[Geoserver-devel] Build failed in Jenkins: geoserver-master-app-schema-online #1638
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1638/display/redirect?page=changes&gt;
Changes:
[Torben Barsballe] Updated version to 2.17-SNAPSHOT, updated GeoTools dependency to
Started by timer
Running as SYSTEM
Building remotely on FleetCloud i-0ec527185f5a5c85a (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&gt;
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&gt; # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision d76c283984ef2c8a2de493127c68493f77d24659 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f d76c283984ef2c8a2de493127c68493f77d24659
Commit message: "Updated version to 2.17-SNAPSHOT, updated GeoTools dependency to 23-SNAPSHOT, updated GeoWebCache dependency to 1.17-SNAPSHOT, and related changes"
> git rev-list --no-walk 01481c972030650cd43b67feecab8e624ce648a8 # timeout=10
Copied 1 artifact from "ojdbc7" build number 3
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/jenkins10247006857020920862.sh
+ mkdir /home/ubuntu/.geoserver
mkdir: cannot create directory ‘/home/ubuntu/.geoserver’: File exists
+ true
+ rm /home/ubuntu/.geotools/postgis.properties
rm: cannot remove '/home/ubuntu/.geotools/postgis.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geotools/oracle.properties
rm: cannot remove '/home/ubuntu/.geotools/oracle.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geoserver/postgis.properties
rm: cannot remove '/home/ubuntu/.geoserver/postgis.properties': No such file or directory
+ true
+ rm /home/ubuntu/.geoserver/oracle.properties
rm: cannot remove '/home/ubuntu/.geoserver/oracle.properties': No such file or directory
+ true
+ set +x
could not change directory to "<https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/&quot;&gt;: Permission denied
GRANT
CREATE FUNCTION
CREATE FUNCTION
DELETE 0
INSERT 0 1
srid
4979
(1 row)
[e[1;34mINFOe[m] Scanning for projects...
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m------------------< e[0;36morg.apache.maven:standalone-pome[0;1m >-------------------e[m
[e[1;34mINFOe[m] e[1mBuilding Maven Stub Project (No POM) 1e[m
[e[1;34mINFOe[m] e[1m--------------------------------[ pom ]---------------------------------e[m
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-install-plugin:2.4:install-filee[m e[1m(default-cli)e[m @ e[36mstandalone-pome[0;1m ---e[m
[e[1;34mINFOe[m] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/ojdbc7.jar&gt; to /home/ubuntu/.m2/repository/com/oracle/ojdbc7/12.1.0.2/ojdbc7-12.1.0.2.jar
[e[1;34mINFOe[m] Installing /tmp/mvninstall7157551844431572684.pom to /home/ubuntu/.m2/repository/com/oracle/ojdbc7/12.1.0.2/ojdbc7-12.1.0.2.pom
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;32mBUILD SUCCESSe[m
[e[1;34mINFOe[m] Total time: 0.330 s
[e[1;34mINFOe[m] Finished at: 2019-08-30T21:44:39Z
[geoserver-master-app-schema-online] $ mvn -f src/extension/app-schema/pom.xml -B -U -Dtest.maxHeapSize=1024m -Dtest.maxPermSize=128m -fae -Papp-schema-online-test -pl !app-schema-oracle-test,!app-schema-mongo-test -Djava.io.tmpdir=/tmp -Dfmt.action=check clean install
[INFO] Scanning for projects...
[INFO] Reactor Build Order:
[INFO]
[INFO] Application Schema Support [pom]
[INFO] Application Schema Integration Test [jar]
[INFO] Sample DataAccess Integration Test [jar]
[INFO] Application Schema Integration Online Test with Postgis Database [jar]
[INFO] Application Schema Solr Integration Test [jar]
[INFO] Application Schema Indexes Integration Test [jar]
[INFO]
[INFO] ---------------< org.geoserver.extension:gs-app-schema >----------------
[INFO] Building Application Schema Support 2.17-SNAPSHOT [1/6]
[INFO] --------------------------------[ pom ]---------------------------------
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/gs-platform/2.17-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/gs-platform/2.17-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.17-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.pom
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.pom
[WARNING] The POM for org.geoserver:gs-platform:jar:2.17-SNAPSHOT is missing, no dependency information available
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-main/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/23-SNAPSHOT/maven-metadata.xml (1.2 kB at 26 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/23-SNAPSHOT/gt-main-23-20190830.111438-4.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/23-SNAPSHOT/gt-main-23-20190830.111438-4.pom (9.3 kB at 387 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/library/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/library/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/23-SNAPSHOT/maven-metadata.xml (590 B at 24 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/23-SNAPSHOT/library-23-20190830.111413-4.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/library/23-SNAPSHOT/library-23-20190830.111413-4.pom (2.2 kB at 139 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/modules/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/modules/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/23-SNAPSHOT/maven-metadata.xml (590 B at 24 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/23-SNAPSHOT/modules-23-20190830.111413-4.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/modules/23-SNAPSHOT/modules-23-20190830.111413-4.pom (3.3 kB at 208 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/geotools/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/23-SNAPSHOT/maven-metadata.xml (591 B at 23 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/23-SNAPSHOT/geotools-23-20190830.111412-4.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/geotools/23-SNAPSHOT/geotools-23-20190830.111412-4.pom (86 kB at 2.3 MB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-referencing/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-referencing/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/23-SNAPSHOT/maven-metadata.xml (1.2 kB at 46 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/23-SNAPSHOT/gt-referencing-23-20190830.111429-4.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/23-SNAPSHOT/gt-referencing-23-20190830.111429-4.pom (7.3 kB at 458 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-metadata/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/23-SNAPSHOT/maven-metadata.xml (975 B at 41 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/23-SNAPSHOT/gt-metadata-23-20190830.111424-4.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/23-SNAPSHOT/gt-metadata-23-20190830.111424-4.pom (5.0 kB at 359 kB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-opengis/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/23-SNAPSHOT/maven-metadata.xml (974 B at 39 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/23-SNAPSHOT/gt-opengis-23-20190830.111418-4.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/23-SNAPSHOT/gt-opengis-23-20190830.111418-4.pom (5.8 kB at 413 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/23-SNAPSHOT/gt-main-23-20190830.111438-4.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/23-SNAPSHOT/gt-referencing-23-20190830.111429-4.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/23-SNAPSHOT/gt-metadata-23-20190830.111424-4.jar
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/23-SNAPSHOT/gt-opengis-23-20190830.111418-4.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/23-SNAPSHOT/gt-metadata-23-20190830.111424-4.jar (547 kB at 9.1 MB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/23-SNAPSHOT/gt-opengis-23-20190830.111418-4.jar (359 kB at 4.7 MB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/23-SNAPSHOT/gt-referencing-23-20190830.111429-4.jar (1.5 MB at 14 MB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-main/23-SNAPSHOT/gt-main-23-20190830.111438-4.jar (2.0 MB at 15 MB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/gs-platform/2.17-SNAPSHOT/gs-platform-2.17-SNAPSHOT.jar
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping Sample DataAccess Integration Test
[INFO]
[INFO] Skipping Application Schema Integration Online Test with Postgis Database
[INFO]
[INFO] Skipping Application Schema Solr Integration Test
[INFO]
[INFO] Skipping Application Schema Indexes Integration Test
[INFO] Reactor Summary for Application Schema Support 2.17-SNAPSHOT:
[INFO]
[INFO] Application Schema Support ......................... FAILURE [ 2.926 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] Application Schema Integration Online Test with Postgis Database SKIPPED
[INFO] Application Schema Solr Integration Test ........... SKIPPED
[INFO] Application Schema Indexes Integration Test ........ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3.319 s
[INFO] Finished at: 2019-08-30T21:44:44Z
[ERROR] Failed to execute goal on project gs-app-schema: Could not resolve dependencies for project org.geoserver.extension:gs-app-schema:pom:2.17-SNAPSHOT: Could not find artifact org.geoserver:gs-platform:jar:2.17-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1639/display/redirect?page=changes&gt;
Changes:
[Torben Barsballe] Update ogcapi to 2.17-SNAPSHOT
[...truncated 52.44 KB...]
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/web/gs-web-core/2.17-SNAPSHOT/gs-web-core-2.17-20190830.223658-1-tests.jar (315 kB at 2.3 MB/s)
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geoserver/gs-restconfig/2.17-SNAPSHOT/gs-restconfig-2.17-20190830.223705-1-tests.jar (2.7 MB at 14 MB/s)
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/web/gs-web-demo/2.17-SNAPSHOT/gs-web-demo-2.17-SNAPSHOT.jar
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geoserver/web/gs-web-demo/2.17-SNAPSHOT/gs-web-demo-2.17-SNAPSHOT-tests.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/web/gs-web-demo/2.17-SNAPSHOT/gs-web-demo-2.17-SNAPSHOT.jar
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geoserver/web/gs-web-demo/2.17-SNAPSHOT/gs-web-demo-2.17-SNAPSHOT-tests.jar
[INFO]
[INFO] ---------< org.geoserver.extension:gs-sample-data-access-test >---------
[INFO] Building Sample DataAccess Integration Test 2.17-SNAPSHOT [3/6]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data-access/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-sample-data-access/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-sample-data-access/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data-access/23-SNAPSHOT/maven-metadata.xml (985 B at 32 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data-access/23-SNAPSHOT/gt-sample-data-access-23-20190830.111514-4.pom
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data-access/23-SNAPSHOT/gt-sample-data-access-23-20190830.111514-4.pom (1.4 kB at 48 kB/s)
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data-access/23-SNAPSHOT/gt-sample-data-access-23-20190830.111514-4.jar
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-sample-data-access/23-SNAPSHOT/gt-sample-data-access-23-20190830.111514-4.jar (17 kB at 544 kB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-sample-data-access-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-sample-data-access-test ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-sample-data-access-test ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sample-data-access-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/src/main/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-sample-data-access-test ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sample-data-access-test ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-sample-data-access-test ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 3 source files to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-sample-data-access-test ---
[INFO]
[INFO] T E S T S
[INFO] Running org.geoserver.test.SampleDataAccessWfsTest
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
[INFO] Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.883 s - in org.geoserver.test.SampleDataAccessWfsTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sample-data-access-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sample-data-access-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sample-data-access-test ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sample-data-access-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-sample-data-access-test ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/src/main/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sample-data-access-test ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-sample-data-access-test/2.17-SNAPSHOT/gs-sample-data-access-test-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-sample-data-access-test/2.17-SNAPSHOT/gs-sample-data-access-test-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-sample-data-access-test/2.17-SNAPSHOT/gs-sample-data-access-test-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/gs-sample-data-access-test-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-sample-data-access-test/2.17-SNAPSHOT/gs-sample-data-access-test-2.17-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------< org.geoserver.extension:gs-app-schema-postgis-test >---------
[INFO] Building Application Schema Integration Online Test with Postgis Database 2.17-SNAPSHOT [4/6]
[INFO]
[INFO] ----------< org.geoserver.extension:gs-app-schema-solr-test >-----------
[INFO] Building Application Schema Solr Integration Test 2.17-SNAPSHOT [5/6]
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/geotools/gt-solr/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/geotools/gt-solr/23-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded from boundless: https://repo.boundlessgeo.com/main/org/geotools/gt-solr/23-SNAPSHOT/maven-metadata.xml (1.4 kB at 22 kB/s)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-solr-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-solr-test ---
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-app-schema-solr-test ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-app-schema-solr-test ---
[INFO]
[INFO] T E S T S
[INFO] Running org.geoserver.test.onlineTest.ComplexSolrTest
[WARNING] Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.293 s - in org.geoserver.test.onlineTest.ComplexSolrTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-app-schema-solr-test ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-app-schema-solr-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-app-schema-solr-test ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/src/main/java’> does not exist, ignoring.
[INFO] Processed 1 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-app-schema-solr-test ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.17-SNAPSHOT/gs-app-schema-solr-test-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.17-SNAPSHOT/gs-app-schema-solr-test-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.17-SNAPSHOT/gs-app-schema-solr-test-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-solr-test/target/gs-app-schema-solr-test-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-solr-test/2.17-SNAPSHOT/gs-app-schema-solr-test-2.17-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------< org.geoserver.extension:gs-app-schema-indexes-test >---------
[INFO] Building Application Schema Indexes Integration Test 2.17-SNAPSHOT [6/6]
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-indexes-test ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/main/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-indexes-test ---
[INFO] Copying 9 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-app-schema-indexes-test ---
[INFO] Compiling 6 source files to <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/test-classes&gt;
[INFO] <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/test/java/org/geoserver/test/onlineTest/ComplexIndexesTest.java&gt;: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/test/java/org/geoserver/test/onlineTest/ComplexIndexesTest.java&gt; uses unchecked or unsafe operations.
[INFO] <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/test/java/org/geoserver/test/onlineTest/ComplexIndexesTest.java&gt;: Recompile with -Xlint:unchecked for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.22.2:test (default-test) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] T E S T S
[INFO] Running org.geoserver.test.onlineTest.ComplexIndexesTest
[WARNING] Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.287 s - in org.geoserver.test.onlineTest.ComplexIndexesTest
[INFO]
[INFO] Results:
[INFO]
[INFO]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-app-schema-indexes-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-app-schema-indexes-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.17-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-app-schema-indexes-test ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-app-schema-indexes-test ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.17-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-app-schema-indexes-test ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/src/main/java’> does not exist, ignoring.
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-app-schema-indexes-test ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.17-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.17-SNAPSHOT/gs-app-schema-indexes-test-2.17-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.17-SNAPSHOT/gs-app-schema-indexes-test-2.17-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.17-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.17-SNAPSHOT/gs-app-schema-indexes-test-2.17-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-indexes-test/target/gs-app-schema-indexes-test-2.17-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-app-schema-indexes-test/2.17-SNAPSHOT/gs-app-schema-indexes-test-2.17-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 4.884 s]
[INFO] Application Schema Integration Test ................ FAILURE [ 12.394 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.630 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [ 0.055 s]
[INFO] Application Schema Solr Integration Test ........... SUCCESS [ 1.819 s]
[INFO] Application Schema Indexes Integration Test ........ SUCCESS [ 1.524 s]
[INFO] Total time: 29.711 s
[INFO] Finished at: 2019-08-30T22:37:26Z
[ERROR] Failed to execute goal on project gs-app-schema-test: Could not resolve dependencies for project org.geoserver.extension:gs-app-schema-test:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver.web:gs-web-demo:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-demo:jar:tests:2.17-SNAPSHOT: Could not find artifact org.geoserver.web:gs-web-demo:jar:2.17-SNAPSHOT in boundless (https://repo.boundlessgeo.com/main/) -> [Help 1]
[ERROR] Failed to execute goal on project gs-app-schema-postgis-test: Could not resolve dependencies for project org.geoserver.extension:gs-app-schema-postgis-test:jar:2.17-SNAPSHOT: The following artifacts could not be resolved: org.geoserver.web:gs-web-demo:jar:2.17-SNAPSHOT, org.geoserver.web:gs-web-demo:jar:tests:2.17-SNAPSHOT: Failure to find org.geoserver.web:gs-web-demo:jar:2.17-SNAPSHOT in https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
See <https://build.geoserver.org/job/geoserver-master-app-schema-online/1640/display/redirect?page=changes&gt;
