[Geoserver-devel] Build failed in Jenkins: geoserver-master #8012
See <https://build.geoserver.org/job/geoserver-master/8012/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] [GEOS-9133] Cannot configure hyperspectral image in "bin" package, form
[nuno.oliveira] [GEOS-8982] GetCapabilities on a single layer fails if a style is
[nuno.oliveira] [GEOS-9248] Allow setting Entity Expansion limit on WFS XML Readers.
[...truncated 1.08 MB...]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-importer-web ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/test-classes&gt;
[INFO] Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.579 s - in org.geoserver.test.XYGeomTest
[INFO] Running org.geoserver.test.XlinkGeometryTest
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-importer-web ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.467 s - in org.geoserver.test.XlinkGeometryTest
[INFO] Running org.geoserver.test.XlinkWfsTest
[INFO] Running org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.94 s - in org.geoserver.test.XlinkWfsTest
[INFO] Running org.geoserver.test.web.Gml311LinksTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.842 s - in org.geoserver.importer.web.AbstractDBPanelTest
[INFO] Running org.geoserver.importer.web.ImportTaskTableTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.086 s - in org.geoserver.test.web.Gml311LinksTest
[INFO] Running org.geoserver.test.web.Gml32LinksTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.462 s - in org.geoserver.test.web.Gml32LinksTest
[INFO]
[INFO] Results:
[INFO]
[WARNING] Tests run: 231, Failures: 0, Errors: 0, Skipped: 25
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-app-schema-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-app-schema-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-app-schema-test ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-app-schema-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-app-schema-test ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-test/2.17-SNAPSHOT/gs-app-schema-test-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-test/2.17-SNAPSHOT/gs-app-schema-test-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-test/2.17-SNAPSHOT/gs-app-schema-test-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/gs-app-schema-test-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-test/2.17-SNAPSHOT/gs-app-schema-test-2.17-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.17-SNAPSHOT [90/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.188 s - in org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.17-SNAPSHOT/gs-importer-web-2.17-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.466 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.716 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.599 s]
[INFO] Main Module ........................................ SUCCESS [01:00 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.041 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:23 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.523 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 16.445 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.515 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.170 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 12.446 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [01:05 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:05 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:55 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 16.009 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.202 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 51.030 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:21 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.473 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.034 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 8.574 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.051 s]
[INFO] Core UI Module ..................................... SUCCESS [ 51.035 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 33.325 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 32.106 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.027 s]
[INFO] Demos Module ....................................... SUCCESS [02:08 min]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.495 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.032 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:01 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 50.261 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.234 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.824 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.032 s]
[INFO] Printing Module .................................... SUCCESS [ 6.766 s]
[INFO] Community Space .................................... SUCCESS [ 0.023 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.019 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:39 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.129 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.227 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.078 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.751 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.602 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.223 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.213 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.845 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.613 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.242 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.032 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.228 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.420 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 9.152 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.420 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.380 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.419 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.505 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.005 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.432 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.029 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.844 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.363 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.377 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.962 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.809 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.030 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 3.706 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.412 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 21.066 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.365 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.036 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.154 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.028 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.216 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.052 s]
[INFO] Importer Core Module ............................... SUCCESS [ 29.022 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 30.025 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 10.285 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.764 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 10.971 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [01:59 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.807 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.444 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.714 s]
[INFO] REST SLD service ................................... SUCCESS [ 14.870 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 16.199 s]
[INFO] GeoFence Server .................................... SUCCESS [ 26.721 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 43.571 s]
[INFO] BUILD FAILURE
[INFO] Total time: 14:34 min (Wall Clock)
[INFO] Finished at: 2019-09-10T13:54:40Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
Not sending mail to unregistered user nuno.oliveira@anonymised.com
See <https://build.geoserver.org/job/geoserver-master/8013/display/redirect?page=changes&gt;
