Changes:
[Alessio Fabiani] Log level to FINEST
[Andrea Aime] [GEOS-8638] WFS join with ValueReference using local namespaces fail to
[Andrea Aime] [GEOS-8657] GeoServer in CITE compliance mode fails to validate an
[Andrea Aime] [GEOS-8646], some fixes to UI and labels
[github] [GEOS-8652] WMTS multidimensional histogram calculation failures
[...truncated 264.94 KB...]
testQuantityListSubset(org.geoserver.test.TimeSeriesInlineWfsTest) Time elapsed: 79 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
at org.junit.Assert.assertEquals(Assert.java:115)
at org.junit.Assert.assertEquals(Assert.java:144)
at org.geoserver.test.TimeSeriesInlineWfsTest.testQuantityListSubset(TimeSeriesInlineWfsTest.java:119)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 3.8 sec <<< FAILURE!
testQuantityListSubset(org.geoserver.test.TimeSeriesWfsTest) Time elapsed: 79 sec <<< FAILURE!
at org.geoserver.test.TimeSeriesWfsTest.testQuantityListSubset(TimeSeriesWfsTest.java:240)
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.497 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 3.812 sec <<< FAILURE!
testTimePositionSubset(org.geoserver.test.WaterMLTimeSeriesWfsTest) Time elapsed: 3505 sec <<< FAILURE!
at org.geoserver.test.WaterMLTimeSeriesWfsTest.testTimePositionSubset(WaterMLTimeSeriesWfsTest.java:170)
testFilter(org.geoserver.test.WaterMLTimeSeriesWfsTest) Time elapsed: 48 sec <<< FAILURE!
at org.geoserver.test.WaterMLTimeSeriesWfsTest.testFilter(WaterMLTimeSeriesWfsTest.java:115)
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.599 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.764 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.891 sec
Running org.geoserver.test.XPathPredicateTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.104 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.416 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.573 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.79 sec
Running org.geoserver.test.web.Gml311LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.763 sec
Running org.geoserver.test.web.Gml32LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.455 sec
Results :
Failed tests: testQueryBboxLatLongPost(org.geoserver.test.BBoxFilterTest): expected:<[2]> but was:<>
testFilter(org.geoserver.test.CSVOutputFormatTest): expected:<[text/csv]> but was:<[application/xml]>
testFilteringNestedMultiValuedAttribute(org.geoserver.test.FeatureChainingWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testFilteringXlinkHref(org.geoserver.test.FeatureChainingWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testFilterAnd(org.geoserver.test.FeatureChainingWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testGetFeaturePropertyFilter(org.geoserver.test.FeatureChainingWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testNestedIdInlineMapping(org.geoserver.test.NestedIdSupportTest): expected:<1> but was:<0>
testNestedIdFeatureChaining(org.geoserver.test.NestedIdSupportTest): expected:<1> but was:<0>
testTimePositionSubset(org.geoserver.test.Observation_2_0_WfsTest): expected:<1> but was:<0>
testGetFeatureWithFilter(org.geoserver.test.PagingTest): expected:<1> but was:<0>
testGetFeatureWithNestedFilter(org.geoserver.test.PagingTest): expected:<1> but was:<0>
testFirstValueFilters(org.geoserver.test.PolymorphismWfsTest): expected:<[1]> but was:<>
testAnyTypeFilters(org.geoserver.test.PolymorphismWfsTest): expected:<[2]> but was:<>
testSecondValueFilters(org.geoserver.test.PolymorphismWfsTest): expected:<[2]> but was:<>
testMappingNameFilters(org.geoserver.test.PolymorphismWfsTest): expected:<[2]> but was:<>
testPostGetFeature(org.geoserver.test.PropertySelectionTest): expected:<2> but was:<0>
testAttributeFilter(org.geoserver.test.SimpleAttributeFeatureChainWfsTest): expected:<[1]> but was:<>
testClientPropertiesFilter(org.geoserver.test.SimpleAttributeFeatureChainWfsTest): expected:<[1]> but was:<>
testTimePositionSubset(org.geoserver.test.TimeSeriesInlineWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testQuantityListSubset(org.geoserver.test.TimeSeriesInlineWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testQuantityListSubset(org.geoserver.test.TimeSeriesWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testTimePositionSubset(org.geoserver.test.WaterMLTimeSeriesWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testFilter(org.geoserver.test.WaterMLTimeSeriesWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
Tests run: 208, Failures: 23, Errors: 0, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 2.772 s]
[INFO] Application Schema Integration Test ................ FAILURE [26:41 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.759 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [05:44 min]
[INFO] BUILD FAILURE
[INFO] Total time: 32:38 min
[INFO] Finished at: 2018-03-21T21:45:34+00:00
[INFO] Final Memory: 55M/331M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-postgis-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
