Changes:
[Andrea Aime] JDK11 build, missing activation jar (the actual impl needed, not the
[Andrea Aime] JDK11 build, test was dependendent on map entry order, switched to
[Andrea Aime] JDK11 build, using jai and imageio-ext snapshots, add activation api
[Andrea Aime] JDK11 build, updating ApacheDS to 1.5.7 to avoid access to
[Andrea Aime] JDK11 build, ServiceLoader would not work anymore, hooking up to
[Andrea Aime] JDK11 build, handle small difference in exception message on XML
[Andrea Aime] JDK11 build, another slight difference in XML parsing handled
[Andrea Aime] JDK11 build, updated to latest commons-lang3 version, which can parse
[Andrea Aime] JDK11 build, handle stricter thread pool size checks in JDK11
[Andrea Aime] JDK11 build, adding JAXB dependencies to kml and netcdf-out
[Andrea Aime] JDK11 build, handle slight numerical differences in number
[Andrea Aime] JDK11 build, account for different double precision in formatted
[Andrea Aime] JDK11 build, handle differences of XML formatting in JDK11 (space
[Andrea Aime] JDK11 build, upgrading to latest Hazelcast version (yes, beta, we'll
[Andrea Aime] upgrade guava to version 27.0-jre - compile and test passes with jdk11
[andrea.antonello] centralized hazelcast version; fixed broken gwc test
[Andrea Aime] Attempting to mix current version of hazelcast-wm with latest
[Andrea Aime] Kicking hz-cluster from communityRelease, not sure how to upgrade its
[Andrea Aime] Making jms-cluster compile, was missing javax annotations dep, no
[Andrea Aime] Making OAuth2 packages compile on JDK11
[Andrea Aime] Making taskmanager module compile
[Brad Hards] Upgrade to Apache POI 4.0.0
[Brad Hards] [JDK 11] Upgrade JAXB to a 2.4.0-b version.
[Andrea Aime] Centralizing hazelcast version management
[Andrea Aime] Better chance of debugging error occurring on build server only
[Andrea Aime] Upgrading to imageio-ext 1.2.0
[tbarsballe] Temporary logging for build server errors, remove ASAP
[dtucker] Simplify renderer status in order to not rely on java internals.
[tbarsballe] Revert "Temporary logging for build server errors, remove ASAP"
[tbarsballe] Remove internal XMLChar reference, use xalan version instead.
[dvick] Upgrade to Apache POI 4.0.0
[dvick] Centralizing hazelcast version management
[dvick] Better chance of debugging error occurring on build server only
[dvick] working on fixing tests due to Spring 5.1 update. (+4 squashed commits)
[Andrea Aime] Emit debug warnings for illegal access during build
[Andrea Aime] Removing reflection warning in the GZIPFilterTest
[andrea.antonello] remove xom dependency that is unused and was raising warnings for jdk11
[dvick] fixes for
[tbarsballe] Rewrite PlainTextPasswordEncoder - Delegating factory does not have a
[dvick] two more fixes down to 15 failing tests.
[jnh5y] Added Abstract implementation for matches.
[dtucker] Updated password encoder to match the API. Add request verb to
[jnh5y] Fixing various tests.
[jnh5y] Fixing GETs.
[jnh5y] Changed BruteForceAttackTest to work against updated error message.
[jnh5y] Fixing WCS 1.1 tests.
[tbarsballe] Change <ref local= to <ref bean= (local hasn't been supported since
[jnh5y] Fixing WFS test.
[Kevin Smith] JUnit to 4.12 and Jackson to 2.9.7
[tbarsballe] Fix REST content negotiation
[Andrea Aime] Eliminate XStream warnings originating from GeoServer (there are quite
[Andrea Aime] Reduce usage of cglib lazy loading, switch it to use the spring
[Andrea Aime] Avoid illegal reflective access in modification proxy cloner
[Andrea Aime] Upgrading to latest pdfbox to fix a github warning (not really a
[Andrea Aime] Upgrade to Java 11 compatible Jetty version
[Andrea Aime] Add Marlin to the JVM only if version 8, Linux version
[Andrea Aime] Removed non fully working java versio selector and just ugpraded to
[tbarsballe] Remove commented code, add headers
[Andrea Aime] Upgrading easymock to 3.6
[tbarsballe] Finish removing SpringUnWrapper
[Kevin Smith] Fix test interdependencies in gs-gwc
[tbarsballe] Rename Jasypt wrapper classes and improve javadocs
[tbarsballe] Remove monitor-hibernate from communityRelease profile
[...truncated 1.75 MB...]
testPostGetFeature(org.geoserver.test.PropertySelectionTest): expected:<2> but was:<0>
testReprojection(org.geoserver.test.Reprojection3DTest): expected:<[3]> but was:<>
testRestconfig(org.geoserver.test.RestconfigWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testChainingReprojection(org.geoserver.test.SRSReprojectionTest): expected:<[52.5 -1.2 52.6 -1.2 52.6 -1.1 52.5 -1.1 52.5 -1.2]> but was:<>
testChainingXlink(org.geoserver.test.SRSReprojectionTest): expected:<[http://example.com/UrnResolver/?uri=1]> but was:<>
testNonFeatureTypeProxy(org.geoserver.test.SRSReprojectionTest): expected:<[value01]> but was:<>
testFilters(org.geoserver.test.SRSWfsTest): expected:<[1]> but was:<>
testReproject(org.geoserver.test.SRSWfsTest): expected:<[2]> but was:<>
testGetFeatureContent(org.geoserver.test.SRSWfsTest): expected:<[2]> but was:<>
testSameNameDiffNamespace3(org.geoserver.test.SameNameDiffNamespaceTest): expected:<1> but was:<0>
testNamespaces(org.geoserver.test.SecondaryNamespaceTest): expected:<2> but was:<0>
testSecureFeatureContent(org.geoserver.test.SecuredFeatureChainingTest): expected:<3> but was:<0>
testDenormalisedFeaturesCount(org.geoserver.test.SecuredFeatureChainingTest): expected:<[3]> but was:<>
testAttributeFilter(org.geoserver.test.SimpleAttributeFeatureChainWfsTest): expected:<[1]> but was:<>
testGetFeature(org.geoserver.test.SimpleAttributeFeatureChainWfsTest): expected:<[4]> but was:<>
testReprojecting(org.geoserver.test.SimpleAttributeFeatureChainWfsTest): expected:<[4]> but was:<>
testClientPropertiesFilter(org.geoserver.test.SimpleAttributeFeatureChainWfsTest): expected:<[1]> but was:<>
testGetMappedFeature(org.geoserver.test.SortByTest): expected:<[mf3]> but was:<>
testGetFeature(org.geoserver.test.SpecimenWfsTest): expected:<...p://www.opengis.net/[wfs/2.0]> but was:<...p://www.opengis.net/[ows]>
testGetFeatureContent(org.geoserver.test.SpecimenWfsTest): expected:<[2]> but was:<>
testGetFeature(org.geoserver.test.StringConstantIdWfsTest): expected:<[1]> but was:<>
testGetFeature(org.geoserver.test.SubstitutionGroupTest): expected:<[200.0]> but was:<>
testTimePositionSubset(org.geoserver.test.TimeSeriesInlineWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testQuantityListSubset(org.geoserver.test.TimeSeriesInlineWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testQuantityListSubset(org.geoserver.test.TimeSeriesWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testAttributeMinOccur0(org.geoserver.test.ValidationTest): expected:<1> but was:<0>
testAttributeMinOccur1(org.geoserver.test.ValidationTest): expected:<3> but was:<0>
testSimpleContentInteger(org.geoserver.test.ValidationTest): expected:<1> but was:<0>
testTimePositionSubset(org.geoserver.test.WaterMLTimeSeriesWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testFilter(org.geoserver.test.WaterMLTimeSeriesWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testGetFeatureInfoGMLReprojection(org.geoserver.test.WmsGetFeatureInfoTest): expected:<1> but was:<0>
testGetFeatureInfoHTML(org.geoserver.test.WmsGetFeatureInfoTest): expected:<1> but was:<0>
testGetFeatureInfoText(org.geoserver.test.WmsGetFeatureInfoTest)
testGetCapabilities(org.geoserver.test.WmsGetFeatureInfoTest): expected:<[WMS_Capabilities]> but was:<[ServiceExceptionReport]>
testGetFeatureInfoGML21(org.geoserver.test.WmsGetFeatureInfoTest): expected:<1> but was:<0>
testGetFeatureInfoGML(org.geoserver.test.WmsGetFeatureInfoTest): expected:<1> but was:<0>
testFiltering(org.geoserver.test.XPathPredicateTest): expected:<2> but was:<0>
testGetPropertyValue(org.geoserver.test.XPathPredicateTest): expected:<2> but was:<0>
testGetFeature(org.geoserver.test.XYGeomTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testGetFeatureContent(org.geoserver.test.XYGeomTest): expected:<2> but was:<0>
testDescribeFeatureType(org.geoserver.test.XYGeomTest): expected:<[xsd:schema]> but was:<[ows:ExceptionReport]>
testGeometry(org.geoserver.test.XlinkGeometryTest): expected:<[xlinkvalue1]> but was:<>
testGetFeature(org.geoserver.test.XlinkWfsTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
testGetCapabilities(org.geoserver.test.XlinkWfsTest): expected:<[wfs:WFS_Capabilities]> but was:<[ows:ExceptionReport]>
testGetFeatureContent(org.geoserver.test.XlinkWfsTest): expected:<4> but was:<0>
testDescribeFeatureType(org.geoserver.test.XlinkWfsTest): expected:<[xsd:schema]> but was:<[ows:ExceptionReport]>
Tests in error:
testAnyTypeAndAnyElementJSON(org.geoserver.test.FeatureChainingWfsTest): Invalid JSON String
testGetFeatureValid(org.geoserver.test.FeatureChainingWfsTest): Failed to resolve http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd
testNonValidNestedJSON(org.geoserver.test.FeatureChainingWfsTest): Invalid JSON String
testComplexTypeWithSimpleContentJSON(org.geoserver.test.FeatureChainingWfsTest): Invalid JSON String
testEncodeFeatureMembersJSON(org.geoserver.test.FeatureChainingWfsTest): Invalid JSON String
testGetFeatureJSON(org.geoserver.test.FeatureChainingWfsTest): Invalid JSON String
testGetFeatureValid(org.geoserver.test.Gsml30WfsTest): Failed to resolve http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd
testGetMap(org.geoserver.test.PagingTest)
testGetFeatureValid(org.geoserver.test.SpecimenWfsTest): Failed to resolve http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd
testGetFeature(org.geoserver.test.SubstitutionGroupCoverageWfsTest): Failed to resolve http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd
testGetFeature(org.geoserver.test.TimeSeriesInlineWfsTest): Failed to resolve http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd
testGetFeature(org.geoserver.test.TimeSeriesWfsTest): Failed to resolve http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd
testGetFeature(org.geoserver.test.WaterMLTimeSeriesWfsTest): Failed to resolve http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd
testGetLegendGraphicBlueRule(org.geoserver.test.WmsGetLegendGraphicTest)
testGetLegendGraphicRedRule(org.geoserver.test.WmsGetLegendGraphicTest)
testGetLegendGraphicAll(org.geoserver.test.WmsGetLegendGraphicTest)
testGetLegendGraphicGreenRule(org.geoserver.test.WmsGetLegendGraphicTest)
testGetMapWithCount(org.geoserver.test.WmsGetMapTest)
testGetMapAfterWFS(org.geoserver.test.WmsGetMapTest)
testGetMapOutcropCharacter(org.geoserver.test.WmsGetMapTest)
testGetMapOutcropCharacterReprojection(org.geoserver.test.WmsGetMapTest)
testGetMapPositionalAccuracy(org.geoserver.test.WmsGetMapTest)
testGml311Links(org.geoserver.test.web.Gml311LinksTest): Can't instantiate page using constructor 'public org.geoserver.web.demo.MapPreviewPage()'. An exception has been thrown during construction!
testGml32Links(org.geoserver.test.web.Gml32LinksTest): Can't instantiate page using constructor 'public org.geoserver.web.demo.MapPreviewPage()'. An exception has been thrown during construction!
Tests run: 231, Failures: 177, Errors: 24, Skipped: 0
[INFO]
[INFO] Building Application Schema Solr Integration Test 2.15-SNAPSHOT
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml (2 KB at 5.2 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181026.201207-54.pom
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181026.201207-54.pom (6 KB at 53.5 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181026.201207-54.jar
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181026.201207-54-tests.jar
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181026.201207-54.jar (70 KB at 706.0 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181026.201207-54-tests.jar (197 KB at 1680.8 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-solr-test ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-solr-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-solr-test ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-solr-test ---
[INFO] Copying 0 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-solr-test ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-solr-test ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/surefire-reports>
T E S T S
Running org.geoserver.test.onlineTest.ComplexSolrTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.421 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-app-schema-solr-test ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 1 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-app-schema-solr-test ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.15-SNAPSHOT/gs-app-schema-solr-test-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.15-SNAPSHOT/gs-app-schema-solr-test-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.15-SNAPSHOT/gs-app-schema-solr-test-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.15-SNAPSHOT/gs-app-schema-solr-test-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Application Schema Indexes Integration Test 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-indexes-test ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-indexes-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-indexes-test ---
[INFO] Copying 9 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-indexes-test ---
[INFO] Compiling 6 source files to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-indexes-test ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/surefire-reports>
T E S T S
Running org.geoserver.test.onlineTest.ComplexIndexesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.472 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-app-schema-indexes-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-app-schema-indexes-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-app-schema-indexes-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-app-schema-indexes-test ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/main/java’> does not exist, ignoring.
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-app-schema-indexes-test ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.15-SNAPSHOT/gs-app-schema-indexes-test-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.15-SNAPSHOT/gs-app-schema-indexes-test-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.15-SNAPSHOT/gs-app-schema-indexes-test-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.15-SNAPSHOT/gs-app-schema-indexes-test-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 14.222 s]
[INFO] Application Schema Integration Test ................ FAILURE [18:56 min]
[INFO] Sample DataAccess Integration Test ................. FAILURE [ 8.454 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [05:11 min]
[INFO] Application Schema Solr Integration Test ........... SUCCESS [ 4.215 s]
[INFO] Application Schema Indexes Integration Test ........ SUCCESS [ 3.062 s]
[INFO] BUILD FAILURE
[INFO] Total time: 24:38 min
[INFO] Finished at: 2018-10-26T21:11:06+00:00
[INFO] Final Memory: 65M/367M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-sample-data-access-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-postgis-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
