[Geoserver-devel] Build failed in Jenkins: geoserver-master-app-schema-online #837
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/837/changes&gt;
Changes:
[nuno.oliveira] [GEOS-8108] Several WFS requests on complex features are returning null
[...truncated 952 lines...]
  at org.geoserver.test.GeoServerBaseTestSupport.doSetup(GeoServerBaseTestSupport.java:148)
  at sun.reflect.GeneratedMethodAccessor180.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
Caused by: java.io.FileNotFoundException: target/app-schema-mock7391167580485069117data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.08707067152907344/gml31/stations_gml31.properties (No such file or directory)
  at java.io.FileInputStream.open0(Native Method)
  at java.io.FileInputStream.open(FileInputStream.java:195)
  at java.io.FileInputStream.<init>(FileInputStream.java:138)
  at java.io.FileReader.<init>(FileReader.java:72)
  at org.geotools.data.property.PropertyFeatureReader.<init>(PropertyFeatureReader.java:103)
  at org.geotools.data.property.PropertyFeatureReader.<init>(PropertyFeatureReader.java:98)
  at org.geoserver.test.onlineTest.setup.AppSchemaTestPostgisSetup.createTables(AppSchemaTestPostgisSetup.java:126)
  at org.geoserver.test.onlineTest.setup.AppSchemaTestPostgisSetup.<init>(AppSchemaTestPostgisSetup.java:105)
  at org.geoserver.test.onlineTest.setup.AppSchemaTestPostgisSetup.getInstance(AppSchemaTestPostgisSetup.java:94)
  at org.geoserver.test.AbstractAppSchemaMockData.createTablesInTestDatabase(AbstractAppSchemaMockData.java:580)
  at org.geoserver.test.AbstractAppSchemaMockData.<init>(AbstractAppSchemaMockData.java:212)
  ... 38 more
virtualServiceNamespacesWfs20(org.geoserver.test.NamespacesWfsTest) Time elapsed: 5 sec <<< ERROR!
java.lang.RuntimeException: java.io.FileNotFoundException: target/app-schema-mock4594840438965696390data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.08707067152907344/gml31/stations_gml31.properties (No such file or directory)
  at org.geoserver.test.AbstractAppSchemaMockData.<init>(AbstractAppSchemaMockData.java:214)
  at org.geoserver.test.AbstractAppSchemaMockData.<init>(AbstractAppSchemaMockData.java:183)
  at org.geoserver.test.NamespacesWfsTest$MockData.<init>(NamespacesWfsTest.java:59)
  at org.geoserver.test.NamespacesWfsTest.createTestData(NamespacesWfsTest.java:164)
  at org.geoserver.test.NamespacesWfsTest.createTestData(NamespacesWfsTest.java:30)
Caused by: java.io.FileNotFoundException: target/app-schema-mock4594840438965696390data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.08707067152907344/gml31/stations_gml31.properties (No such file or directory)
  ... 38 more
Running org.geoserver.test.NestedIdSupportTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.4 sec
Running org.geoserver.test.Observation_2_0_WfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.369 sec
Running org.geoserver.test.PagingTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.427 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.861 sec
Running org.geoserver.test.PolymorphismWfsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.071 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.158 sec
Running org.geoserver.test.PropertySelectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.139 sec
Running org.geoserver.test.Reprojection3DTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.699 sec
Running org.geoserver.test.RestconfigWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.039 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.118 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.833 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.55 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.92 sec
Running org.geoserver.test.SecuredFeatureChainingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.232 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.417 sec
Running org.geoserver.test.SortByTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.983 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.256 sec
Running org.geoserver.test.StringConstantIdWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.596 sec
Running org.geoserver.test.SubstitutionGroupCoverageWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.103 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.276 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.797 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.62 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.833 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.952 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.063 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.091 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.121 sec
Running org.geoserver.test.XPathPredicateTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.79 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.04 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.834 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.41 sec
Running org.geoserver.test.web.Gml311LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.576 sec
Running org.geoserver.test.web.Gml32LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.372 sec
Results :
Tests in error:
  globalServiceNamespacesWfs11(org.geoserver.test.NamespacesWfsTest): java.io.FileNotFoundException: target/app-schema-mock5885287423726364199data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.08707067152907344/gml31/stations_gml31.properties (No such file or directory)
  globalServiceNamespacesWfs20(org.geoserver.test.NamespacesWfsTest): java.io.FileNotFoundException: target/app-schema-mock2620307417980765603data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.08707067152907344/gml31/stations_gml31.properties (No such file or directory)
  virtualServiceNamespacesWfs11(org.geoserver.test.NamespacesWfsTest): java.io.FileNotFoundException: target/app-schema-mock7391167580485069117data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.08707067152907344/gml31/stations_gml31.properties (No such file or directory)
  virtualServiceNamespacesWfs20(org.geoserver.test.NamespacesWfsTest): java.io.FileNotFoundException: target/app-schema-mock4594840438965696390data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.08707067152907344/gml31/stations_gml31.properties (No such file or directory)
Tests run: 197, Failures: 0, Errors: 4, Skipped: 0
[INFO]
[INFO] Building Application Schema MongoDB Integration Test 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-mongo-test ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-mongo-test/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-app-schema-mongo-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-mongo-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-mongo-test ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-mongo-test/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-mongo-test/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-mongo-test ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-mongo-test ---
[INFO] Copying 0 resource
[INFO] Copying 7 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-mongo-test ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-mongo-test/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-mongo-test ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-mongo-test/target/surefire-reports&gt;
T E S T S
Running org.geoserver.test.onlineTest.ComplexMongoDBTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.522 sec
Results :
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 5.927 s]
[INFO] Application Schema Integration Test ................ SUCCESS [08:47 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.439 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [03:37 min]
[INFO] Application Schema MongoDB Integration Test ........ SUCCESS [ 3.487 s]
[INFO] BUILD FAILURE
[INFO] Total time: 12:46 min
[INFO] Finished at: 2017-07-04T20:52:55+00:00
[INFO] Final Memory: 53M/353M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-postgis-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-postgis-test
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/838/&gt;
[...truncated 948 lines...]
Caused by: java.io.FileNotFoundException: target/app-schema-mock4221644724415570371data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.5720156983871107/gml31/stations_gml31.properties (No such file or directory)
  ... 38 more
java.lang.RuntimeException: java.io.FileNotFoundException: target/app-schema-mock5322364471320973198data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.5720156983871107/gml31/stations_gml31.properties (No such file or directory)
Caused by: java.io.FileNotFoundException: target/app-schema-mock5322364471320973198data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.5720156983871107/gml31/stations_gml31.properties (No such file or directory)
  ... 38 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.508 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.427 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.982 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.744 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.927 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.434 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.622 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.563 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.238 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.625 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.848 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.632 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.935 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.021 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.256 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.915 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.248 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.707 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.211 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.876 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.869 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.186 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.883 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.776 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.196 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.962 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.617 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.662 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.984 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.56 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.379 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.493 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.946 sec
Results :
Tests in error:
  globalServiceNamespacesWfs11(org.geoserver.test.NamespacesWfsTest): java.io.FileNotFoundException: target/app-schema-mock3227954378512656745data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.5720156983871107/gml31/stations_gml31.properties (No such file or directory)
  globalServiceNamespacesWfs20(org.geoserver.test.NamespacesWfsTest): java.io.FileNotFoundException: target/app-schema-mock4344386552050288744data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.5720156983871107/gml31/stations_gml31.properties (No such file or directory)
  virtualServiceNamespacesWfs11(org.geoserver.test.NamespacesWfsTest): java.io.FileNotFoundException: target/app-schema-mock4221644724415570371data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.5720156983871107/gml31/stations_gml31.properties (No such file or directory)
  virtualServiceNamespacesWfs20(org.geoserver.test.NamespacesWfsTest): java.io.FileNotFoundException: target/app-schema-mock5322364471320973198data/featureTypes/st_gml31_Station_gml31/mnt/memtmp/app-schema-stations0.5720156983871107/gml31/stations_gml31.properties (No such file or directory)
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.504 sec
Results :
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 5.791 s]
[INFO] Application Schema Integration Test ................ SUCCESS [08:58 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.513 s]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [03:40 min]
[INFO] Application Schema MongoDB Integration Test ........ SUCCESS [ 14.979 s]
[INFO] Total time: 13:14 min
[INFO] Finished at: 2017-07-05T20:53:18+00:00
[INFO] Final Memory: 50M/497M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/839/changes&gt;
