[Geoserver-devel] Build failed in Jenkins: geoserver-master-app-schema-online #922
it seems that the oracle instance database is not responding:
psql: could not connect to server: Connection timed out
	Is the server running on host "184.154.70.224" and accepting
	TCP/IP connections on port 5432?
Full log:
http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/922/consoleText
Nuno Oliveira
On 09/27/2017 09:42 PM, monitor@anonymised.com wrote:
See [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/922/changes>](http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/922/changes)
Changes:
[nuno.oliveira] [GEOS-8283] Add an extension point for new tabs in GeoServer status
[nuno.oliveira] [GEOS-8285] Add clause in GeoServer LICENSE for OSHI library
[nuno.oliveira] [GEOS-8284] Create status monitoring community module
[github] Rest API Swagger doc QA - coverages and coveragestores (#2525)
[github] Swagger API Docs - proper style example (#2532)
[github] Rest API Swagger doc QA - namespaces (#2528)
[github] Rest API Swagger doc QA - layer groups (#2531)
[github] Rest API Swagger doc QA - layers (#2534)
[github] Rest API Swagger doc QA - templates (#2537)
[github] Rest API Swagger doc QA - security (#2539)
[github] Rest API Swagger doc QA - settings (#2536)
[github] Rest API Swagger doc QA - wms and wmts stores and layers (#2527)
[tbarsballe] [GEOS-8300] Prevent extension from overriding format parameter when
[tbarsballe] Rest API Swagger doc QA - resources
[github] Rest API Swagger doc QA - datastores and featuretypes (#2526)
[tbarsballe] Swagger doc QA - fix docbuild
[github] Support for MBStyle StyleGroups (#2523)
[github] [GEOS-8289] AbstractCatalogFacade.resolve(StyleInfo) resolves the
[nuno.oliveira] [GEOS-8302] Statatus monitoring community module is failing with
[emerkle] Fix POSTing for GeoGig Import
Started by timer
Building in workspace [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/>](http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/)
 > git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
 > git --version # timeout=10
 > git -c core.askpass=true fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
 > git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 24a056923c443326b18f2eed7d2a21ce51510d92 (origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 24a056923c443326b18f2eed7d2a21ce51510d92
 > git rev-list d7295eab90f3102a714ae294c12bac895f652f68 # timeout=10
[geoserver-master-app-schema-online] $ /bin/sh -xe /tmp/hudson3940528431788471740.sh
+ mkdir /var/lib/jenkins/.geotools
mkdir: cannot create directory `/var/lib/jenkins/.geotools': File exists
+ true
+ rm /var/lib/jenkins/.geotools/postgis.properties
rm: cannot remove `/var/lib/jenkins/.geotools/postgis.properties': No such file or directory
+ true
+ rm /var/lib/jenkins/.geotools/oracle.properties
rm: cannot remove `/var/lib/jenkins/.geotools/oracle.properties': No such file or directory
+ true
+ set +x
Build step 'Execute shell' marked build as failure
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:      +39 0584 1660272
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Hi Nuno,
Thanks for checking the cause of this failure. I’ve gotten in touch with Nick (Boundless Devops) and we are looking into the issue.
Torben
On Thu, Sep 28, 2017 at 3:50 AM, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
Full log:
Nuno Oliveira
Changes:
Started by timer
 > git config remote.origin.url git://[github.com/geoserver/geoserver.git](http://github.com/geoserver/geoserver.git) # timeout=10
Fetching upstream changes from git://[github.com/geoserver/geoserver.git](http://github.com/geoserver/geoserver.git)
 > git -c core.askpass=true fetch --tags --progress git://[github.com/geoserver/geoserver.git](http://github.com/geoserver/geoserver.git) +refs/heads/*:refs/remotes/origin/*
+ true
+ true
+ true
+ set +x
Nuno Oliveira
@nmcoliveira
Software Engineer
