[Geoserver-devel] Build failed in Jenkins: geoserver-master #7713
See <https://build.geoserver.org/job/geoserver-master/7713/display/redirect&gt;
[...truncated 1.89 MB...]
[INFO] <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-web ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-web ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.687 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.737 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.16-SNAPSHOT/gs-importer-web-2.16-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.16-SNAPSHOT [90/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.16-SNAPSHOT/gs-web-sec-cas-2.16-SNAPSHOT-sources.jar
[INFO] Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 197.347 s - in org.geoserver.importer.bdb.BDBImportStoreTest
[INFO] Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.445 s - in org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.114 s - in org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.16-SNAPSHOT/gs-importer-bdb-2.16-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.16-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 28.610 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.389 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.637 s]
[INFO] Main Module ........................................ SUCCESS [01:27 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.051 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:38 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 44.424 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 27.206 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.584 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.615 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.487 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [01:21 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:39 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:39 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 23.357 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.196 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:14 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:49 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.454 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.267 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 13.146 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.652 s]
[INFO] Core UI Module ..................................... SUCCESS [01:29 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.244 s]
[INFO] GWC UI Module ...................................... SUCCESS [05:01 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.999 s]
[INFO] Demos Module ....................................... SUCCESS [ 15.366 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.799 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.050 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:17 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [02:17 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 20.314 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.795 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.034 s]
[INFO] Printing Module .................................... SUCCESS [ 38.878 s]
[INFO] Community Space .................................... SUCCESS [ 0.023 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Application Schema Integration Test ................ SUCCESS [08:44 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.133 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.099 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.580 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.945 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.247 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.369 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.265 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.555 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 12.555 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.331 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.026 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.344 s]
[INFO] OGR WFS ............................................ SUCCESS [ 6.240 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 13.759 s]
[INFO] Chart external graphics support .................... SUCCESS [ 4.091 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.674 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.535 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.743 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.470 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.455 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [04:07 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.036 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.408 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.290 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.938 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 20.080 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.042 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.867 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.352 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [04:43 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.122 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.076 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.140 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.956 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.249 s]
[INFO] Importer Core Module ............................... SUCCESS [ 28.896 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 28.479 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [03:22 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.058 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 31.931 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.793 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 17.273 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 10.448 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.768 s]
[INFO] REST SLD service ................................... SUCCESS [02:12 min]
[INFO] GeoFence security integration ...................... SUCCESS [ 20.817 s]
[INFO] GeoFence Server .................................... SUCCESS [07:30 min]
[INFO] Authentication by unique url key ................... SUCCESS [05:34 min]
[INFO] BUILD FAILURE
[INFO] Total time: 37:49 min (Wall Clock)
[INFO] Finished at: 2019-08-25T01:54:12Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <https://build.geoserver.org/job/geoserver-master/7714/display/redirect&gt;
