[Geoserver-devel] Build failed in Jenkins: geoserver-master #7668
See <https://build.geoserver.org/job/geoserver-master/7668/display/redirect&gt;
[...truncated 2.06 MB...]
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-csw ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-csw ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.wfs.web.CSWAdminPageTest
[ERROR] Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 311.082 s <<< FAILURE! - in org.geoserver.geofence.internal.InternalUserResolverTest
[ERROR] testInternalUserResolver(org.geoserver.geofence.internal.InternalUserResolverTest) Time elapsed: 311.072 s <<< FAILURE!
java.lang.AssertionError
  at org.geoserver.geofence.internal.InternalUserResolverTest.testInternalUserResolver(InternalUserResolverTest.java:152)
[INFO] Running org.geoserver.geofence.rest.AdminRulesRestControllerTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.474 s - in org.geoserver.wfs.web.CSWAdminPageTest
Skipping test in AdminRulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.185 s - in org.geoserver.geofence.rest.AdminRulesRestControllerTest
[INFO] Running org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.16-SNAPSHOT/gs-web-csw-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [100/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.844 s - in org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Running org.geoserver.geofence.rest.RulesRestControllerTest
Skipping test in RulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.617 s - in org.geoserver.geofence.rest.RulesRestControllerTest
[INFO] Running org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.014 s - in org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.041 s - in org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.652 s - in org.geoserver.geofence.web.GeofenceServerPageTest
[INFO]
[INFO] Results:
[INFO]
[ERROR] Failures:
[ERROR] InternalUserResolverTest.testInternalUserResolver:152
[INFO]
[ERROR] Tests run: 17, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 28.172 s]
[INFO] Core Platform Module ............................... SUCCESS [ 22.893 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.735 s]
[INFO] Main Module ........................................ SUCCESS [01:15 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.044 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:23 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.184 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 23.066 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.427 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.826 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.639 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:02 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:13 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:12 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 17.027 s]
[INFO] gs-rest ............................................ SUCCESS [ 6.735 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 59.167 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:31 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.948 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.420 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.102 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.114 s]
[INFO] Core UI Module ..................................... SUCCESS [01:06 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 23.264 s]
[INFO] GWC UI Module ...................................... SUCCESS [07:08 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.522 s]
[INFO] Demos Module ....................................... SUCCESS [ 35.363 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.982 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.026 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:05 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [06:16 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 14.156 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.550 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.024 s]
[INFO] Printing Module .................................... SUCCESS [ 35.167 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 10.693 s]
[INFO] Community Space .................................... SUCCESS [ 0.021 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.020 s]
[INFO] Application Schema Integration Test ................ SUCCESS [07:38 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.514 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.811 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.803 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.660 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.276 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.349 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.267 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.990 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.632 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.612 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.280 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.741 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service Module ...................... SUCCESS [10:30 min]
[INFO] OGR WPS ............................................ SUCCESS [ 5.566 s]
[INFO] Excel Output Format ................................ SUCCESS [ 13.142 s]
[INFO] Chart external graphics support .................... SUCCESS [ 4.301 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.491 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.643 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.600 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.140 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 18.557 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.218 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.486 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.026 s]
[INFO] Core Monitor Extension ............................. SUCCESS [03:37 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.685 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.033 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.452 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.521 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 19.789 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 14.278 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.029 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.958 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.284 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:15 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.604 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.028 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.057 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.596 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.025 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.274 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 35.540 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.518 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.482 s]
[INFO] Importer Core Module ............................... SUCCESS [ 28.045 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 30.673 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [04:38 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.887 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 25.597 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 51.444 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [05:48 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 15.272 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.439 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.753 s]
[INFO] REST SLD service ................................... SUCCESS [04:20 min]
[INFO] GeoFence security integration ...................... SUCCESS [ 31.888 s]
[INFO] GeoFence Server .................................... FAILURE [05:46 min]
[INFO] Authentication by unique url key ................... SUCCESS [03:03 min]
[INFO] BUILD FAILURE
[INFO] Total time: 43:54 min (Wall Clock)
[INFO] Finished at: 2019-08-22T11:23:56Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-geofence-server: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence-server
See <https://build.geoserver.org/job/geoserver-master/7669/display/redirect&gt;
