See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/877/changes>
Changes:
[andrea.aime] Adding documentation for char and word spacing
[andrea.aime] Images for char and word spacing
Started by timer
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/>
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git -c core.askpass=true fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 55e5cdb4cba31ee3f6f6c7339eaeb767439e5630 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 55e5cdb4cba31ee3f6f6c7339eaeb767439e5630
> git rev-list 9bf96e849981ee74da32f3f3c506917ef255d0a5 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/hudson6372208386276747527.sh
+ mkdir /var/lib/jenkins/.geotools
mkdir: cannot create directory `/var/lib/jenkins/.geotools': File exists
+ true
+ rm /var/lib/jenkins/.geotools/postgis.properties
rm: cannot remove `/var/lib/jenkins/.geotools/postgis.properties': No such file or directory
+ true
+ rm /var/lib/jenkins/.geotools/oracle.properties
rm: cannot remove `/var/lib/jenkins/.geotools/oracle.properties': No such file or directory
+ true
+ set +x
CREATE FUNCTION
CREATE FUNCTION
DELETE 0
INSERT 0 1
srid
4979
(1 row)
[geoserver-master-app-schema-online] $ /opt/apache-maven-3.3.9/bin/mvn -f src/extension/app-schema/pom.xml -B -Dtest.maxHeapSize=1024m -Dtest.maxPermSize=128m -fae -Papp-schema-online-test -pl !app-schema-oracle-test -Djava.io.tmpdir=/mnt/memtmp clean test
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
[INFO] Scanning for projects...
[INFO] Reactor Build Order:
[INFO]
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] Application Schema Integration Online Test with Postgis Database
[INFO] Application Schema MongoDB Integration Test
[INFO]
[INFO] Building Application Schema Support 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-app-schema ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema ---
[INFO]
[INFO] Building Application Schema Integration Test 2.12-SNAPSHOT
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-cql/18-SNAPSHOT/gt-cql-18-20170811.221727-268.pom
[INFO]
[INFO] Building Sample DataAccess Integration Test 2.12-SNAPSHOT
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-cql/18-SNAPSHOT/gt-cql-18-20170811.221727-268.jar
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-render/18-SNAPSHOT/gt-render-18-20170811.221743-268.jar
[INFO]
[INFO] Building Application Schema Integration Online Test with Postgis Database 2.12-SNAPSHOT
[INFO]
[INFO] Building Application Schema MongoDB Integration Test 2.12-SNAPSHOT
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 6.138 s]
[INFO] Application Schema Integration Test ................ FAILURE [01:04 min]
[INFO] Sample DataAccess Integration Test ................. FAILURE [01:03 min]
[INFO] Application Schema Integration Online Test with Postgis Database FAILURE [ 0.094 s]
[INFO] Application Schema MongoDB Integration Test ........ FAILURE [ 0.096 s]
[INFO] BUILD FAILURE
[INFO] Total time: 02:15 min
[INFO] Finished at: 2017-08-12T20:42:21+00:00
[INFO] Final Memory: 51M/363M
[ERROR] Failed to execute goal on project gs-app-schema-test: Could not resolve dependencies for project org.geoserver.extension:gs-app-schema-test:jar:2.12-SNAPSHOT: Failed to collect dependencies at org.geoserver:gs-main:jar:2.12-SNAPSHOT -> org.geotools:gt-cql:jar:18-SNAPSHOT: Failed to read artifact descriptor for org.geotools:gt-cql:jar:18-SNAPSHOT: Could not transfer artifact org.geotools:gt-cql:pom:18-20170811.221727-268 from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR] Failed to execute goal on project gs-sample-data-access-test: Could not resolve dependencies for project org.geoserver.extension:gs-sample-data-access-test:jar:2.12-SNAPSHOT: The following artifacts could not be resolved: org.geotools:gt-cql:jar:18-SNAPSHOT, org.geotools:gt-render:jar:18-SNAPSHOT: Could not transfer artifact org.geotools:gt-cql:jar:18-20170811.221727-268 from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR] Failed to execute goal on project gs-app-schema-postgis-test: Could not resolve dependencies for project org.geoserver.extension:gs-app-schema-postgis-test:jar:2.12-SNAPSHOT: The following artifacts could not be resolved: org.geotools:gt-cql:jar:18-SNAPSHOT, org.geotools:gt-render:jar:18-SNAPSHOT: Failure to transfer org.geotools:gt-cql:jar:18-20170811.221727-268 from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer artifact org.geotools:gt-cql:jar:18-20170811.221727-268 from/to boundless (https://repo.boundlessgeo.com/main/\): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR] Failed to execute goal on project gs-app-schema-mongo-test: Could not resolve dependencies for project org.geoserver.extension:gs-app-schema-mongo-test:jar:2.12-SNAPSHOT: The following artifacts could not be resolved: org.geotools:gt-cql:jar:18-SNAPSHOT, org.geotools:gt-render:jar:18-SNAPSHOT: Failure to transfer org.geotools:gt-cql:jar:18-20170811.221727-268 from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer artifact org.geotools:gt-cql:jar:18-20170811.221727-268 from/to boundless (https://repo.boundlessgeo.com/main/\): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
