[Geoserver-devel] Build failed in Jenkins: geoserver-master #915
See <http://ares.opengeo.org/jenkins/job/geoserver-master/915/&gt;
[...truncated 26316 lines...]
GEOS-6775: removed wrong content-length header from gzipped content
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-sec-jdbc ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/src/main/resources&gt;
[INFO] Copying 7 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-sec-jdbc ---
[INFO] Compiling 8 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/classes&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.119 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.938 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.659 sec
Running org.geoserver.test.SecondaryNamespaceTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-jdbc ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-sec-jdbc ---
[INFO] Compiling 13 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/test-classes&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.64 sec
Running org.geoserver.test.SecuredFeatureChainingTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-sec-jdbc ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/surefire-reports&gt;
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.533 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Running org.geoserver.security.web.jdbc.JDBCConnectionPanelTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.332 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.423 sec
Running org.geoserver.test.StringConstantIdWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.786 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.561 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.594 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.352 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.734 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.032 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 31.238 sec
Running org.geoserver.security.web.jdbc.group.JDBCConfirmRemovalGroupPanelTest
Query:
   feature type: MappedFeatureType
   filter: [ shape intersects POLYGON ((-1.3650000000000033 52.475133749539246, -1.235000000000003 52.475133749539246, -1.235000000000003 52.52485219413131, -1.3650000000000033 52.52485219413131, -1.3650000000000033 52.475133749539246)) ]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   filter: [ shape intersects POLYGON ((-1.365 52.475, -1.235 52.475, -1.235 52.525, -1.365 52.525, -1.365 52.475)) ]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   filter: [[ shape intersects POLYGON ((-1.365 53.475, -1.235 53.475, -1.235 53.525, -1.365 53.525, -1.365 53.475)) ] AND [[ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = http://urn.opengis.net ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = a ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = b ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = c ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = d ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = e ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = f ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = g ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = h ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = i ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = j ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = k ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = l ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = m ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = n ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = o ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = p ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = q ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = r ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = S ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = t ]]]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.537 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.09 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.813 sec
Running org.geoserver.security.web.jdbc.group.JDBCEditGroupPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.915 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.114 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.226 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.515 sec
Results :
Failed tests: testFilterAnd(org.geoserver.test.FeatureChainingWfsTest): expected:<[1]> but was:<[3]>
Tests run: 151, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.248 sec
Running org.geoserver.security.web.jdbc.group.JDBCGroupListPageTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.204s]
[INFO] Core Platform Module .............................. SUCCESS [13.843s]
[INFO] Open Web Service Module ........................... SUCCESS [18.092s]
[INFO] Main Module ....................................... SUCCESS [3:14.587s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.857s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:16.909s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [47.607s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.936s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.226s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.222s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:07.190s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:38.360s]
[INFO] Web Map Service Module ............................ SUCCESS [7:07.317s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:27.983s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:38.568s]
[INFO] REST Support Module ............................... SUCCESS [44.205s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:26.174s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.204s]
[INFO] Core UI Module .................................... SUCCESS [2:32.244s]
[INFO] WMS UI Module ..................................... SUCCESS [1:03.811s]
[INFO] GWC UI Module ..................................... SUCCESS [1:33.036s]
[INFO] WFS UI Module ..................................... SUCCESS [47.096s]
[INFO] Demoes Module ..................................... SUCCESS [1:02.821s]
[INFO] WCS UI Module ..................................... SUCCESS [55.083s]
[INFO] Security UI Modules ............................... SUCCESS [0.302s]
[INFO] Security UI Core Module ........................... SUCCESS [3:53.814s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [47.188s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.171s]
[INFO] Printing Module ................................... SUCCESS [37.566s]
[INFO] Community Space ................................... SUCCESS [0.227s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.419s]
[INFO] Application Schema Support ........................ SUCCESS [0.153s]
[INFO] Application Schema Integration Test ............... FAILURE [4:33.414s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [40.700s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.061s]
[INFO] GeoSearch Index Module ............................ SUCCESS [40.630s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.430s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.616s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.593s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.315s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.546s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.946s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.011s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.470s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.268s]
[INFO] Excel Output Format ............................... SUCCESS [42.304s]
[INFO] Chart external graphics support ................... SUCCESS [2.039s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.886s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.836s]
[INFO] OWS request flow controller ....................... SUCCESS [32.572s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.198s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:31.807s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [26.573s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:07.055s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.176s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.852s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.350s]
[INFO] Core Monitor Extension ............................ SUCCESS [26.579s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [17.498s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [59.034s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:00.802s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [51.598s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.169s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.811s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.771s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:50.022s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.213s]
[INFO] DXF WFS output format ............................. SUCCESS [41.300s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [40.642s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.216s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [54.047s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.022s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [35.438s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.334s]
[INFO] Importer Core Module .............................. SUCCESS [1:55.351s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 38:32.444s (Wall Clock)
[INFO] Finished at: Sat Nov 22 14:15:11 UTC 2014
[INFO] Final Memory: 76M/205M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
See <http://ares.opengeo.org/jenkins/job/geoserver-master/916/&gt;
[...truncated 25937 lines...]
[INFO]
[INFO]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.237 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.505 sec
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.438 sec
[INFO]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.332 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.388 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.526 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.774 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.617 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.671 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.058 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.601 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 31.34 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.471 sec
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.016 sec
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.666 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.205 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.057 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.085 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.906 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.398 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.721 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.979s]
[INFO] Core Platform Module .............................. SUCCESS [15.361s]
[INFO] Open Web Service Module ........................... SUCCESS [16.238s]
[INFO] Main Module ....................................... SUCCESS [3:17.210s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.826s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:18.802s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [43.241s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.508s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.817s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:16.868s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.092s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:43.847s]
[INFO] Web Map Service Module ............................ SUCCESS [6:46.226s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:37.047s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:28.109s]
[INFO] REST Support Module ............................... SUCCESS [44.160s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:18.811s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.357s]
[INFO] Core UI Module .................................... SUCCESS [2:30.092s]
[INFO] WMS UI Module ..................................... SUCCESS [1:14.269s]
[INFO] GWC UI Module ..................................... SUCCESS [1:30.776s]
[INFO] WFS UI Module ..................................... SUCCESS [42.318s]
[INFO] Demoes Module ..................................... SUCCESS [1:01.845s]
[INFO] WCS UI Module ..................................... SUCCESS [54.229s]
[INFO] Security UI Modules ............................... SUCCESS [0.199s]
[INFO] Security UI Core Module ........................... SUCCESS [3:40.642s]
[INFO] REST UI Module .................................... SUCCESS [47.056s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.209s]
[INFO] Printing Module ................................... SUCCESS [37.180s]
[INFO] Community Space ................................... SUCCESS [0.179s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.039s]
[INFO] Application Schema Support ........................ SUCCESS [0.123s]
[INFO] Application Schema Integration Test ............... FAILURE [4:34.532s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [40.945s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.418s]
[INFO] GeoSearch Index Module ............................ SUCCESS [45.514s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.837s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.203s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.604s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.308s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.384s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.067s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.973s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.418s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.725s]
[INFO] Excel Output Format ............................... SUCCESS [40.888s]
[INFO] Chart external graphics support ................... SUCCESS [1.866s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.416s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.858s]
[INFO] OWS request flow controller ....................... SUCCESS [31.934s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.383s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:27.021s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [27.481s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:04.605s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.799s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.279s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.137s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.024s]
[INFO] XLST based WFS output format ...................... SUCCESS [1:00.078s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [52.373s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [57.234s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.173s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.524s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.584s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:52.142s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.210s]
[INFO] DXF WFS output format ............................. SUCCESS [42.708s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [38.978s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.219s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [47.339s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [31.725s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [36.534s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.191s]
[INFO] Importer Core Module .............................. SUCCESS [1:55.175s]
[INFO] Total time: 38:00.108s (Wall Clock)
[INFO] Finished at: Sun Nov 23 09:58:54 UTC 2014
[INFO] Final Memory: 76M/218M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/917/changes&gt;
Changes:
[bradh] Update grib.rst
[...truncated 25728 lines...]
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO]
[INFO]
SimpleFeatureTypeImpl http://geotools.org:feature identified extends Feature(geometry:geometry,name:name,pop:pop)
SimpleFeatureTypeImpl http://geotools.org:feature identified extends Feature(geometry:geometry,name:name,type:type)
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
  at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
  at java.security.AccessController.doPrivileged(Native Method)
  at com.sun.media.jai.mlib.MediaLibAccessor.setUseMlib(MediaLibAccessor.java:245)
  at com.sun.media.jai.mlib.MediaLibAccessor.useMlib(MediaLibAccessor.java:177)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
  at com.sun.media.jai.mlib.MlibScaleRIF.create(MlibScaleRIF.java:67)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
  at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
  at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
  at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
  at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
  at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
  at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
  at javax.media.jai.RenderedOp.getSampleModel(RenderedOp.java:2233)
  at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.affine(GridCoverageRenderer.java:631)
  at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderCoverage(GridCoverageRenderer.java:441)
  at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:844)
  at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:743)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:854)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:336)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:258)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:130)
  at org.geoserver.wms.GetMap.executeInternal(GetMap.java:504)
  at org.geoserver.wms.GetMap.run(GetMap.java:248)
  at org.geoserver.wms.GetMap.run(GetMap.java:119)
  at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:329)
  at org.geoserver.wms.DefaultWebMapService.getMapReflect(DefaultWebMapService.java:403)
  at org.geoserver.wms.DefaultWebMapService.reflect(DefaultWebMapService.java:383)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:33)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at com.sun.proxy.$Proxy24.reflect(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:839)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:280)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1421)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1440)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1375)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:924)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:907)
  at org.geoserver.importer.ImporterTestSupport.runChecks(ImporterTestSupport.java:141)
  at org.geoserver.importer.ImporterDataTest.testImportGeoTIFF(ImporterDataTest.java:427)
Caused by: java.lang.ClassNotFoundException: com.sun.medialib.mlib.Image
  at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
  at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
  at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
  ... 100 more
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.863s]
[INFO] Core Platform Module .............................. SUCCESS [14.097s]
[INFO] Open Web Service Module ........................... SUCCESS [16.530s]
[INFO] Main Module ....................................... SUCCESS [3:19.280s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.812s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.850s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [46.676s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.672s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:14.466s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:21.257s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:07.598s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:40.223s]
[INFO] Web Map Service Module ............................ SUCCESS [7:00.497s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:28.679s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:43.569s]
[INFO] REST Support Module ............................... SUCCESS [45.217s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:14.529s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.415s]
[INFO] Core UI Module .................................... SUCCESS [2:39.663s]
[INFO] WMS UI Module ..................................... SUCCESS [1:05.015s]
[INFO] GWC UI Module ..................................... SUCCESS [1:32.400s]
[INFO] WFS UI Module ..................................... SUCCESS [46.321s]
[INFO] Demoes Module ..................................... SUCCESS [1:02.993s]
[INFO] WCS UI Module ..................................... SUCCESS [54.777s]
[INFO] Security UI Modules ............................... SUCCESS [0.283s]
[INFO] Security UI Core Module ........................... SUCCESS [3:55.677s]
[INFO] REST UI Module .................................... SUCCESS [49.193s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.126s]
[INFO] Printing Module ................................... SUCCESS [35.351s]
[INFO] Community Space ................................... SUCCESS [0.217s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.173s]
[INFO] Application Schema Support ........................ SUCCESS [0.142s]
[INFO] Application Schema Integration Test ............... FAILURE [4:25.935s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.867s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.933s]
[INFO] GeoSearch Index Module ............................ SUCCESS [40.014s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.255s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.190s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.565s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.287s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.336s]
[INFO] ImageMap Output Format ............................ SUCCESS [20.180s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.908s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.415s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.837s]
[INFO] Excel Output Format ............................... SUCCESS [40.848s]
[INFO] Chart external graphics support ................... SUCCESS [2.169s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.756s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.782s]
[INFO] OWS request flow controller ....................... SUCCESS [30.423s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.186s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:29.691s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [32.740s]
[INFO] Web Processing Service GUI ........................ SUCCESS [58.877s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.773s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.169s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.256s]
[INFO] Core Monitor Extension ............................ SUCCESS [27.024s]
[INFO] XLST based WFS output format ...................... SUCCESS [1:00.512s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [56.352s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [55.648s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.314s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.977s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.886s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:46.254s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.284s]
[INFO] DXF WFS output format ............................. SUCCESS [42.133s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [36.801s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.112s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [56.778s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [36.681s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [33.655s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.140s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Total time: 37:33.461s (Wall Clock)
[INFO] Finished at: Sun Nov 23 12:40:23 UTC 2014
[INFO] Final Memory: 75M/198M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/918/changes&gt;
Changes:
[daniele.romagnoli] [GEOS-6779]: Fixing NetCDF WCS request after fix made with GEOS-6757
[...truncated 25775 lines...]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.383 sec
  ... 100 more
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.178s]
[INFO] Core Platform Module .............................. SUCCESS [14.272s]
[INFO] Open Web Service Module ........................... SUCCESS [17.478s]
[INFO] Main Module ....................................... SUCCESS [3:29.117s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.995s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.524s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [43.052s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.080s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:11.014s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.123s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:03.401s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:41.679s]
[INFO] Web Map Service Module ............................ SUCCESS [7:03.830s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:26.695s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:45.195s]
[INFO] REST Support Module ............................... SUCCESS [44.575s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:18.472s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.573s]
[INFO] Core UI Module .................................... SUCCESS [2:30.206s]
[INFO] WMS UI Module ..................................... SUCCESS [1:06.154s]
[INFO] GWC UI Module ..................................... SUCCESS [1:33.105s]
[INFO] WFS UI Module ..................................... SUCCESS [42.108s]
[INFO] Demoes Module ..................................... SUCCESS [1:04.351s]
[INFO] WCS UI Module ..................................... SUCCESS [54.043s]
[INFO] Security UI Modules ............................... SUCCESS [0.208s]
[INFO] Security UI Core Module ........................... SUCCESS [3:49.844s]
[INFO] REST UI Module .................................... SUCCESS [44.849s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.162s]
[INFO] Printing Module ................................... SUCCESS [38.221s]
[INFO] Community Space ................................... SUCCESS [0.189s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.697s]
[INFO] Application Schema Support ........................ SUCCESS [0.165s]
[INFO] Application Schema Integration Test ............... FAILURE [4:34.335s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [36.788s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.022s]
[INFO] GeoSearch Index Module ............................ SUCCESS [41.929s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.708s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.461s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.613s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.293s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.323s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.607s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.877s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.416s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.528s]
[INFO] Excel Output Format ............................... SUCCESS [39.755s]
[INFO] Chart external graphics support ................... SUCCESS [1.288s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.839s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.158s]
[INFO] OWS request flow controller ....................... SUCCESS [30.591s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.244s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:30.383s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [23.528s]
[INFO] Web Processing Service GUI ........................ SUCCESS [57.890s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.944s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.451s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.285s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.503s]
[INFO] XLST based WFS output format ...................... SUCCESS [59.329s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [58.002s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [57.756s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.199s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.533s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.982s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:45.287s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.815s]
[INFO] DXF WFS output format ............................. SUCCESS [42.314s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [41.239s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.119s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [54.357s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.390s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [34.644s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.353s]
[INFO] Total time: 37:34.108s (Wall Clock)
[INFO] Finished at: Mon Nov 24 08:58:20 UTC 2014
[INFO] Final Memory: 75M/196M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/919/changes&gt;
Changes:
[daniele.romagnoli] [GEOS-6783]: Fixing imageLayout on coverageViewReader
[...truncated 25801 lines...]
  ... 100 more
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.716 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.226s]
[INFO] Core Platform Module .............................. SUCCESS [14.012s]
[INFO] Open Web Service Module ........................... SUCCESS [18.760s]
[INFO] Main Module ....................................... SUCCESS [3:19.972s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.942s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:18.393s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [45.987s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.906s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.412s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.638s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:08.991s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:44.571s]
[INFO] Web Map Service Module ............................ SUCCESS [7:24.705s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:25.114s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:38.343s]
[INFO] REST Support Module ............................... SUCCESS [45.414s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:13.674s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.206s]
[INFO] Core UI Module .................................... SUCCESS [2:33.491s]
[INFO] WMS UI Module ..................................... SUCCESS [1:04.232s]
[INFO] GWC UI Module ..................................... SUCCESS [1:29.083s]
[INFO] WFS UI Module ..................................... SUCCESS [46.244s]
[INFO] Demoes Module ..................................... SUCCESS [1:04.415s]
[INFO] WCS UI Module ..................................... SUCCESS [55.732s]
[INFO] Security UI Modules ............................... SUCCESS [0.289s]
[INFO] Security UI Core Module ........................... SUCCESS [3:56.550s]
[INFO] REST UI Module .................................... SUCCESS [49.233s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.152s]
[INFO] Printing Module ................................... SUCCESS [36.935s]
[INFO] Community Space ................................... SUCCESS [0.220s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.718s]
[INFO] Application Schema Support ........................ SUCCESS [0.169s]
[INFO] Application Schema Integration Test ............... FAILURE [4:26.039s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.238s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.600s]
[INFO] GeoSearch Index Module ............................ SUCCESS [40.846s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.732s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.732s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.590s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.359s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.374s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.428s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.963s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.489s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.205s]
[INFO] Excel Output Format ............................... SUCCESS [40.528s]
[INFO] Chart external graphics support ................... SUCCESS [1.824s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.036s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.793s]
[INFO] OWS request flow controller ....................... SUCCESS [30.602s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.241s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:30.176s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [26.893s]
[INFO] Web Processing Service GUI ........................ SUCCESS [57.444s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.455s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.898s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.267s]
[INFO] Core Monitor Extension ............................ SUCCESS [28.313s]
[INFO] XLST based WFS output format ...................... SUCCESS [58.590s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:01.752s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [56.433s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.207s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.783s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [31.123s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:49.058s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.198s]
[INFO] DXF WFS output format ............................. SUCCESS [43.219s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [41.505s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.209s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [56.815s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.259s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [35.019s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.274s]
[INFO] Total time: 37:49.363s (Wall Clock)
[INFO] Finished at: Tue Nov 25 15:20:30 UTC 2014
[INFO] Final Memory: 75M/210M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/920/&gt;
[...truncated 25785 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
  ... 100 more
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.788s]
[INFO] Core Platform Module .............................. SUCCESS [14.543s]
[INFO] Open Web Service Module ........................... SUCCESS [17.223s]
[INFO] Main Module ....................................... SUCCESS [3:43.391s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.338s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:20.073s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [48.330s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.451s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:13.766s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.316s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:08.944s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:42.004s]
[INFO] Web Map Service Module ............................ SUCCESS [7:26.098s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.567s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:40.471s]
[INFO] REST Support Module ............................... SUCCESS [46.400s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:18.933s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.457s]
[INFO] Core UI Module .................................... SUCCESS [2:40.095s]
[INFO] WMS UI Module ..................................... SUCCESS [1:06.332s]
[INFO] GWC UI Module ..................................... SUCCESS [1:34.680s]
[INFO] WFS UI Module ..................................... SUCCESS [42.539s]
[INFO] Demoes Module ..................................... SUCCESS [1:02.815s]
[INFO] WCS UI Module ..................................... SUCCESS [59.049s]
[INFO] Security UI Modules ............................... SUCCESS [0.264s]
[INFO] Security UI Core Module ........................... SUCCESS [3:52.777s]
[INFO] REST UI Module .................................... SUCCESS [47.312s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.155s]
[INFO] Printing Module ................................... SUCCESS [39.035s]
[INFO] Community Space ................................... SUCCESS [0.195s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.983s]
[INFO] Application Schema Support ........................ SUCCESS [0.130s]
[INFO] Application Schema Integration Test ............... FAILURE [4:27.253s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.487s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [34.409s]
[INFO] GeoSearch Index Module ............................ SUCCESS [40.434s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.863s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.534s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.767s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.465s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.676s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.082s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.129s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.642s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [34.493s]
[INFO] Excel Output Format ............................... SUCCESS [40.180s]
[INFO] Chart external graphics support ................... SUCCESS [2.875s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.230s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.897s]
[INFO] OWS request flow controller ....................... SUCCESS [27.645s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.280s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:33.779s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [23.575s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:04.632s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.250s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.784s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.205s]
[INFO] Core Monitor Extension ............................ SUCCESS [30.501s]
[INFO] XLST based WFS output format ...................... SUCCESS [56.113s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [56.246s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [57.183s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.250s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.349s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.255s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:54.479s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.290s]
[INFO] DXF WFS output format ............................. SUCCESS [41.436s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [41.798s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.113s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [56.389s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [34.196s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [34.466s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.169s]
[INFO] Total time: 38:23.600s (Wall Clock)
[INFO] Finished at: Tue Nov 25 21:22:56 UTC 2014
[INFO] Final Memory: 75M/206M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/921/changes&gt;
Changes:
[ksmith] Update Page Header for 2.7
[...truncated 26182 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Kevin Smith
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = a0d9ca9
[INFO] [GitCommitIdMojo] build.commit.id = a0d9ca95f60618de1217cb5ad88cba94d08ce2a6
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #820 from smithkm/master
Update Page Header to reflect version
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.129 sec
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.693 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.338 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.44 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.362 sec
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.856 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.213 sec
[INFO]
T E S T S
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.406 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.183 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.884 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.309 sec
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.537 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.958 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.88 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.99 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.284 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 34.202 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.483 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.84 sec
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.639s]
[INFO] Core Platform Module .............................. SUCCESS [15.849s]
[INFO] Open Web Service Module ........................... SUCCESS [15.966s]
[INFO] Main Module ....................................... SUCCESS [3:19.386s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.870s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:36.193s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:08.158s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.461s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:12.365s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.972s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:17.049s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:31.356s]
[INFO] Web Map Service Module ............................ SUCCESS [7:13.288s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:28.855s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:39.509s]
[INFO] REST Support Module ............................... SUCCESS [44.989s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:23.931s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.462s]
[INFO] Core UI Module .................................... SUCCESS [2:33.357s]
[INFO] WMS UI Module ..................................... SUCCESS [1:07.784s]
[INFO] GWC UI Module ..................................... SUCCESS [1:31.528s]
[INFO] WFS UI Module ..................................... SUCCESS [44.614s]
[INFO] Demoes Module ..................................... SUCCESS [1:00.073s]
[INFO] WCS UI Module ..................................... SUCCESS [52.851s]
[INFO] Security UI Modules ............................... SUCCESS [0.290s]
[INFO] Security UI Core Module ........................... SUCCESS [3:54.243s]
[INFO] REST UI Module .................................... SUCCESS [49.813s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.163s]
[INFO] Printing Module ................................... SUCCESS [34.928s]
[INFO] Community Space ................................... SUCCESS [0.117s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.525s]
[INFO] Application Schema Support ........................ SUCCESS [0.122s]
[INFO] Application Schema Integration Test ............... FAILURE [4:35.461s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [42.142s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.126s]
[INFO] GeoSearch Index Module ............................ SUCCESS [37.234s]
[INFO] H2 DataStore Extension ............................ SUCCESS [27.718s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.368s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.664s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.858s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.424s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.745s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.916s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.700s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.785s]
[INFO] Excel Output Format ............................... SUCCESS [41.787s]
[INFO] Chart external graphics support ................... SUCCESS [1.893s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.879s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.200s]
[INFO] OWS request flow controller ....................... SUCCESS [28.739s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.119s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:39.173s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [37.113s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:05.988s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [48.811s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.750s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [1.707s]
[INFO] Core Monitor Extension ............................ SUCCESS [27.341s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [24.368s]
[INFO] XLST based WFS output format ...................... SUCCESS [59.578s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [57.384s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [56.583s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.194s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.293s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [30.180s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:48.821s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.101s]
[INFO] DXF WFS output format ............................. SUCCESS [40.536s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [38.528s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.116s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [55.302s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.736s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [41.251s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.276s]
[INFO] Importer Core Module .............................. SUCCESS [2:02.567s]
[INFO] Total time: 39:23.867s (Wall Clock)
[INFO] Finished at: Wed Nov 26 02:03:05 UTC 2014
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/922/changes&gt;
Changes:
[andrea.aime] Fixing progress report for triple nested processes
[...truncated 26014 lines...]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixing progress report for triple nested processes
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 26.11.2014 @ 18:48:15 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 26-Nov-2014 18:48
[INFO] [GitCommitIdMojo] build.build.time = 26.11.2014 @ 19:26:11 UTC
[INFO] [GitCommitIdMojo] build.branch = 0aa033b185afad79128511fc91a6a445aedf6261
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 0aa033b
[INFO] [GitCommitIdMojo] build.commit.id = 0aa033b185afad79128511fc91a6a445aedf6261
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixing progress report for triple nested processes
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-sec-jdbc ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/src/main/resources&gt;
[INFO] Copying 7 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-sec-jdbc ---
[INFO] Compiling 8 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/classes&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.906 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.903 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-jdbc ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-sec-jdbc ---
[INFO] Compiling 13 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/test-classes&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.405 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.089 sec
Running org.geoserver.test.ValidationTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-sec-jdbc ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.web.jdbc.JDBCConnectionPanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.413 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.932 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Query:
   feature type: MappedFeatureType
   filter: [ shape intersects POLYGON ((-1.3650000000000033 52.475133749539246, -1.235000000000003 52.475133749539246, -1.235000000000003 52.52485219413131, -1.3650000000000033 52.52485219413131, -1.3650000000000033 52.475133749539246)) ]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   filter: [ shape intersects POLYGON ((-1.365 52.475, -1.235 52.475, -1.235 52.525, -1.365 52.525, -1.365 52.475)) ]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   filter: [[ shape intersects POLYGON ((-1.365 53.475, -1.235 53.475, -1.235 53.525, -1.365 53.525, -1.365 53.475)) ] AND [[ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = http://urn.opengis.net ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = a ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = b ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = c ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = d ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = e ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = f ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = g ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = h ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = i ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = j ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = k ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = l ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = m ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = n ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = o ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = p ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = q ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = r ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = S ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = t ]]]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.721 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.854 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.53 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.523 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.982 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.894 sec
Results :
Failed tests: testFilterAnd(org.geoserver.test.FeatureChainingWfsTest): expected:<[1]> but was:<[3]>
Tests run: 151, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 32.706 sec
Running org.geoserver.security.web.jdbc.group.JDBCConfirmRemovalGroupPanelTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.340s]
[INFO] Core Platform Module .............................. SUCCESS [14.687s]
[INFO] Open Web Service Module ........................... SUCCESS [16.958s]
[INFO] Main Module ....................................... SUCCESS [3:18.984s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.805s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:31.218s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [52.587s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.408s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:11.483s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.035s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:12.166s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:49.980s]
[INFO] Web Map Service Module ............................ SUCCESS [6:03.215s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:27.971s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:43.181s]
[INFO] REST Support Module ............................... SUCCESS [47.646s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:25.347s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.279s]
[INFO] Core UI Module .................................... SUCCESS [2:34.916s]
[INFO] WMS UI Module ..................................... SUCCESS [1:04.964s]
[INFO] GWC UI Module ..................................... SUCCESS [1:34.696s]
[INFO] WFS UI Module ..................................... SUCCESS [45.044s]
[INFO] Demoes Module ..................................... SUCCESS [1:01.660s]
[INFO] WCS UI Module ..................................... SUCCESS [57.240s]
[INFO] Security UI Modules ............................... SUCCESS [0.246s]
[INFO] Security UI Core Module ........................... SUCCESS [3:41.978s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [47.623s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.174s]
[INFO] Printing Module ................................... SUCCESS [39.962s]
[INFO] Community Space ................................... SUCCESS [0.294s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.215s]
[INFO] Application Schema Support ........................ SUCCESS [0.184s]
[INFO] Application Schema Integration Test ............... FAILURE [4:36.192s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.393s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.268s]
[INFO] GeoSearch Index Module ............................ SUCCESS [51.392s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.755s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.511s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.666s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.357s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.453s]
[INFO] ImageMap Output Format ............................ SUCCESS [21.887s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.062s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.509s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [31.239s]
[INFO] Excel Output Format ............................... SUCCESS [37.383s]
[INFO] Chart external graphics support ................... SUCCESS [1.819s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.185s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.827s]
[INFO] OWS request flow controller ....................... SUCCESS [31.140s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.198s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:25.555s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [27.901s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:04.702s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.622s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.910s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.364s]
[INFO] Core Monitor Extension ............................ SUCCESS [25.944s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [14.371s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [1:03.047s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [55.604s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [54.910s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.153s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.378s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.805s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:47.369s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.307s]
[INFO] DXF WFS output format ............................. SUCCESS [40.598s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [42.242s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.254s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [50.597s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.211s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [34.880s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.162s]
[INFO] Importer Core Module .............................. SUCCESS [2:00.300s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 38:11.951s (Wall Clock)
[INFO] Finished at: Wed Nov 26 19:26:58 UTC 2014
[INFO] Final Memory: 76M/203M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
See <http://ares.opengeo.org/jenkins/job/geoserver-master/923/changes&gt;
Changes:
[jody.garnett] Fix copyright in xml files
[...truncated 25989 lines...]
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO]
[INFO]
[INFO]
  ... 100 more
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.475s]
[INFO] Core Platform Module .............................. SUCCESS [15.316s]
[INFO] Open Web Service Module ........................... SUCCESS [16.739s]
[INFO] Main Module ....................................... SUCCESS [3:23.168s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.754s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:42.204s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:07.150s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.053s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:16.638s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:17.194s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:04.256s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:39.372s]
[INFO] Web Map Service Module ............................ SUCCESS [7:00.411s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.946s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:44.544s]
[INFO] REST Support Module ............................... SUCCESS [42.326s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:31.309s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.431s]
[INFO] Core UI Module .................................... SUCCESS [2:40.892s]
[INFO] WMS UI Module ..................................... SUCCESS [1:06.235s]
[INFO] GWC UI Module ..................................... SUCCESS [1:28.054s]
[INFO] WFS UI Module ..................................... SUCCESS [44.239s]
[INFO] Demoes Module ..................................... SUCCESS [1:02.057s]
[INFO] WCS UI Module ..................................... SUCCESS [57.559s]
[INFO] Security UI Modules ............................... SUCCESS [0.307s]
[INFO] Security UI Core Module ........................... SUCCESS [3:45.244s]
[INFO] REST UI Module .................................... SUCCESS [47.241s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.132s]
[INFO] Printing Module ................................... SUCCESS [34.238s]
[INFO] Community Space ................................... SUCCESS [0.111s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.693s]
[INFO] Application Schema Support ........................ SUCCESS [0.102s]
[INFO] Application Schema Integration Test ............... FAILURE [4:25.732s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.465s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.160s]
[INFO] GeoSearch Index Module ............................ SUCCESS [41.664s]
[INFO] H2 DataStore Extension ............................ SUCCESS [23.040s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.308s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.741s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.291s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.270s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.976s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.746s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.384s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.685s]
[INFO] Excel Output Format ............................... SUCCESS [40.537s]
[INFO] Chart external graphics support ................... SUCCESS [4.121s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.799s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.526s]
[INFO] OWS request flow controller ....................... SUCCESS [28.219s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.079s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:31.131s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [23.899s]
[INFO] Web Processing Service GUI ........................ SUCCESS [57.598s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.566s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.539s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.175s]
[INFO] Core Monitor Extension ............................ SUCCESS [27.085s]
[INFO] XLST based WFS output format ...................... SUCCESS [1:00.536s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [1:00.773s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [50.871s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.210s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.887s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.635s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:44.203s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.151s]
[INFO] DXF WFS output format ............................. SUCCESS [40.223s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [41.874s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.124s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [57.073s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.184s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [35.567s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.116s]
[INFO] Total time: 37:53.003s (Wall Clock)
[INFO] Finished at: Wed Nov 26 21:26:32 UTC 2014
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/924/changes&gt;
Changes:
[jody.garnett] Update instructions for running with Java 7 JRE
[jody.garnett] Update license contact details for OSGeo
[...truncated 25570 lines...]
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
  at com.sun.media.jai.mlib.MlibScaleRIF.create(MlibScaleRIF.java:67)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
  at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
  at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
  at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
  at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
  at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
  at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
  at javax.media.jai.RenderedOp.getSampleModel(RenderedOp.java:2233)
  at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.affine(GridCoverageRenderer.java:631)
  at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderCoverage(GridCoverageRenderer.java:441)
  at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:844)
  at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:743)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:854)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:336)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:258)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:130)
  at org.geoserver.wms.GetMap.executeInternal(GetMap.java:504)
  at org.geoserver.wms.GetMap.run(GetMap.java:248)
  at org.geoserver.wms.GetMap.run(GetMap.java:119)
  at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:329)
  at org.geoserver.wms.DefaultWebMapService.getMapReflect(DefaultWebMapService.java:403)
  at org.geoserver.wms.DefaultWebMapService.reflect(DefaultWebMapService.java:383)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:33)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at com.sun.proxy.$Proxy24.reflect(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:839)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:280)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1421)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1440)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1375)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:924)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:907)
  at org.geoserver.importer.ImporterTestSupport.runChecks(ImporterTestSupport.java:141)
  at org.geoserver.importer.ImporterDataTest.testImportGeoTIFF(ImporterDataTest.java:427)
Caused by: java.lang.ClassNotFoundException: com.sun.medialib.mlib.Image
  at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
  at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
  ... 100 more
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.572 sec
Results :
[INFO]
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO]
[INFO]
SimpleFeatureTypeImpl http://geotools.org:feature identified extends Feature(geometry:geometry,name:name,pop:pop)
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.685s]
[INFO] Core Platform Module .............................. SUCCESS [15.331s]
[INFO] Open Web Service Module ........................... SUCCESS [17.278s]
[INFO] Main Module ....................................... SUCCESS [3:24.065s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.828s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.591s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [47.748s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.932s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.170s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.898s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.877s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:40.004s]
[INFO] Web Map Service Module ............................ SUCCESS [7:18.034s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:22.666s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:38.821s]
[INFO] REST Support Module ............................... SUCCESS [45.563s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:11.431s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.368s]
[INFO] Core UI Module .................................... SUCCESS [2:39.188s]
[INFO] WMS UI Module ..................................... SUCCESS [1:07.289s]
[INFO] GWC UI Module ..................................... SUCCESS [1:32.521s]
[INFO] WFS UI Module ..................................... SUCCESS [43.855s]
[INFO] Demoes Module ..................................... SUCCESS [1:04.307s]
[INFO] WCS UI Module ..................................... SUCCESS [56.779s]
[INFO] Security UI Modules ............................... SUCCESS [0.167s]
[INFO] Security UI Core Module ........................... SUCCESS [3:53.313s]
[INFO] REST UI Module .................................... SUCCESS [46.086s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.211s]
[INFO] Printing Module ................................... SUCCESS [45.938s]
[INFO] Community Space ................................... SUCCESS [0.271s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.705s]
[INFO] Application Schema Support ........................ SUCCESS [0.159s]
[INFO] Application Schema Integration Test ............... FAILURE [4:29.547s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.965s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [35.808s]
[INFO] GeoSearch Index Module ............................ SUCCESS [37.630s]
[INFO] H2 DataStore Extension ............................ SUCCESS [26.478s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.352s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.032s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.343s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.477s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.628s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.014s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.471s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [40.746s]
[INFO] Excel Output Format ............................... SUCCESS [39.271s]
[INFO] Chart external graphics support ................... SUCCESS [1.834s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.402s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.312s]
[INFO] OWS request flow controller ....................... SUCCESS [30.139s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.106s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:36.314s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [34.773s]
[INFO] Web Processing Service GUI ........................ SUCCESS [59.616s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.547s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [6.555s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.206s]
[INFO] Core Monitor Extension ............................ SUCCESS [31.241s]
[INFO] XLST based WFS output format ...................... SUCCESS [1:01.662s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [57.738s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [52.040s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.436s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [25.754s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.742s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:46.420s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.275s]
[INFO] DXF WFS output format ............................. SUCCESS [41.182s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [43.455s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.100s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [54.926s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [32.953s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [36.288s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.352s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Total time: 38:00.167s (Wall Clock)
[INFO] Finished at: Wed Nov 26 22:04:51 UTC 2014
[INFO] Final Memory: 75M/213M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/925/changes&gt;
Changes:
[jody.garnett] highlight github quickfix
[jody.garnett] update license information in developer guide
[jody.garnett] Use release license files for user docs.
[jody.garnett] Update tools for Java 7, Git and Maven
[...truncated 26013 lines...]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.572 sec
Running org.geoserver.test.RestconfigWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.289 sec
Running org.geoserver.test.SRSReprojectionTest
[INFO]
[INFO]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.779 sec
Running org.geoserver.test.SRSWfsTest
[INFO]
T E S T S
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.203 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.5 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.36 sec
Running org.geoserver.test.SecuredFeatureChainingTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.262 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.339 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.706 sec
Running org.geoserver.test.StringConstantIdWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.482 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.022 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.605 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.268 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 31.557 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.067 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.86 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.789 sec
Running org.geoserver.security.web.jdbc.group.JDBCEditGroupPageTest
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.157 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.253 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.441 sec
Running org.geoserver.security.web.jdbc.group.JDBCGroupListPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.347 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.544 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.393 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.391 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.241 sec
Running org.geoserver.security.web.jdbc.group.JDBCNewGroupPageTest
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.174s]
[INFO] Core Platform Module .............................. SUCCESS [15.692s]
[INFO] Open Web Service Module ........................... SUCCESS [17.581s]
[INFO] Main Module ....................................... SUCCESS [3:18.012s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.711s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:20.331s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [48.559s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.229s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:15.190s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.601s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:06.926s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:48.205s]
[INFO] Web Map Service Module ............................ SUCCESS [6:56.029s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:27.294s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:34.668s]
[INFO] REST Support Module ............................... SUCCESS [49.283s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:18.962s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.336s]
[INFO] Core UI Module .................................... SUCCESS [2:40.521s]
[INFO] WMS UI Module ..................................... SUCCESS [1:05.929s]
[INFO] GWC UI Module ..................................... SUCCESS [1:31.975s]
[INFO] WFS UI Module ..................................... SUCCESS [43.382s]
[INFO] Demoes Module ..................................... SUCCESS [1:00.124s]
[INFO] WCS UI Module ..................................... SUCCESS [55.801s]
[INFO] Security UI Modules ............................... SUCCESS [0.365s]
[INFO] Security UI Core Module ........................... SUCCESS [3:49.317s]
[INFO] REST UI Module .................................... SUCCESS [46.904s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.178s]
[INFO] Printing Module ................................... SUCCESS [34.766s]
[INFO] Community Space ................................... SUCCESS [0.194s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.074s]
[INFO] Application Schema Support ........................ SUCCESS [0.136s]
[INFO] Application Schema Integration Test ............... FAILURE [4:33.585s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.523s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [33.467s]
[INFO] GeoSearch Index Module ............................ SUCCESS [42.330s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.561s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.274s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.621s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.289s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.563s]
[INFO] ImageMap Output Format ............................ SUCCESS [19.129s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.017s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.451s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.647s]
[INFO] Excel Output Format ............................... SUCCESS [40.252s]
[INFO] Chart external graphics support ................... SUCCESS [2.448s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.998s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.100s]
[INFO] OWS request flow controller ....................... SUCCESS [31.525s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.206s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:34.674s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [21.482s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:05.871s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.486s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.443s]
[INFO] Core Monitor Extension ............................ SUCCESS [27.032s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [17.087s]
[INFO] XLST based WFS output format ...................... SUCCESS [59.795s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [59.367s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [53.148s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.347s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.646s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.697s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:44.992s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.386s]
[INFO] DXF WFS output format ............................. SUCCESS [42.989s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [42.941s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.186s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [55.950s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [36.013s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [39.077s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.426s]
[INFO] Importer Core Module .............................. SUCCESS [2:01.192s]
[INFO] Total time: 38:45.083s (Wall Clock)
[INFO] Finished at: Thu Nov 27 00:02:25 UTC 2014
[INFO] Final Memory: 76M/204M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/926/changes&gt;
