See <http://ares.opengeo.org/jenkins/job/geoserver-master/952/changes>
Changes:
[maurobartolomeoli] GEOS-6800: sldService community module improvements
Started by an SCM change
Started by upstream project "geotools-master" build number 465
originally caused by:
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/>
Checkout:geoserver-master / <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/> - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 4a9d218fd205107e808011c96083cd2f04bf1b22 (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
Commencing build of Revision 7a22b6a173ea31cb7462bad425a0d31f0c06c300 (origin/master)
Checking out Revision 7a22b6a173ea31cb7462bad425a0d31f0c06c300 (origin/master)
[geoserver-master] $ /opt/apache-maven-3.0.4/bin/mvn -f src/pom.xml -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,proxy,printing,secJdbcJndiTest clean install -DconfigDirectory=../../../data -T2
[INFO] Scanning for projects...
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project org.geoserver.web:gs-web-app:2.7-SNAPSHOT (<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/app/pom.xml)> has 1 error
[ERROR] 'profiles.profile.id' must be unique but found duplicate profile with id sldService @ line 1214, column 11
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
