See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1550/display/redirect?page=changes>
Changes:
[Torben Barsballe] [GEOS-8752] Allow integrated GWC to seed secured layers - Add regression
Started by timer
ln builds/lastSuccessfulBuild /var/lib/jenkins/jobs/geoserver-master-app-schema-online/lastSuccessful failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-master-app-schema-online/lastSuccessful
at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
at java.nio.file.Files.deleteIfExists(Files.java:1165)
at hudson.Util.createSymlink(Util.java:1193)
at hudson.model.Run.createSymlink(Run.java:1955)
at hudson.model.Run.updateSymlinks(Run.java:1936)
at hudson.model.Run.execute(Run.java:1814)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-master-app-schema-online/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-master-app-schema-online/lastStable
at hudson.model.Run.updateSymlinks(Run.java:1937)
Building remotely on i-0aad116285a365a2a (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/>
Unpacking https://github.com/AdoptOpenJDK/openjdk8-binaries/releases/download/jdk8u212-b03/OpenJDK8U-jdk_x64_linux_hotspot_8u212b03.tar.gz to /tmp/jenkins-80297e65/tools/hudson.model.JDK/OpenJDK_8u212 on i-0aad116285a365a2a
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/> # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 1b8a459b27881fece2783a8189ae5e6414bf3478 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 1b8a459b27881fece2783a8189ae5e6414bf3478
Commit message: "Merge pull request #3525 from tbarsballe/GEOS-8752"
> git rev-list --no-walk 290813cbc463e68459b7eb7d8e6b031b0e192657 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins3575304206799490092.sh
+ mkdir /home/ubuntu/.geoserver
+ rm /home/ubuntu/.geotools/postgis.properties
rm: cannot remove '/home/ubuntu/.geotools/postgis.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geotools/oracle.properties
rm: cannot remove '/home/ubuntu/.geotools/oracle.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geoserver/postgis.properties
rm: cannot remove '/home/ubuntu/.geoserver/postgis.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geoserver/oracle.properties
rm: cannot remove '/home/ubuntu/.geoserver/oracle.properties': No such file or directory
+ true
+ set +x
Password for user geotools:
psql: fe_sendauth: no password supplied
Build step 'Execute shell' marked build as failure
See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1551/display/redirect?page=changes>
Changes:
[niels] GEOS-9125 improve indexed property support in catalogpropertyaccessor
[Torben Barsballe] [GEOS-8254] Add demo page english translation for DXF
[Torben Barsballe] Add demo page english translations for OGR-WFS
[Torben Barsballe] [GEOS-8628] Add missing demo page english translation for VectorTiles
[Torben Barsballe] Add missing demo page english translation for GeoPackage
[Torben Barsballe] Add missing demo page english translation for DDS BIL
[Torben Barsballe] Add demo page english translation for MapML
[Torben Barsballe] Add missing demo page english translation for GeoRSS and KML
[Jody Garnett] Fix GWC RESTIntegration test to work after recent Spring MVC fix
[daniele.romagnoli] Updating imageio-ext and jai-ext versions
[Jody Garnett] Use Charset.defaultCharset() to test resource operations
[Jody Garnett] comment used to force rebuild
Started by timer
Building remotely on i-0cd931f994d495f2a (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/>
Checking out Revision c1c317a8c614a78b40b81f362702faebd8d25831 (origin/master)
> git checkout -f c1c317a8c614a78b40b81f362702faebd8d25831
Commit message: "comment used to force rebuild"
> git rev-list --no-walk 1b8a459b27881fece2783a8189ae5e6414bf3478 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins11018048349575602598.sh
mkdir: cannot create directory ‘/home/ubuntu/.geoserver’: File exists
+ true
+ true
+ true
+ true
+ true
+ set +x
CREATE FUNCTION
CREATE FUNCTION
ERROR: permission denied for relation spatial_ref_sys
See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1552/display/redirect?page=changes>
Changes:
[Torben Barsballe] Add gs-fgdb community module
[Torben Barsballe] importer-fgdb - updates based on feedback, fix deprecated methods
[Jody Garnett] keep going after first sphinx-build warning
[Jody Garnett] update postgis data store connection parameters
[Jody Garnett] fix heading indentation to preserve table of contents structure
[Jody Garnett] fix sphinx-build warnings allowing build with -W option
[Jody Garnett] revise based on feedback
Started by timer
Building remotely on i-0d56ae68438a5a29f (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/>
Checking out Revision 62d947c32d38797aaaf826d58fdc58baacb78d4f (origin/master)
> git checkout -f 62d947c32d38797aaaf826d58fdc58baacb78d4f
Commit message: "Merge pull request #3393 from tbarsballe/fgdb"
> git rev-list --no-walk c1c317a8c614a78b40b81f362702faebd8d25831 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins9484093876787291164.sh
+ true
+ true
+ true
+ true
+ set +x
See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1553/display/redirect?page=changes>
Changes:
[tabareu90] GEOS-9227 Cannot upload more than 10 times the same shapefile (or source
[daniele.romagnoli] GEOS-9235: Customizing OWS Exception Handler content-type
Started by timer
Building remotely on i-012cef99590b90d3c (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/>
Checking out Revision 733a4153cf675129b49ff818f5c9039741495c5c (origin/master)
> git checkout -f 733a4153cf675129b49ff818f5c9039741495c5c
Commit message: "Merge pull request #3538 from taba90/master"
> git rev-list --no-walk 62d947c32d38797aaaf826d58fdc58baacb78d4f # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins4420260863714453107.sh
+ true
+ true
+ true
+ true
+ set +x
See <http://build.geoserver.org/job/geoserver-master-app-schema-online/1554/display/redirect?page=changes>
Changes:
[daniele.romagnoli] cleanup OWS ExceptionHandler test
[Andrea Aime] Follow up on scale/offset imageio-ext and gt support
Started by timer
Building remotely on i-0075247cc3e84e5c2 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-master-app-schema-online/ws/>
Checking out Revision 0b242a05ada6fc9d030a876760c68e08ac36b311 (origin/master)
> git checkout -f 0b242a05ada6fc9d030a876760c68e08ac36b311
Commit message: "Merge pull request #3530 from aaime/scaleOffset"
> git rev-list --no-walk 733a4153cf675129b49ff818f5c9039741495c5c # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins11830743260758735219.sh
+ true
+ true
+ true
+ true
+ true
+ set +x
CREATE FUNCTION
CREATE FUNCTION
