See <https://build.geoserver.org/job/geoserver-master/8034/display/redirect>
[...truncated 1.80 MB...]
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar
[INFO]
[INFO] --------------------< org.geoserver.csw:gs-web-csw >--------------------
[INFO] Building CSW UI Module 2.17-SNAPSHOT [96/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-csw ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-csw ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-csw ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-csw ---
[info] Skipping format check
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-csw ---
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-csw ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-csw ---
[INFO]
[INFO] -------------------------------------------------------
[INFO] T E S T S
[INFO] Running org.geoserver.wfs.web.CSWAdminPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 267.43 s - in org.geoserver.geofence.internal.InternalUserResolverTest
[INFO] Running org.geoserver.geofence.rest.AdminRulesRestControllerTest
Skipping test in AdminRulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.274 s - in org.geoserver.geofence.rest.AdminRulesRestControllerTest
[INFO] Running org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.946 s - in org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Running org.geoserver.geofence.rest.RulesRestControllerTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.451 s - in org.geoserver.wfs.web.CSWAdminPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.17-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.17-SNAPSHOT/gs-web-csw-2.17-SNAPSHOT-test-sources.jar
Skipping test in RulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.688 s - in org.geoserver.geofence.rest.RulesRestControllerTest
[INFO] Running org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.065 s - in org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.242 s - in org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.814 s - in org.geoserver.geofence.web.GeofenceServerPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 17, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-geofence-server ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 23.792 s]
[INFO] Core Platform Module ............................... SUCCESS [ 22.383 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.267 s]
[INFO] Main Module ........................................ SUCCESS [01:21 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.048 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:37 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 46.263 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 29.778 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.554 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.898 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 21.194 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:16 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:26 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:47 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 22.344 s]
[INFO] gs-rest ............................................ SUCCESS [ 6.899 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:55 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.323 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 14.664 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.042 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.084 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 26.421 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 49.960 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.771 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.842 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.015 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.054 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:25 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 46.781 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.299 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.042 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.028 s]
[INFO] Printing Module .................................... SUCCESS [ 26.883 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.416 s]
[INFO] Community Space .................................... SUCCESS [ 0.019 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.019 s]
[INFO] Application Schema Integration Test ................ SUCCESS [04:46 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.369 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 9.879 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.596 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.850 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.536 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.403 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.237 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.343 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.589 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 2.402 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.310 s]
[INFO] OGR WFS ............................................ SUCCESS [ 6.531 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:02 min]
[INFO] Excel Output Format ................................ SUCCESS [ 16.664 s]
[INFO] Chart external graphics support .................... SUCCESS [ 3.691 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.466 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.164 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.619 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.730 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.526 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] Core Monitor Extension ............................. SUCCESS [01:14 min]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.435 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.333 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.000 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 19.696 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.481 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.029 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 7.368 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.879 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [04:18 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.635 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.721 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.017 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.539 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [03:35 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.178 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 4.232 s]
[INFO] Importer Core Module ............................... SUCCESS [ 26.934 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 28.365 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [03:40 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.329 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 24.122 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.212 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [04:01 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 18.226 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 8.313 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.356 s]
[INFO] REST SLD service ................................... SUCCESS [ 18.966 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 14.938 s]
[INFO] GeoFence Server .................................... SUCCESS [05:01 min]
[INFO] Authentication by unique url key ................... SUCCESS [ 43.795 s]
[INFO] BUILD FAILURE
[INFO] Total time: 29:25 min (Wall Clock)
[INFO] Finished at: 2019-09-11T20:43:38Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.22.2:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] Please refer to dump files (if any exist) [date].dump, [date]-jvmRun[N].dump and [date].dumpstream.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
