See <https://build.geoserver.org/job/geoserver-master/8049/display/redirect>
[...truncated 1.82 MB...]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/junit/junit/4.10/junit-4.10.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/junit/junit/4.10/junit-4.10.pom (2.3 kB at 33 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/hamcrest/hamcrest-core/1.1/hamcrest-core-1.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/hamcrest/hamcrest-core/1.1/hamcrest-core-1.1.pom (481 B at 6.5 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/hamcrest/hamcrest-parent/1.1/hamcrest-parent-1.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/hamcrest/hamcrest-parent/1.1/hamcrest-parent-1.1.pom (5.9 kB at 137 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.1/maven-plugin-api-2.0.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven-plugin-api/2.0.1/maven-plugin-api-2.0.1.pom (643 B at 11 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.1/maven-2.0.1.pom
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/apache/maven/maven/2.0.1/maven-2.0.1.pom (11 kB at 174 kB/s)
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.8/plexus-utils-1.5.8.jar
[INFO] Downloaded from central: https://repo.maven.apache.org/maven2/org/codehaus/plexus/plexus-utils/1.5.8/plexus-utils-1.5.8.jar (268 kB at 1.3 MB/s)
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /home/ubuntu/.m2/repository/org/geoserver/web/gs-web-app/2.17-SNAPSHOT/gs-web-app-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/web/gs-web-app/2.17-SNAPSHOT/gs-web-app-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.17-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/web/gs-web-app/2.17-SNAPSHOT/gs-web-app-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.17-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/web/gs-web-app/2.17-SNAPSHOT/gs-web-app-2.17-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /home/ubuntu/.m2/repository/org/geoserver/web/gs-web-app/2.17-SNAPSHOT/gs-web-app-2.17-SNAPSHOT.war
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.17-SNAPSHOT [97/100]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master/ws/src>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:format (default) @ gs-web-sec-cas ---
[info] Skipping format check
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-web-sec-cas ---
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.17-SNAPSHOT/gs-web-sec-cas-2.17-SNAPSHOT-sources.jar
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 95.14 s - in org.geoserver.geofence.internal.InternalUserResolverTest
[INFO] Running org.geoserver.geofence.rest.AdminRulesRestControllerTest
Skipping test in AdminRulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.752 s - in org.geoserver.geofence.rest.AdminRulesRestControllerTest
[INFO] Running org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.164 s - in org.geoserver.geofence.rest.MultiPolygonAdapterTest
[INFO] Running org.geoserver.geofence.rest.RulesRestControllerTest
Skipping test in RulesRestControllerTest as GeoFence service is down: in order to run this test you need the services to be running on port 9191
[INFO] Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.346 s - in org.geoserver.geofence.rest.RulesRestControllerTest
[INFO] Running org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.256 s - in org.geoserver.geofence.web.GeofenceRulesModelTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.492 s - in org.geoserver.geofence.web.GeofenceServerAdminPageTest
[INFO] Running org.geoserver.geofence.web.GeofenceServerPageTest
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.267 s - in org.geoserver.geofence.web.GeofenceServerPageTest
[INFO]
[INFO] Results:
[INFO]
[INFO] Tests run: 17, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-geofence-server ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-geofence-server ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master/ws/src/extension/geofence-server/target/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-geofence-server/2.17-SNAPSHOT/gs-geofence-server-2.17-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.17-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 17.408 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.484 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.136 s]
[INFO] Main Module ........................................ SUCCESS [01:29 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.049 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:40 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 42.248 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 26.785 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.529 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 21.323 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.920 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:07 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:45 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:26 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 21.131 s]
[INFO] gs-rest ............................................ SUCCESS [ 8.133 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:04 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:46 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.257 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.629 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.821 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.104 s]
[INFO] Core UI Module ..................................... SUCCESS [01:33 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.414 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:09 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.826 s]
[INFO] Demos Module ....................................... SUCCESS [ 15.604 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.592 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.044 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:12 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [06:15 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 17.089 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.844 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.037 s]
[INFO] Printing Module .................................... SUCCESS [02:55 min]
[INFO] GeoServer Web Application .......................... SUCCESS [ 12.487 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:50 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.654 s]
[INFO] ArcSDE DataStore Extension ......................... FAILURE [01:08 min]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.691 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.465 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.747 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.184 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.233 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 5.215 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [02:06 min]
[INFO] JP2K Coverage Extension ............................ FAILURE [01:00 min]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.441 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.678 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.035 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:07 min]
[INFO] OGR WPS ............................................ SUCCESS [ 6.041 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.761 s]
[INFO] Chart external graphics support .................... SUCCESS [01:00 min]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.816 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.479 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.166 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 10.736 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 21.161 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.207 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.478 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.027 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.452 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.708 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.315 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.280 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 22.908 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.526 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.034 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.644 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.786 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [05:02 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.299 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.025 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 9.333 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.039 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.693 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [04:52 min]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 7.377 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 7.092 s]
[INFO] Importer Core Module ............................... FAILURE [ 1.804 s]
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 23.884 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 37.895 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 27.344 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 20.066 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 10.103 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.205 s]
[INFO] REST SLD service ................................... SUCCESS [06:46 min]
[INFO] GeoFence security integration ...................... SUCCESS [03:46 min]
[INFO] GeoFence Server .................................... SUCCESS [02:24 min]
[INFO] Authentication by unique url key ................... SUCCESS [03:33 min]
[INFO] BUILD FAILURE
[INFO] Total time: 37:03 min (Wall Clock)
[INFO] Finished at: 2019-09-12T15:01:53Z
[ERROR] Failed to execute goal on project gs-jp2k: Could not resolve dependencies for project org.geoserver.extension:gs-jp2k:jar:2.17-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-jp2k:jar:23-SNAPSHOT: Failed to read artifact descriptor for org.geotools:gt-jp2k:jar:23-SNAPSHOT: Could not transfer artifact org.geotools:gt-jp2k:pom:23-SNAPSHOT from/to boundless (https://repo.boundlessgeo.com/main/): Failed to transfer file: https://repo.boundlessgeo.com/main/org/geotools/gt-jp2k/23-SNAPSHOT/gt-jp2k-23-SNAPSHOT.pom. Return code is: 502 , ReasonPhrase:Bad Gateway. -> [Help 1]
[ERROR] Failed to execute goal on project gs-arcsde: Could not resolve dependencies for project org.geoserver.extension:gs-arcsde:jar:2.17-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-arcsde-common:jar:23-SNAPSHOT: Failed to read artifact descriptor for org.geotools:gt-arcsde-common:jar:23-SNAPSHOT: Could not transfer artifact org.geotools:gt-arcsde-common:pom:23-SNAPSHOT from/to boundless (https://repo.boundlessgeo.com/main/): Failed to transfer file: https://repo.boundlessgeo.com/main/org/geotools/gt-arcsde-common/23-SNAPSHOT/gt-arcsde-common-23-SNAPSHOT.pom. Return code is: 502 , ReasonPhrase:Bad Gateway. -> [Help 1]
[ERROR] Failed to execute goal on project gs-importer-core: Could not resolve dependencies for project org.geoserver.importer:gs-importer-core:jar:2.17-SNAPSHOT: Could not find artifact org.geotools:gt-arcsde-common:jar:23-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-jp2k
