See <http://ares.opengeo.org/jenkins/job/geoserver-master/947/>
[...truncated 20381 lines...]
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota-jdbc/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-diskquota-jdbc/1.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota-jdbc/1.7-SNAPSHOT/maven-metadata.xml (2 KB at 105.9 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-diskquota/1.7-SNAPSHOT/maven-metadata.xml
803/803 B
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota/1.7-SNAPSHOT/maven-metadata.xml (803 B at 71.3 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota-core/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://repository.codehaus.org/org/geowebcache/gwc-diskquota-core/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-diskquota-core/1.7-SNAPSHOT/maven-metadata.xml
Downloading: http://download.oracle.com/maven/org/geowebcache/gwc-diskquota-core/1.7-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota-core/1.7-SNAPSHOT/maven-metadata.xml (2 KB at 83.2 KB/sec)
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.778 sec
Running org.geoserver.wps.RawInputOutputTest
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-wmts/1.7-SNAPSHOT/gwc-wmts-1.7-20141209.214338-10.jar
1/20 KB
5/20 KB
9/20 KB
13/20 KB
17/20 KB
20/20 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-wmts/1.7-SNAPSHOT/gwc-wmts-1.7-20141209.214338-10.jar (20 KB at 1281.7 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-gwc ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/gwc/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-gwc ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #846 from Geodan/GEOS-6688-2
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 08.12.2014 @ 20:20:05 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 09-Dec-2014 21:44
[INFO] [GitCommitIdMojo] build.build.time = 09.12.2014 @ 22:05:51 UTC
[INFO] [GitCommitIdMojo] build.branch = c42f9cd33044dec6968e3ccced3ea96c9ca04f81
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = c42f9cd
[INFO] [GitCommitIdMojo] build.commit.id = c42f9cd33044dec6968e3ccced3ea96c9ca04f81
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #846 from Geodan/GEOS-6688-2
[GEOS-6688] Addition to support more interpolation types.
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gwc ---
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc ---
[INFO] Compiling 40 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/gwc/target/classes>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.549 sec
Running org.geoserver.wps.ResourceAccessManagerWPSTest
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java>:\[83,7\] error: GeoServerTileLayer is not abstract and does not override abstract method setTransientLayer(boolean) in TileLayer
[INFO] 1 error
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping GeoSearch Index Module
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.706 sec
Running org.geoserver.wps.SnapTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.344s]
[INFO] Core Platform Module .............................. SUCCESS [15.893s]
[INFO] Open Web Service Module ........................... SUCCESS [17.942s]
[INFO] Main Module ....................................... SUCCESS [3:16.449s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.913s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:33.573s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:20.215s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.231s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [53.268s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:26.347s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:17.705s]
[INFO] Web Feature Service Module ........................ SUCCESS [5:23.431s]
[INFO] Web Map Service Module ............................ SUCCESS [6:35.074s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:32.197s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [12.366s]
[INFO] REST Support Module ............................... SUCCESS [48.595s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.294s]
[INFO] Core UI Module .................................... SUCCESS [2:44.994s]
[INFO] WFS UI Module ..................................... SUCCESS [44.080s]
[INFO] Security UI Modules ............................... SUCCESS [0.284s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.170s]
[INFO] Printing Module ................................... SUCCESS [45.046s]
[INFO] Community Space ................................... SUCCESS [0.127s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.353s]
[INFO] Application Schema Support ........................ SUCCESS [0.124s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [41.178s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.964s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.511s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.302s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.685s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.305s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.300s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.989s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.525s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.979s]
[INFO] Excel Output Format ............................... SUCCESS [38.014s]
[INFO] Chart external graphics support ................... SUCCESS [1.887s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.332s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.811s]
[INFO] OWS request flow controller ....................... SUCCESS [33.457s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.200s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [49.497s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.855s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.259s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [59.201s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.140s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.362s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.673s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.134s]
[INFO] DXF WFS output format ............................. SUCCESS [36.021s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.175s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 21:59.274s (Wall Clock)
[INFO] Finished at: Tue Dec 09 22:06:05 UTC 2014
[INFO] Final Memory: 61M/178M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
