See <http://ares.opengeo.org/jenkins/job/geoserver-master/941/changes>
Changes:
[alex3305] [GEOS-6785]WCS GetCapabilities 1.1.1 has invalid metadataType attribute
[...truncated 26025 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.test.SpecimenWfsTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-jdbc ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-sec-jdbc ---
[INFO] Compiling 13 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/test-classes>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.136 sec
Running org.geoserver.test.StringConstantIdWfsTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-sec-jdbc ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/security/jdbc/target/surefire-reports>
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.341 sec
Running org.geoserver.test.SubstitutionGroupTest
Running org.geoserver.security.web.jdbc.JDBCConnectionPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.245 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.027 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.916 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.892 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.745 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Query:
feature type: MappedFeatureType
filter: [ shape intersects POLYGON ((-1.3650000000000033 52.475133749539246, -1.235000000000003 52.475133749539246, -1.235000000000003 52.52485219413131, -1.3650000000000033 52.52485219413131, -1.3650000000000033 52.475133749539246)) ]
[properties: ALL ]
Query:
[properties: ALL ]
Query:
filter: [ shape intersects POLYGON ((-1.365 52.475, -1.235 52.475, -1.235 52.525, -1.365 52.525, -1.365 52.475)) ]
[properties: ALL ]
Query:
[properties: ALL ]
Query:
filter: [[ shape intersects POLYGON ((-1.365 53.475, -1.235 53.475, -1.235 53.525, -1.365 53.525, -1.365 53.475)) ] AND [[ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = http://urn.opengis.net ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = a ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = b ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = c ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = d ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = e ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = f ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = g ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = h ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = i ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = j ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = k ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = l ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = m ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = n ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = o ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = p ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = q ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = r ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = S ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = t ]]]
[properties: ALL ]
Query:
[properties: ALL ]
Query:
[properties: ALL ]
Query:
[properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.685 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.559 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.424 sec
Running org.geoserver.test.XYGeomTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 34.736 sec
Running org.geoserver.security.web.jdbc.group.JDBCConfirmRemovalGroupPanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.649 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.289 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.745 sec
Results :
Failed tests: testAttributeFilter(org.geoserver.test.SimpleAttributeFeatureChainWfsTest): expected:<[1]> but was:<[0]>
testClientPropertiesFilter(org.geoserver.test.SimpleAttributeFeatureChainWfsTest): expected:<[1]> but was:<[0]>
Tests run: 151, Failures: 2, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.208 sec
Running org.geoserver.security.web.jdbc.group.JDBCEditGroupPageTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.282s]
[INFO] Core Platform Module .............................. SUCCESS [15.812s]
[INFO] Open Web Service Module ........................... SUCCESS [16.770s]
[INFO] Main Module ....................................... SUCCESS [3:17.937s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.626s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:20.410s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [45.801s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.905s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:06.094s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.571s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:06.454s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:55.603s]
[INFO] Web Map Service Module ............................ SUCCESS [6:38.588s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:32.759s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:36.865s]
[INFO] REST Support Module ............................... SUCCESS [46.015s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:33.409s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.303s]
[INFO] Core UI Module .................................... SUCCESS [2:33.105s]
[INFO] WMS UI Module ..................................... SUCCESS [1:12.505s]
[INFO] GWC UI Module ..................................... SUCCESS [1:32.055s]
[INFO] WFS UI Module ..................................... SUCCESS [45.491s]
[INFO] Demoes Module ..................................... SUCCESS [1:02.756s]
[INFO] WCS UI Module ..................................... SUCCESS [52.316s]
[INFO] Security UI Modules ............................... SUCCESS [0.281s]
[INFO] Security UI Core Module ........................... SUCCESS [3:52.655s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [50.434s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.215s]
[INFO] Printing Module ................................... SUCCESS [37.649s]
[INFO] Community Space ................................... SUCCESS [0.156s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.856s]
[INFO] Application Schema Support ........................ SUCCESS [0.122s]
[INFO] Application Schema Integration Test ............... FAILURE [4:25.338s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.855s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [31.640s]
[INFO] GeoSearch Index Module ............................ SUCCESS [47.937s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.915s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.243s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.646s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.335s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.314s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.068s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.903s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.490s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.086s]
[INFO] Excel Output Format ............................... SUCCESS [41.865s]
[INFO] Chart external graphics support ................... SUCCESS [2.611s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.620s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.844s]
[INFO] OWS request flow controller ....................... SUCCESS [31.684s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.375s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:27.457s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [27.781s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:05.646s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.859s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.202s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.318s]
[INFO] Core Monitor Extension ............................ SUCCESS [26.429s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [1:00.999s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [54.113s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [52.322s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.284s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.177s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [29.123s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:54.252s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.238s]
[INFO] DXF WFS output format ............................. SUCCESS [42.911s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [41.541s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.214s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [53.261s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [33.839s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [36.932s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.254s]
[INFO] Importer Core Module .............................. SUCCESS [1:51.671s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 38:21.277s (Wall Clock)
[INFO] Finished at: Mon Dec 08 09:57:05 UTC 2014
[INFO] Final Memory: 75M/210M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
