[Geoserver-devel] Build failed in Jenkins: geoserver-master-app-schema-online #1349
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1349/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-9012] Allow OpenSearch REST created mosaics to use either time as
Started by timer
Building remotely on apollo-slave-02 in workspace <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&gt;
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 94d8bca73b5e1a7438117b1aa2fb519b6ae4e3a4 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 94d8bca73b5e1a7438117b1aa2fb519b6ae4e3a4
> git rev-list fe63c157ada8c5aea35e0ef26877f7a17cca0d73 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins5503944386803892606.sh
+ mkdir /var/jenkins/.geoserver
mkdir: cannot create directory `/var/jenkins/.geoserver': File exists
+ true
+ rm /var/jenkins/.geotools/postgis.properties
+ rm /var/jenkins/.geotools/oracle.properties
rm: cannot remove `/var/jenkins/.geotools/oracle.properties': No such file or directory
+ true
+ rm /var/jenkins/.geoserver/postgis.properties
+ rm /var/jenkins/.geoserver/oracle.properties
rm: cannot remove `/var/jenkins/.geoserver/oracle.properties': No such file or directory
+ true
+ set +x
psql: could not connect to server: Connection timed out
  Is the server running on host "184.154.70.224" and accepting
  TCP/IP connections on port 5432?
Build step 'Execute shell' marked build as failure
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1350/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Align with the geotools jai-ext version
Started by timer
Checking out Revision c43c9ac8a9e156e328ef2cfbea2ab070ec143291 (origin/master)
> git checkout -f c43c9ac8a9e156e328ef2cfbea2ab070ec143291
> git rev-list 94d8bca73b5e1a7438117b1aa2fb519b6ae4e3a4 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins2009907815646511155.sh
+ true
+ true
+ true
+ set +x
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1351/display/redirect?page=changes&gt;
Changes:
[lfelipevc] fixed bug GEOS-8868 error when press button Synchronize user/group
[lfelipevc] fixGEOS-8786 change feedback panel name
[fernandomino7] Remove gml:id from GML 3.1 geometry encoding
[github] Fix minor spelling errors and punctuation
[Andrea Aime] [GEOS-9017] Excessive number of coordinates used in GWC envelope
Started by timer
Checking out Revision 2e47370f7f184305ecf418d3c5f240b6211bfe3a (origin/master)
> git checkout -f 2e47370f7f184305ecf418d3c5f240b6211bfe3a
> git rev-list c43c9ac8a9e156e328ef2cfbea2ab070ec143291 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins450685389450698251.sh
+ true
+ true
+ true
+ set +x
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1352/display/redirect&gt;
Started by timer
> git rev-list 2e47370f7f184305ecf418d3c5f240b6211bfe3a # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins3492817896916480845.sh
+ true
+ true
+ true
+ set +x
