[Geoserver-devel] Build failed in Jenkins: geoserver-master-app-schema-online #1143
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1143/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Windows Installation issue - upgrading GeoServer results in corrupt
[Andrea Aime] [Issue GEOS-8683] Windows Installation issue - upgrading GeoServer
[Andrea Aime] [GEOS-8697] Remove language warnings during Windows setup compilation
[Andrea Aime] [GEOS-8698] Windows Installer: Remove 'work' folder when uninstalling
[Andrea Aime] [GEOS-8712] GeoServer Developer documentation contains invalid links to
[Jody Garnett] Create branch and start adapting code to the new JSR363 API
[Jody Garnett] Capture also parse exception
[Jody Garnett] Restore ConversionException where needed
[...truncated 92.86 KB...]
T E S T S
Running org.geoserver.test.BBox3DTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.636 sec
Running org.geoserver.test.BBoxFilterTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.49 sec
Running org.geoserver.test.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.375 sec
Running org.geoserver.test.ConnectionUsageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.782 sec
Running org.geoserver.test.DefaultIdTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.742 sec
Running org.geoserver.test.DuplicatePropertiesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.953 sec
Running org.geoserver.test.DuplicateTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.622 sec
Running org.geoserver.test.EncodeIfEmptyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.979 sec
Running org.geoserver.test.FeatureChainingSharedConnectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.189 sec
Running org.geoserver.test.FeatureChainingWfsTest
Tests run: 33, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 23.38 sec
Running org.geoserver.test.FeatureGML32Test
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.428 sec
Running org.geoserver.test.GUChainNoIDMFTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.757 sec
Running org.geoserver.test.GetPropertyValueTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.106 sec
Running org.geoserver.test.Gsml30WfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.526 sec
Running org.geoserver.test.Gsml32BoreholeIntervalWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.836 sec
Running org.geoserver.test.Gsml32BoreholeWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.919 sec
Running org.geoserver.test.IdFunctionWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.058 sec
Running org.geoserver.test.IdFunctionWfsWithJoiningTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.734 sec
Running org.geoserver.test.IdNotEncodedTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.742 sec
Running org.geoserver.test.InvalidColumnTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.556 sec
Running org.geoserver.test.IsolatedNamespacesWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.406 sec
Running org.geoserver.test.LocalResolveFeatureChainingByRefTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.04 sec
Running org.geoserver.test.LocalResolveTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.713 sec
Running org.geoserver.test.MappingNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.517 sec
Running org.geoserver.test.MeasureTypeBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.633 sec
Running org.geoserver.test.MultivaluedXlinkHrefTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.786 sec
Running org.geoserver.test.NamespacesWfsTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.062 sec
Running org.geoserver.test.NestedIdSupportTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.76 sec
Running org.geoserver.test.Observation_2_0_WfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.66 sec
Running org.geoserver.test.PagingTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.055 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.824 sec
Running org.geoserver.test.PolymorphismWfsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.124 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.348 sec
Running org.geoserver.test.PropertySelectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.025 sec
Running org.geoserver.test.Reprojection3DTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.447 sec
Running org.geoserver.test.RestconfigWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.44 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.158 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.7 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.007 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.68 sec
Running org.geoserver.test.SecuredFeatureChainingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.665 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.523 sec
Running org.geoserver.test.SortByTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.747 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.765 sec
Running org.geoserver.test.StringConstantIdWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.195 sec
Running org.geoserver.test.SubstitutionGroupCoverageWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.906 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.779 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.134 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.906 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.918 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.986 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 6, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 11.061 sec <<< FAILURE!
testGetFeatureInfoGMLReprojection(org.geoserver.test.WmsGetFeatureInfoTest) Time elapsed: 6027 sec <<< FAILURE!
java.lang.AssertionError: expected:<1> but was:<0>
  at org.junit.Assert.fail(Assert.java:88)
  at org.junit.Assert.failNotEquals(Assert.java:743)
  at org.junit.Assert.assertEquals(Assert.java:118)
  at org.junit.Assert.assertEquals(Assert.java:555)
  at org.junit.Assert.assertEquals(Assert.java:542)
  at org.geoserver.test.AbstractAppSchemaTestSupport.assertXpathCount(AbstractAppSchemaTestSupport.java:372)
  at org.geoserver.test.WmsGetFeatureInfoTest.testGetFeatureInfoGMLReprojection(WmsGetFeatureInfoTest.java:75)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.519 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 5, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 7.917 sec <<< FAILURE!
testGetMapOutcropCharacterReprojection(org.geoserver.test.WmsGetMapTest) Time elapsed: 8 sec <<< ERROR!
java.lang.NullPointerException
  at org.geoserver.test.AbstractAppSchemaTestSupport.countNonBlankPixels(AbstractAppSchemaTestSupport.java:577)
  at org.geoserver.test.AbstractAppSchemaTestSupport.assertNotBlank(AbstractAppSchemaTestSupport.java:557)
  at org.geoserver.test.WmsGetMapTest.testGetMapOutcropCharacterReprojection(WmsGetMapTest.java:55)
Running org.geoserver.test.XPathPredicateTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.595 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.528 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.584 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.879 sec
Running org.geoserver.test.web.Gml311LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.554 sec
Running org.geoserver.test.web.Gml32LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.925 sec
Results :
Failed tests: testGetFeatureInfoGMLReprojection(org.geoserver.test.WmsGetFeatureInfoTest): expected:<1> but was:<0>
Tests in error:
Tests run: 208, Failures: 1, Errors: 1, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 2.986 s]
[INFO] Application Schema Integration Test ................ FAILURE [42:26 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.416 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [05:56 min]
[INFO] BUILD FAILURE
[INFO] Total time: 48:34 min
[INFO] Finished at: 2018-04-23T21:27:43+00:00
[INFO] Final Memory: 55M/297M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-postgis-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1144/display/redirect?page=changes&gt;
