[Geoserver-devel] Build failed in Jenkins: geoserver-master #7852
See <https://build.geoserver.org/job/geoserver-master/7852/display/redirect&gt;
[...truncated 1.89 MB...]
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-csw ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.wfs.web.CSWAdminPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 476.162 s - in org.geoserver.geofence.internal.InternalUserResolverTest
[INFO] Running org.geoserver.geofence.rest.AdminRulesRestControllerTest
Skipping test in AdminRulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.492 s - in org.geoserver.geofence.rest.AdminRulesRestControllerTest
[INFO] Running org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.716 s - in org.geoserver.wfs.web.CSWAdminPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.17-SNAPSHOT [95/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.936 s - in org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Running org.geoserver.geofence.rest.RulesRestControllerTest
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar
Skipping test in RulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.859 s - in org.geoserver.geofence.rest.RulesRestControllerTest
[INFO] Running org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.124 s - in org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.358 s - in org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.804 s - in org.geoserver.geofence.web.GeofenceServerPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 17, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-geofence-server ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 39.769 s]
[INFO] Core Platform Module ............................... SUCCESS [ 28.900 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.486 s]
[INFO] Main Module ........................................ SUCCESS [01:22 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.066 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:31 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 51.455 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 27.527 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.504 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.130 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.369 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:22 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:17 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:54 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 22.979 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.343 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:05 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:45 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 14.175 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 15.707 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 11.978 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.151 s]
[INFO] Core UI Module ..................................... SUCCESS [01:12 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 32.360 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 7.828 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.761 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 10.735 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.028 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:23 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:06 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 21.915 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.649 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.031 s]
[INFO] Printing Module .................................... SUCCESS [ 37.794 s]
[INFO] Community Space .................................... SUCCESS [ 0.032 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:04 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.913 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.857 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.822 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.877 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.238 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.952 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.298 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 5.128 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 12.998 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.822 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.042 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.369 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.223 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.089 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:12 min]
[INFO] OGR WPS ............................................ SUCCESS [ 5.901 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.103 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.187 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.514 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.259 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.659 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.564 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 19.772 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.496 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.546 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.033 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.543 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.281 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 14.009 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.481 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.029 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.859 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.458 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 24.492 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.937 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.027 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 10.747 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.116 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.818 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 32.269 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 7.683 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 7.506 s]
[INFO] Importer Core Module ............................... SUCCESS [ 35.182 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 32.094 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [07:36 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.408 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 30.158 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 18.139 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 28.581 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 21.529 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.924 s]
[INFO] REST SLD service ................................... SUCCESS [ 22.284 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 20.177 s]
[INFO] GeoFence Server .................................... SUCCESS [08:31 min]
[INFO] Authentication by unique url key ................... SUCCESS [ 47.861 s]
[INFO] BUILD FAILURE
[INFO] Total time: 26:38 min (Wall Clock)
[INFO] Finished at: 2019-09-02T00:24:45Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <https://build.geoserver.org/job/geoserver-master/7853/display/redirect&gt;
