See <https://build.geoserver.org/job/geoserver-master/7926/display/redirect>
[...truncated 1.71 MB...]
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-csw ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.wfs.web.CSWAdminPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.037 s - in org.geoserver.wfs.web.CSWAdminPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.17-SNAPSHOT [90/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar
[INFO] Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 184.172 s - in org.geoserver.importer.bdb.BDBImportStoreTest
[INFO] Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.596 s - in org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
[INFO] Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.414 s - in org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.17-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.17-SNAPSHOT/gs-importer-bdb-2.17-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 22.275 s]
[INFO] Core Platform Module ............................... SUCCESS [ 21.263 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.059 s]
[INFO] Main Module ........................................ SUCCESS [01:19 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.065 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:37 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 47.196 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 24.056 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.414 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 17.959 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 16.967 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [01:20 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:18 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:34 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 22.829 s]
[INFO] gs-rest ............................................ SUCCESS [ 6.743 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:53 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.952 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 15.161 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.221 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.082 s]
[INFO] Core UI Module ..................................... SUCCESS [01:18 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 25.903 s]
[INFO] GWC UI Module ...................................... SUCCESS [05:14 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 8.021 s]
[INFO] Demos Module ....................................... SUCCESS [ 15.042 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 7.420 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.031 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:25 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 52.342 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.999 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.324 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.041 s]
[INFO] Printing Module .................................... SUCCESS [ 37.315 s]
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.018 s]
[INFO] Application Schema Integration Test ................ SUCCESS [05:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.798 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.765 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.465 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.647 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.554 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.880 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.257 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.210 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.858 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 4.145 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.028 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.259 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.820 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.032 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 15.825 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.117 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.452 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.251 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.559 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.338 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.510 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.135 s]
[INFO] Core Monitor Extension ............................. SUCCESS [04:43 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.319 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.384 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.866 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 13.424 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 7.163 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.762 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [04:41 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.133 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.018 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 9.766 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.018 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.040 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.317 s]
[INFO] Importer Core Module ............................... SUCCESS [ 28.096 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 26.289 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [03:09 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 8.915 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 30.596 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.969 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 17.693 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 8.061 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.539 s]
[INFO] REST SLD service ................................... SUCCESS [ 18.497 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 14.544 s]
[INFO] GeoFence Server .................................... SUCCESS [03:00 min]
[INFO] Authentication by unique url key ................... SUCCESS [ 54.488 s]
[INFO] BUILD FAILURE
[INFO] Total time: 28:17 min (Wall Clock)
[INFO] Finished at: 2019-09-06T06:22:25Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
