Changes:
[Alessio Fabiani] [GSIP-169] WPS Extension GetExecutions Operation
[Alessio Fabiani] - Fixes as per @aaime review
[Andrea Aime] [GEOS-8943] File chooser autocomplete list might contain duplicate
[github] [GEOS-8882] Add integration tests for App-Schema JDBC and Solr
[...truncated 138.84 KB...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
testGetFilteredNormalizedMultiValuesWfs20(org.geoserver.test.NormalizedMultiValuesTest) Time elapsed: 20 sec <<< FAILURE!
java.lang.AssertionError:
Expected: is <1>
but: was <0>
at org.hamcrest.MatcherAssert.assertThat(MatcherAssert.java:20)
at org.hamcrest.MatcherAssert.assertThat(MatcherAssert.java:8)
at org.geoserver.test.NormalizedMultiValuesTest.checkCount(NormalizedMultiValuesTest.java:401)
at org.geoserver.test.NormalizedMultiValuesTest.checkStation1Gml32(NormalizedMultiValuesTest.java:302)
at org.geoserver.test.NormalizedMultiValuesTest.testGetFilteredNormalizedMultiValuesWfs20(NormalizedMultiValuesTest.java:202)
Running org.geoserver.test.Observation_2_0_WfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.839 sec
Running org.geoserver.test.PagingTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.957 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.604 sec
Running org.geoserver.test.PolymorphismWfsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.381 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.773 sec
Running org.geoserver.test.PropertySelectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.237 sec
Running org.geoserver.test.Reprojection3DTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.436 sec
Running org.geoserver.test.RestconfigWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.565 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.261 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.615 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.049 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.592 sec
Running org.geoserver.test.SecuredFeatureChainingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.963 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.366 sec
Running org.geoserver.test.SortByTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.972 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.629 sec
Running org.geoserver.test.StringConstantIdWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.295 sec
Running org.geoserver.test.SubstitutionGroupCoverageWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.913 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.751 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.979 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.895 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.952 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.64 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.946 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.141 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.728 sec
Running org.geoserver.test.XPathPredicateTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.393 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.613 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.634 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.911 sec
Running org.geoserver.test.web.Gml311LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.235 sec
Running org.geoserver.test.web.Gml32LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.402 sec
Results :
Failed tests: testNestedDWithinFilterEncoding(org.geoserver.test.NestedGeometryFilterEncodingTest)
testNestedBeyondFilterEncoding(org.geoserver.test.NestedGeometryFilterEncodingTest): expected:<2> but was:<1>
testGetAllNormalizedMultiValuesWfs11(org.geoserver.test.NormalizedMultiValuesTest): (..)
testGetAllNormalizedMultiValuesWfs20(org.geoserver.test.NormalizedMultiValuesTest): (..)
testGetFilteredNormalizedMultiValuesWfs11(org.geoserver.test.NormalizedMultiValuesTest): (..)
testGetFilteredNormalizedMultiValuesWfs20(org.geoserver.test.NormalizedMultiValuesTest): (..)
Tests run: 227, Failures: 6, Errors: 0, Skipped: 0
[INFO]
[INFO] Building Application Schema Solr Integration Test 2.15-SNAPSHOT
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml (2 KB at 15.7 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20180924.095002-18.pom
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20180924.095002-18.pom (5 KB at 433.8 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20180924.095002-18.jar
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20180924.095002-18-tests.jar
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20180924.095002-18.jar (65 KB at 4057.3 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20180924.095002-18-tests.jar (155 KB at 848.5 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-solr-test ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-solr-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-solr-test ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-solr-test ---
[INFO] Copying 0 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-solr-test ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-solr-test ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/surefire-reports>
T E S T S
Running org.geoserver.test.onlineTest.ComplexSolrTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.407 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-app-schema-solr-test ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 1 files (1 non-complying).
[ERROR] Found 1 non-complying files, failing build
[ERROR] To fix formatting errors, run "mvn fmt:format"
[ERROR] Non complying file: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/test/java/org/geoserver/test/onlineTest/ComplexSolrTest.java>
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 6.674 s]
[INFO] Application Schema Integration Test ................ SUCCESS [44:47 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.015 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [06:34 min]
[INFO] Application Schema Solr Integration Test ........... FAILURE [ 3.022 s]
[INFO] BUILD FAILURE
[INFO] Total time: 51:41 min
[INFO] Finished at: 2018-09-24T12:38:05+00:00
[INFO] Final Memory: 62M/386M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-postgis-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal com.coveo:fmt-maven-plugin:2.4.0:check (default) on project gs-app-schema-solr-test: Found 1 non-complying files, failing build -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-postgis-test
