Hudson
January 26, 2018, 8:40pm
1
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1055/display/redirect?page=changes> ;
Changes:
[Brad Hards] [GEOS-8541] Fix ground overlay east/west swap.
[Daniele Romagnoli] GEOS-8548: Output bbox on each CRS on LayerGroups too
[Jody Garnett] fixing broken links and formatting issues
[tbarsballe] Use repo.maven.com instead of archive.apache.org to get mvn for Travis
Started by timer
Building remotely on apollo-slave-02 in workspace <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/> ;
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision a679158b13df4aaee08709fc6890ac61f8685cb4 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f a679158b13df4aaee08709fc6890ac61f8685cb4
> git rev-list 0315d231a804abb7a0b9593ef20f63aa914c8ac2 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins6364087923245017470.sh
+ mkdir /var/jenkins/.geoserver
mkdir: cannot create directory `/var/jenkins/.geoserver': File exists
+ true
+ rm /var/jenkins/.geotools/postgis.properties
+ rm /var/jenkins/.geotools/oracle.properties
rm: cannot remove `/var/jenkins/.geotools/oracle.properties': No such file or directory
+ true
+ rm /var/jenkins/.geoserver/postgis.properties
+ rm /var/jenkins/.geoserver/oracle.properties
rm: cannot remove `/var/jenkins/.geoserver/oracle.properties': No such file or directory
+ true
+ set +x
psql: could not connect to server: Connection timed out
Is the server running on host "184.154.70.224" and accepting
TCP/IP connections on port 5432?
Build step 'Execute shell' marked build as failure
Hudson
January 27, 2018, 8:40pm
2
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1056/display/redirect?page=changes> ;
Changes:
[tbarsballe] [GEOS-8366] fix bug adding a new GeoPackage datastore from within the
[Jody Garnett] [GEOS-8479] Update doc links to point to build.geoserver.org
[Andrea Aime] [GEOS-8546] Location picker displays null instead of Data Directory
[Andrea Aime] [GEOS-8531] GeoServer code still uses DataUtilities.urlToFile/fileToUrl
[Andrea Aime] [GEOS-8554] Installing the XSLT plugin may cause random REST endpoints
Started by timer
Checking out Revision 6ce9cd34dfd636889c451ace2364ecd85e68e3c2 (origin/master)
> git checkout -f 6ce9cd34dfd636889c451ace2364ecd85e68e3c2
> git rev-list a679158b13df4aaee08709fc6890ac61f8685cb4 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins5794324702867270352.sh
+ true
+ true
+ true
+ set +x
Hudson
January 28, 2018, 8:40pm
3
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1057/display/redirect> ;
Started by timer
> git rev-list 6ce9cd34dfd636889c451ace2364ecd85e68e3c2 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins1482119634768997798.sh
+ true
+ true
+ true
+ set +x
Hudson
January 29, 2018, 8:40pm
4
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1058/display/redirect?page=changes> ;
Changes:
[Andrea Aime] Add nicer extensions for downloaded images in DownloadMap
[Andrea Aime] Use new extension method
[github] [GEOS-4339][GEOS-5356][GEOS-7942] REST API - Use prefixed layer names
Started by timer
Checking out Revision 53ae0c38a1707b7632e846f160d101893fd4c686 (origin/master)
> git checkout -f 53ae0c38a1707b7632e846f160d101893fd4c686
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins8410765094969714505.sh
+ true
+ true
+ true
+ set +x
Torben and Nick,
Boundless Jenkins geoserver-master-app-schema-online fails to connect to postgres. Any ideas what might be causing this?
Kind regards,
Ben.
-------- Forwarded Message --------
Subject: [Geoserver-devel] Build failed in Jenkins: geoserver-master-app-schema-online #1058
Date: Mon, 29 Jan 2018 20:40:04 +0000 (UTC)
To: geoserver-devel@lists.sourceforge.net
Changes:
Started by timer
+ true
+ true
+ true
+ set +x
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/> ;
New Zealand
Hudson
January 30, 2018, 8:40pm
6
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1059/display/redirect?page=changes> ;
Changes:
[Alessio Fabiani] [GeoServerOAuthAuthenticationFilter] - OAuth2 Roles Computation
[mjmcee] [GEOS-8556] Add option to copy global attributes from NetCDF/GRIB
[Ben Caradoc-Davies] Document global attribute source for NetCDF output from ImageMosaic
Started by timer
Checking out Revision 9e0e09291ba0da390ea1e2c19ec6da6b59a813b4 (origin/master)
> git checkout -f 9e0e09291ba0da390ea1e2c19ec6da6b59a813b4
> git rev-list 53ae0c38a1707b7632e846f160d101893fd4c686 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins5410157768722303392.sh
+ true
+ true
+ true
+ set +x
Hudson
January 31, 2018, 8:40pm
7
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1060/display/redirect> ;
Started by timer
> git rev-list 9e0e09291ba0da390ea1e2c19ec6da6b59a813b4 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins6722381872976820969.sh
+ true
+ true
+ true
+ set +x
Hi Ben
It appears the database server is offline.
Nick is away the latter half of this week, we’ll try to look into this further on Monday.
Torben
On Tue, Jan 30, 2018 at 11:39 AM, Ben Caradoc-Davies <ben@anonymised.com > wrote:
Torben and Nick,
Kind regards,
Ben.
To: geoserver-devel@anonymised.comrge.net
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1058/display/redirect?page=changes >
Changes:
Started by timer
Building remotely on apollo-slave-02 in workspace <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/ >
git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/:refs/remotes/origin/
mkdir: cannot create directory `/var/jenkins/.geoserver’: File exists
true
rm: cannot remove `/var/jenkins/.geotools/oracle.properties’: No such file or directory
true
rm: cannot remove `/var/jenkins/.geoserver/oracle.properties’: No such file or directory
true
set +x
Is the server running on host “184.154.70.224” and accepting
Build step ‘Execute shell’ marked build as failure
engaging tech sites, Slashdot.org ! http://sdm.link/slashdot
Geoserver-devel@anonymised.comrge.net
Director
Transient Software Limited <https://transient.nz/ >
New Zealand
Thanks, Torben. Much appreciated. I ran the app-schema online tests locally and they still pass.
Kind regards,
Ben.
On 02/02/18 08:12, Torben Barsballe wrote:
Hi Ben
Nick is away the latter half of this week, we'll try to look into this
further on Monday.
Torben
On Tue, Jan 30, 2018 at 11:39 AM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:
Torben and Nick,
Kind regards,
Ben.
Changes:
names
Started by timer
# timeout=10
(origin/master)
+ true
file or directory
+ true
file or directory
+ true
+ set +x
Director
New Zealand
Director
New Zealand
Excellent, good to hear that they still pass.
Torben
On Thu, Feb 1, 2018 at 11:30 AM, Ben Caradoc-Davies <ben@anonymised.com > wrote:
Kind regards,
Ben.
Hi Ben
further on Monday.
Torben
wrote:
Torben and Nick,
Kind regards,
Ben.
Changes:
names
Started by timer
timeout=10
(origin/master)
true
file or directory
true
file or directory
true
set +x
Director
New Zealand
Director
New Zealand
Hudson
February 1, 2018, 8:47pm
11
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1061/display/redirect> ;
Started by timer
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins5278677534292892143.sh
+ true
+ true
+ true
+ set +x
Hudson
February 2, 2018, 8:40pm
12
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1062/display/redirect?page=changes> ;
Changes:
[Andrea Aime] Allow overriding base parameters (including time) in DownloadMap
Started by timer
Checking out Revision 2ece5fd76010a0f57d6f9edce1e250411fba13fa (origin/master)
> git checkout -f 2ece5fd76010a0f57d6f9edce1e250411fba13fa
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins6968549210979273953.sh
+ true
+ true
+ true
+ set +x
Hudson
February 3, 2018, 8:40pm
13
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1063/display/redirect?page=changes> ;
Changes:
[tbarsballe] [GEOS-8255] Fix serialization of brute force whitelist mask
Started by timer
Checking out Revision 0a3d14b7df2cdc8f49e8ac04da8b7c248eaf001d (origin/master)
> git checkout -f 0a3d14b7df2cdc8f49e8ac04da8b7c248eaf001d
> git rev-list 2ece5fd76010a0f57d6f9edce1e250411fba13fa # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins8463142952387734317.sh
+ true
+ true
+ true
+ set +x
Hudson
February 4, 2018, 8:40pm
14
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1064/display/redirect> ;
Started by timer
> git rev-list 0a3d14b7df2cdc8f49e8ac04da8b7c248eaf001d # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins7650320240453478012.sh
+ true
+ true
+ true
+ set +x
Hudson
February 5, 2018, 8:40pm
15
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1065/display/redirect> ;
Started by timer
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins5155862038828104548.sh
+ true
+ true
+ true
+ set +x
Hudson
February 6, 2018, 8:34pm
16
Thanks very much. The build is now fixed.
Kind regards,
Ben.
Hi Ben
further on Monday.
Torben
wrote:
Torben and Nick,
Kind regards,
Ben.
Changes:
names
Started by timer
# timeout=10
(origin/master)
+ true
file or directory
+ true
file or directory
+ true
+ set +x
Director
New Zealand
Director
New Zealand
