[Geoserver-devel] Build failed in Jenkins: geoserver-master #7944
See <https://build.geoserver.org/job/geoserver-master/7944/display/redirect&gt;
[...truncated 1.78 MB...]
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
  at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:365)
  at org.apache.maven.surefire.junit4.JUnit4Provider.executeWithRerun(JUnit4Provider.java:273)
  at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:238)
  at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:159)
  at org.apache.maven.surefire.booter.ForkedBooter.invokeProviderInSameClassLoader(ForkedBooter.java:384)
  at org.apache.maven.surefire.booter.ForkedBooter.runSuitesInProcess(ForkedBooter.java:345)
  at org.apache.maven.surefire.booter.ForkedBooter.execute(ForkedBooter.java:126)
  at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:418)
[INFO] Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.918 s - in org.geoserver.importer.rest.ImporterIntegrationTest
[INFO] Running org.geoserver.importer.rest.PostScriptTransformTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 s - in org.geoserver.importer.rest.PostScriptTransformTest
[INFO] Running org.geoserver.importer.rest.converters.ImportJSONIOTest
[INFO] Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.028 s - in org.geoserver.importer.rest.converters.ImportJSONIOTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 77, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-rest/2.17-SNAPSHOT/gs-importer-rest-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-rest/2.17-SNAPSHOT/gs-importer-rest-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-rest/2.17-SNAPSHOT/gs-importer-rest-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-rest/2.17-SNAPSHOT/gs-importer-rest-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-rest/2.17-SNAPSHOT/gs-importer-rest-2.17-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.17-SNAPSHOT [90/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.378 s - in org.geoserver.wfs.web.CSWAdminPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 29.925 s]
[INFO] Core Platform Module ............................... SUCCESS [ 22.951 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.963 s]
[INFO] Main Module ........................................ SUCCESS [01:07 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.038 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:27 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.197 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.102 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.359 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 9.880 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 11.748 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [01:02 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:00 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:51 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 15.074 s]
[INFO] gs-rest ............................................ SUCCESS [ 5.265 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 49.592 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:16 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.976 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 10.265 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 7.707 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.098 s]
[INFO] Core UI Module ..................................... SUCCESS [ 59.688 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 19.365 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 25.758 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 5.691 s]
[INFO] Demos Module ....................................... SUCCESS [ 18.783 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.855 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.023 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 57.570 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [03:32 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.575 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.439 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.023 s]
[INFO] Printing Module .................................... SUCCESS [ 33.355 s]
[INFO] Community Space .................................... SUCCESS [ 0.017 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.014 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:35 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.295 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.682 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 5.678 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 3.132 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.427 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.313 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.243 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.762 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 12.310 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.630 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.013 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.220 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.198 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.012 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 12.079 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.611 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.414 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.969 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.369 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.062 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.422 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.022 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.040 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.022 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.728 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.236 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.198 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.075 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.023 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.476 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.008 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 22.442 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 7.700 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.015 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.181 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.013 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 4.699 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.221 s]
[INFO] Importer Core Module ............................... SUCCESS [ 26.670 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 30.814 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 10.426 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 11.160 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 26.596 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.366 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.815 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.287 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.792 s]
[INFO] REST SLD service ................................... SUCCESS [03:05 min]
[INFO] GeoFence security integration ...................... SUCCESS [ 13.292 s]
[INFO] GeoFence Server .................................... SUCCESS [ 35.213 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 43.679 s]
[INFO] BUILD FAILURE
[INFO] Total time: 16:41 min (Wall Clock)
[INFO] Finished at: 2019-09-07T04:24:44Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <https://build.geoserver.org/job/geoserver-master/7945/display/redirect&gt;
