[Geoserver-devel] Build failed in Jenkins: geoserver-master-app-schema-online #1543
See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1543/display/redirect&gt;
Started by timer
ln builds/lastSuccessfulBuild /var/lib/jenkins/jobs/geoserver-master-app-schema-online/lastSuccessful failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-master-app-schema-online/lastSuccessful
  at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
  at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
  at java.nio.file.Files.deleteIfExists(Files.java:1165)
  at hudson.Util.createSymlink(Util.java:1193)
  at hudson.model.Run.createSymlink(Run.java:1955)
  at hudson.model.Run.updateSymlinks(Run.java:1936)
  at hudson.model.Run.execute(Run.java:1814)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
  at hudson.model.ResourceController.execute(ResourceController.java:97)
  at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-master-app-schema-online/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-master-app-schema-online/lastStable
  at hudson.model.Run.updateSymlinks(Run.java:1937)
Building remotely on i-04d23641d5b2d9a0b (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&gt;
Unpacking https://github.com/AdoptOpenJDK/openjdk8-binaries/releases/download/jdk8u212-b03/OpenJDK8U-jdk_x64_linux_hotspot_8u212b03.tar.gz to /tmp/jenkins-26e3803d/tools/hudson.model.JDK/OpenJDK_8u212 on i-04d23641d5b2d9a0b
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&gt; # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 35927a45b92b10c0efa386195d71dcc23ede1bad (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 35927a45b92b10c0efa386195d71dcc23ede1bad
Commit message: "WFS3: add tests for YAML. (#3529)"
> git rev-list --no-walk 35927a45b92b10c0efa386195d71dcc23ede1bad # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins4263058520573856061.sh
+ mkdir /home/ubuntu/.geoserver
+ rm /home/ubuntu/.geotools/postgis.properties
rm: cannot remove '/home/ubuntu/.geotools/postgis.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geotools/oracle.properties
rm: cannot remove '/home/ubuntu/.geotools/oracle.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geoserver/postgis.properties
rm: cannot remove '/home/ubuntu/.geoserver/postgis.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geoserver/oracle.properties
rm: cannot remove '/home/ubuntu/.geoserver/oracle.properties': No such file or directory
+ true
+ set +x
/tmp/jenkins4263058520573856061.sh: 15: /tmp/jenkins4263058520573856061.sh: psql: not found
Build step 'Execute shell' marked build as failure
See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1544/display/redirect&gt;
Started by timer
Building remotely on i-02adb618e47497a85 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&gt;
Unpacking https://github.com/AdoptOpenJDK/openjdk8-binaries/releases/download/jdk8u212-b03/OpenJDK8U-jdk_x64_linux_hotspot_8u212b03.tar.gz to /tmp/jenkins-521a2b8a/tools/hudson.model.JDK/OpenJDK_8u212 on i-02adb618e47497a85
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins5960764486126816245.sh
+ true
+ true
+ true
+ true
+ set +x
psql: could not connect to server: Connection refused
  Is the server running on host "localhost" (127.0.0.1) and accepting
  TCP/IP connections on port 5432?
See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1545/display/redirect&gt;
Started by timer
Building remotely on i-023bd4cae535d02b8 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&gt;
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins12697821817508971180.sh
+ true
+ true
+ true
+ true
+ set +x
Password for user geotools:
psql: fe_sendauth: no password supplied
See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1546/display/redirect&gt;
Started by timer
Building remotely on i-0d1336981b0717402 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&gt;
Unpacking https://github.com/AdoptOpenJDK/openjdk8-binaries/releases/download/jdk8u212-b03/OpenJDK8U-jdk_x64_linux_hotspot_8u212b03.tar.gz to /tmp/jenkins-702f1214/tools/hudson.model.JDK/OpenJDK_8u212 on i-0d1336981b0717402
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins17063943799319269331.sh
+ true
+ true
+ true
+ true
+ set +x
See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1547/display/redirect?page=changes&gt;
Changes:
[gabriel.roldan] Speed up data_dir load by making ConfigurationPasswordEncryptionHelper
Started by timer
Building remotely on i-072a32da4d1a313b0 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&gt;
Checking out Revision acfdccc57129a8115080258ee6ff501bf3df4a82 (origin/master)
> git checkout -f acfdccc57129a8115080258ee6ff501bf3df4a82
Commit message: "Speed up data_dir load by making ConfigurationPasswordEncryptionHelper faster"
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins4823827847267276379.sh
mkdir: cannot create directory ‘/home/ubuntu/.geoserver’: File exists
+ true
+ true
+ true
+ true
+ true
+ set +x
CREATE FUNCTION
CREATE FUNCTION
ERROR: permission denied for relation spatial_ref_sys
See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1548/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Makng GeoServer compile after removal of deprecated methods/objects in
[Andrea Aime] Removing/replacing all deprecated calls to IOUtils.closeQuietly
[Andrea Aime] Switching from old junit assert to the current one
[Andrea Aime] Removing easymock classpath extension, is deprecated and has been merged
[Andrea Aime] Removing RequestUtils deprecated method
[Andrea Aime] Removing HTTPServletAware and its usage points
[Andrea Aime] Replacing deprecated DefaultServiceExceptionHandler with its superclass
[Andrea Aime] Completing cleanup of the gs-ows module, removed the deprecated OWS
[Andrea Aime] Replacing commons deprecated MultiHashMap with MultiValueHashMap
[Andrea Aime] Replacing deprecated Wrapper and AbstractCatalogDecorator with the
[Andrea Aime] Bye bye DataAccessManager
[Andrea Aime] Sweeping under the rug a bit of deprecatd org.vfny stuff, unfortunately
[Andrea Aime] Replacing deprecated Spring Base64 class with java own
[Andrea Aime] Resource step one
[Andrea Aime] Replacing deprecated url method in GeoServerResourceLoader
[Andrea Aime] Cleaning up GeoServerDataDirectory deprecated methods
[Andrea Aime] Removing deprecated ResourceInfo.getPrefixedName
[Andrea Aime] Removing deprecated methods from Catalog
[Andrea Aime] Removing deprecated prefixedName from PublishedInfo
[Andrea Aime] Removing deprecated methods from ContactInfo and GeoServerInfo
[Andrea Aime] Removing deprecated methods from JAIInfo
[Andrea Aime] The concurrent operation registry is in jai-ext
[Andrea Aime] Fixing IOUtils.write calls and removing GeoServeFeatureLocking
[Andrea Aime] Replacing calls to Throwables deprecated methods
[Andrea Aime] Dude, this is the two arguments constructor....
[Andrea Aime] Fixing deprecated calls to Spring Assert methos, use junit assert in
[Andrea Aime] Removing CatalogFacade deprecated method
[Andrea Aime] Removing StyleInfo deprecated methods
[Andrea Aime] Removing deprecated methods from template loader
[Andrea Aime] Resolving assorted deprecations in gs-main tests, fixing pmd and
[Andrea Aime] Fixing deprecated calls to Capture
[Andrea Aime] Removing PropertyFileWatcher deprecated constructor
[Andrea Aime] Removing deprecated methods from FileWatcher and friends
[Andrea Aime] Fixing deprecated class usage in LDAP module... finger crossed, I don't
[Andrea Aime] Fixing deprecated calls to readFileToString
[Andrea Aime] Fixed usage of deprecated SimpleEnumerationType
[Andrea Aime] Removed dodgy deprecation, was deprecated but GMLInfo was not given a
[Andrea Aime] Goodbye TransactionPlugin
[Andrea Aime] Removing deprecated method from Response
[Andrea Aime] Removing usage of deprecated EMFUtils.clone method
[Andrea Aime] Fixing calls to URLDecoder.decode deprecated method version
[Andrea Aime] Fixing deprecated point constructor call
[Andrea Aime] Removing ShapeZipOutputFormat deprecated constructor
[Andrea Aime] Small deprecation and PMD fixes
[Andrea Aime] Removing deprecated call to ExpressionDOMParser static method
[Andrea Aime] GetLegendGraphicRequest deprecated methods removal
[Andrea Aime] Ignore deprecatins in MockHttpClientConnectionManager, nothing we can do
[Andrea Aime] Completing WMS small cleanups
[Andrea Aime] Fixing deprecated calls to FileUtils.write
[Andrea Aime] Fixing usage of deprecated constructor of
[Andrea Aime] Removing deprecated methods in GeoServerTileLayer
[Andrea Aime] Handling assorted deprecations in gwc src/main
[Andrea Aime] Assorted deprecation fixes. Some are just suppressions, the author of
[Andrea Aime] Assorted deprecated call fixes in restconfig
[Andrea Aime] Fixing assorted deprecations in web/core
[Andrea Aime] Removing deprecated method from GeoServerSecurityManager
[Andrea Aime] Ignoring deprecation on wicket method call that has no obvious
[Andrea Aime] web/app deprecation fixes. Start.java uses a bunch of deprecated
[Andrea Aime] Removing deprecated IOUtils class, switch usage points to its superclass
[Andrea Aime] Completing app-schema-test cleanup
[Andrea Aime] Cleaning up html image map
[Andrea Aime] Fixing ogr output format
[Andrea Aime] Cleaning up GSProcess usage
[Andrea Aime] Assorted minor fixes in wps
[Andrea Aime] Cleaning up geofence and monitoring
[Andrea Aime] Follow up on GeoTools changes
[Andrea Aime] Making community modules in communityRelease compile
[Andrea Aime] Fixing build after deprecated method removal in GeoWebCache
[Andrea Aime] Deprecated API checkpoint on main, more deprecated API yet to remove
[Andrea Aime] Closing up main
[Andrea Aime] Make community modules compile
[Andrea Aime] java 11 fixes
[Andrea Aime] More java 11 fixes. WCS 1.1 has the same 'fix' as CQL, cannot have
[Andrea Aime] Add extensibility of common preview formats via beans (#3521)
[Andrea Aime] GEOS-9184 style image upload: NPE if new style (#3443)
[Andrea Aime] Revert "Resource step one"
[Andrea Aime] Resources.find( resource, force ) javadoc Implement
Started by timer
Building remotely on i-06f59b2f24d096a96 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&gt;
Unpacking https://github.com/AdoptOpenJDK/openjdk8-binaries/releases/download/jdk8u212-b03/OpenJDK8U-jdk_x64_linux_hotspot_8u212b03.tar.gz to /tmp/jenkins-26312fcd/tools/hudson.model.JDK/OpenJDK_8u212 on i-06f59b2f24d096a96
Checking out Revision 290813cbc463e68459b7eb7d8e6b031b0e192657 (origin/master)
> git checkout -f 290813cbc463e68459b7eb7d8e6b031b0e192657
Commit message: "Merge pull request #3449 from aaime/deprecation"
> git rev-list --no-walk acfdccc57129a8115080258ee6ff501bf3df4a82 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins13320394533890651548.sh
+ true
+ true
+ true
+ true
+ set +x
