[Geoserver-devel] Build failed in Jenkins: geoserver-master #873
See <http://ares.opengeo.org/jenkins/job/geoserver-master/873/changes&gt;
Changes:
[dwinslow] Enforce that store and layer names are xml-safe at the catalog level
[...truncated 19396 lines...]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Enforce that store and layer names are xml-safe at the catalog level
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 30.10.2014 @ 13:30:58 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 30-Oct-2014 14:02
[INFO] [GitCommitIdMojo] build.build.time = 30.10.2014 @ 14:21:43 UTC
[INFO] [GitCommitIdMojo] build.branch = b00ed3c5e86006a009ba44dd4c4f4f3767b68999
[INFO] [GitCommitIdMojo] build.commit.user.email = dwinslow@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = David Winslow
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = b00ed3c
[INFO] [GitCommitIdMojo] build.commit.id = b00ed3c5e86006a009ba44dd4c4f4f3767b68999
[INFO] [GitCommitIdMojo] build.commit.message.full = Enforce that store and layer names are xml-safe at the catalog level
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-core ---
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-core ---
[INFO] Compiling 131 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/classes&gt;
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.83 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.872 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.511 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/ImportProcess.java&gt;:\[443,62\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.87 sec
Results :
Tests run: 650, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wms ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/gs-wms-2.7-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wms ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/gs-wms-2.7-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wms >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wms ---
[INFO] [GitCommitIdMojo] build.build.time = 30.10.2014 @ 14:21:56 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wms <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wms ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/gs-wms-2.7-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wms >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wms <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wms ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/gs-wms-2.7-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wms ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/gs-wms-2.7-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wms/2.7-SNAPSHOT/gs-wms-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wms/2.7-SNAPSHOT/gs-wms-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/gs-wms-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wms/2.7-SNAPSHOT/gs-wms-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/gs-wms-2.7-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wms/2.7-SNAPSHOT/gs-wms-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/gs-wms-2.7-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wms/2.7-SNAPSHOT/gs-wms-2.7-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.729s]
[INFO] Core Platform Module .............................. SUCCESS [14.724s]
[INFO] Open Web Service Module ........................... SUCCESS [16.671s]
[INFO] Main Module ....................................... SUCCESS [3:16.693s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.758s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.433s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [45.381s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.678s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.354s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.340s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.288s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:54.243s]
[INFO] Web Map Service Module ............................ SUCCESS [7:00.033s]
[INFO] REST Support Module ............................... SUCCESS [46.699s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.451s]
[INFO] Core UI Module .................................... SUCCESS [2:41.772s]
[INFO] WFS UI Module ..................................... SUCCESS [42.470s]
[INFO] Security UI Modules ............................... SUCCESS [0.239s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.289s]
[INFO] Printing Module ................................... SUCCESS [36.855s]
[INFO] Community Space ................................... SUCCESS [0.238s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.203s]
[INFO] Application Schema Support ........................ SUCCESS [0.172s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.507s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.525s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.599s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.194s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.707s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.342s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.339s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.013s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.442s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.058s]
[INFO] Excel Output Format ............................... SUCCESS [39.609s]
[INFO] Chart external graphics support ................... SUCCESS [2.316s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.085s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.705s]
[INFO] OWS request flow controller ....................... SUCCESS [29.438s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.268s]
[INFO] Web Processing Service Module ..................... FAILURE [12.254s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.553s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.628s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [54.434s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.352s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.363s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.272s]
[INFO] DXF WFS output format ............................. SUCCESS [42.409s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.213s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 19:07.706s (Wall Clock)
[INFO] Finished at: Thu Oct 30 14:21:56 UTC 2014
[INFO] Final Memory: 59M/176M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wps-core: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.opengeo.org/jenkins/job/geoserver-master/874/&gt;
[...truncated 19326 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 30-Oct-2014 19:49
[INFO] [GitCommitIdMojo] build.build.time = 30.10.2014 @ 20:08:49 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/gs-wcs2_0-2.7-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wcs2_0 ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/gs-wcs2_0-2.7-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.7-SNAPSHOT/gs-wcs2_0-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.7-SNAPSHOT/gs-wcs2_0-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/gs-wcs2_0-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.7-SNAPSHOT/gs-wcs2_0-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/gs-wcs2_0-2.7-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.7-SNAPSHOT/gs-wcs2_0-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wcs2_0/target/gs-wcs2_0-2.7-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.7-SNAPSHOT/gs-wcs2_0-2.7-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Processing Service Module 2.7-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Web Processing Service Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (976 B at 2.7 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml
971/971 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (971 B at 79.0 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (976 B at 79.4 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml
967/967 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml (967 B at 94.4 KB/sec)
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.44 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 30.10.2014 @ 20:08:52 UTC
[INFO]
[INFO]
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.379 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.242 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
[INFO] 1 error
[INFO]
[INFO]
[INFO]
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.315 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.974 sec
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.558s]
[INFO] Core Platform Module .............................. SUCCESS [14.073s]
[INFO] Open Web Service Module ........................... SUCCESS [16.185s]
[INFO] Main Module ....................................... SUCCESS [3:19.300s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.804s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:19.187s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [51.236s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.276s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:11.291s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.961s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:14.786s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:35.759s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [46.637s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.387s]
[INFO] Core UI Module .................................... SUCCESS [2:30.373s]
[INFO] WFS UI Module ..................................... SUCCESS [43.762s]
[INFO] Security UI Modules ............................... SUCCESS [0.194s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.207s]
[INFO] Printing Module ................................... SUCCESS [33.083s]
[INFO] Community Space ................................... SUCCESS [0.201s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.373s]
[INFO] Application Schema Support ........................ SUCCESS [0.141s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.705s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.815s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.546s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.254s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.549s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.712s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.561s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.840s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.463s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [33.045s]
[INFO] Excel Output Format ............................... SUCCESS [40.213s]
[INFO] Chart external graphics support ................... SUCCESS [2.146s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.723s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.986s]
[INFO] OWS request flow controller ....................... SUCCESS [30.869s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.114s]
[INFO] Web Processing Service Module ..................... FAILURE [11.915s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.627s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.133s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [54.183s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.272s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.758s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.207s]
[INFO] DXF WFS output format ............................. SUCCESS [45.811s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.198s]
[INFO] Total time: 19:09.585s (Wall Clock)
[INFO] Finished at: Thu Oct 30 20:09:07 UTC 2014
[INFO] Final Memory: 59M/195M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/875/&gt;
[...truncated 19374 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 31-Oct-2014 12:22
[INFO] [GitCommitIdMojo] build.build.time = 31.10.2014 @ 12:41:48 UTC
[INFO]
[INFO]
[INFO]
[INFO]
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (976 B at 63.5 KB/sec)
971/971 B
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (976 B at 86.6 KB/sec)
967/967 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml (967 B at 85.8 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 31.10.2014 @ 12:41:49 UTC
[INFO]
[INFO]
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.981 sec
id = t0002
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.371 sec
[INFO] 1 error
[INFO]
[INFO]
[INFO]
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.895 sec
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.615 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.211 sec
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.095s]
[INFO] Core Platform Module .............................. SUCCESS [15.472s]
[INFO] Open Web Service Module ........................... SUCCESS [17.410s]
[INFO] Main Module ....................................... SUCCESS [3:16.933s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.850s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:18.411s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [46.647s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.756s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:09.000s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.784s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:17.427s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:41.989s]
[INFO] REST Support Module ............................... SUCCESS [44.742s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.305s]
[INFO] Core UI Module .................................... SUCCESS [2:30.607s]
[INFO] WFS UI Module ..................................... SUCCESS [43.790s]
[INFO] Security UI Modules ............................... SUCCESS [0.283s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.160s]
[INFO] Printing Module ................................... SUCCESS [39.171s]
[INFO] Community Space ................................... SUCCESS [0.241s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.173s]
[INFO] Application Schema Support ........................ SUCCESS [0.235s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.849s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.199s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.494s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.588s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.584s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.333s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.446s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.005s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.688s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.490s]
[INFO] Excel Output Format ............................... SUCCESS [41.542s]
[INFO] Chart external graphics support ................... SUCCESS [2.150s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.990s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.876s]
[INFO] OWS request flow controller ....................... SUCCESS [32.652s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.306s]
[INFO] Web Processing Service Module ..................... FAILURE [11.399s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.622s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.439s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [52.553s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.492s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.055s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.442s]
[INFO] DXF WFS output format ............................. SUCCESS [41.497s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.206s]
[INFO] Total time: 19:10.323s (Wall Clock)
[INFO] Finished at: Fri Oct 31 12:42:05 UTC 2014
[INFO] Final Memory: 59M/212M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/876/changes&gt;
Changes:
[dwinslow] Update ImportProcess to match changes in Catalog API
[...truncated 19386 lines...]
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 53d4ae2
[INFO] [GitCommitIdMojo] build.commit.id = 53d4ae238ac3e9649c455438ba38af1e88cd28d9
[INFO] [GitCommitIdMojo] build.commit.message.full = Update ImportProcess to match changes in Catalog API
[INFO]
[INFO]
[INFO]
[INFO]
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (976 B at 47.7 KB/sec)
971/971 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (971 B at 8.2 KB/sec)
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (976 B at 43.3 KB/sec)
967/967 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/13-SNAPSHOT/maven-metadata.xml (967 B at 78.7 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Update ImportProcess to match changes in Catalog API
[INFO] [GitCommitIdMojo] build.commit.time = 31.10.2014 @ 14:30:07 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 31-Oct-2014 14:32
[INFO] [GitCommitIdMojo] build.build.time = 31.10.2014 @ 14:51:36 UTC
[INFO] [GitCommitIdMojo] build.branch = 53d4ae238ac3e9649c455438ba38af1e88cd28d9
[INFO]
[INFO]
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.889 sec
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-core ---
[INFO] Copying 13 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-core ---
[INFO] Compiling 50 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/test-classes&gt;
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.34 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.232 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.916 sec
Results :
Failed tests: testExplicitMaxTimeCoverageSelector(org.geoserver.wms.dimension.RasterTimeDimensionDefaultValueTest): Default time should be the biggest one
Tests run: 650, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-wps-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wps.DescribeProcessTest
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.430s]
[INFO] Core Platform Module .............................. SUCCESS [15.212s]
[INFO] Open Web Service Module ........................... SUCCESS [17.030s]
[INFO] Main Module ....................................... SUCCESS [3:16.470s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.867s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:18.968s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [45.835s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.719s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.963s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.127s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:08.498s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:44.862s]
[INFO] Web Map Service Module ............................ FAILURE [7:00.660s]
[INFO] REST Support Module ............................... SUCCESS [45.622s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.375s]
[INFO] Core UI Module .................................... SUCCESS [2:35.377s]
[INFO] WFS UI Module ..................................... SUCCESS [44.252s]
[INFO] Security UI Modules ............................... SUCCESS [0.345s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.130s]
[INFO] Printing Module ................................... SUCCESS [36.821s]
[INFO] Community Space ................................... SUCCESS [0.183s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.268s]
[INFO] Application Schema Support ........................ SUCCESS [0.118s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [40.550s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.058s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.223s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.162s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.626s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.301s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.436s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.256s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.479s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.457s]
[INFO] Excel Output Format ............................... SUCCESS [40.761s]
[INFO] Chart external graphics support ................... SUCCESS [1.767s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.253s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.733s]
[INFO] OWS request flow controller ....................... SUCCESS [29.965s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.193s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.150s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.171s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [53.376s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.159s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.775s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.435s]
[INFO] DXF WFS output format ............................. SUCCESS [40.561s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.184s]
[INFO] Total time: 19:08.873s (Wall Clock)
[INFO] Finished at: Fri Oct 31 14:51:56 UTC 2014
[INFO] Final Memory: 58M/189M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-master/877/changes&gt;
