Changes:
[github] [GEOS-8986] Update documentation \ info related with measures (M)
[github] [GEOS-8992] Complex GeoJSON encoder ignores complex features (XML)
[github] [GEOS-8994] Complex features nested attributes not correctly detected
[...truncated 134.65 KB...]
Running org.geoserver.test.NamespacesWfsTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.958 sec
Running org.geoserver.test.NestedElementsFilteringTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.579 sec
Running org.geoserver.test.NestedGeometryFilterEncodingTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.313 sec
Running org.geoserver.test.NestedIdSupportTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.599 sec
Running org.geoserver.test.NormalizedMultiValuesTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.93 sec
Running org.geoserver.test.Observation_2_0_WfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.1 sec
Running org.geoserver.test.PagingTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.453 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.747 sec
Running org.geoserver.test.PolymorphismWfsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.27 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.456 sec
Running org.geoserver.test.PropertySelectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.202 sec
Running org.geoserver.test.Reprojection3DTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.391 sec
Running org.geoserver.test.RestconfigWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.36 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.857 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.655 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.984 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.496 sec
Running org.geoserver.test.SecuredFeatureChainingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 24.033 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.416 sec
Running org.geoserver.test.SortByTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.928 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.527 sec
Running org.geoserver.test.StringConstantIdWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.251 sec
Running org.geoserver.test.SubstitutionGroupCoverageWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.798 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.758 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.183 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.167 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.96 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.044 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.38 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.416 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.741 sec
Running org.geoserver.test.XPathPredicateTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.827 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.428 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.432 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.909 sec
Running org.geoserver.test.web.Gml311LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.383 sec
Running org.geoserver.test.web.Gml32LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.13 sec
Results :
Tests in error:
testGetGeoJsonResponseWfs11(org.geoserver.test.GeoJsonOutputFormatWfsTest): Invalid JSON String
testGetGeoJsonResponseWfs20(org.geoserver.test.GeoJsonOutputFormatWfsTest): Invalid JSON String
Tests run: 231, Failures: 0, Errors: 2, Skipped: 0
[INFO]
[INFO] Building Application Schema Solr Integration Test 2.15-SNAPSHOT
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/maven-metadata.xml (2 KB at 10.8 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181102.184014-67.pom
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181102.184014-67.pom (6 KB at 25.8 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181102.184014-67.jar
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181102.184014-67-tests.jar
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181102.184014-67.jar (71 KB at 593.3 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/21-SNAPSHOT/gt-solr-21-20181102.184014-67-tests.jar (199 KB at 1015.4 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-solr-test ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-solr-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-solr-test ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-solr-test ---
[INFO] Copying 0 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-solr-test ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-solr-test ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/surefire-reports>
T E S T S
Running org.geoserver.test.onlineTest.ComplexSolrTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.409 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-app-schema-solr-test ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 1 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-app-schema-solr-test ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.15-SNAPSHOT/gs-app-schema-solr-test-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.15-SNAPSHOT/gs-app-schema-solr-test-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.15-SNAPSHOT/gs-app-schema-solr-test-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.15-SNAPSHOT/gs-app-schema-solr-test-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Application Schema Indexes Integration Test 2.15-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-indexes-test ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target>
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-indexes-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/main/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-indexes-test ---
[INFO] Copying 9 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-indexes-test ---
[INFO] Compiling 6 source files to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-indexes-test ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/surefire-reports>
T E S T S
Running org.geoserver.test.onlineTest.ComplexIndexesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.403 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-app-schema-indexes-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-app-schema-indexes-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-app-schema-indexes-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-app-schema-indexes-test ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/main/java’> does not exist, ignoring.
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-app-schema-indexes-test ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.15-SNAPSHOT/gs-app-schema-indexes-test-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.15-SNAPSHOT/gs-app-schema-indexes-test-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.15-SNAPSHOT/gs-app-schema-indexes-test-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.15-SNAPSHOT/gs-app-schema-indexes-test-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 49.273 s]
[INFO] Application Schema Integration Test ................ SUCCESS [52:12 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.741 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [06:56 min]
[INFO] Application Schema Solr Integration Test ........... SUCCESS [ 3.062 s]
[INFO] Application Schema Indexes Integration Test ........ SUCCESS [ 2.593 s]
[INFO] BUILD FAILURE
[INFO] Total time: 01:00 h
[INFO] Finished at: 2018-11-02T21:41:38+00:00
[INFO] Final Memory: 64M/381M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-postgis-test: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-postgis-test
