See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/926/>
[...truncated 2080 lines...]
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sample-data-access-test ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sample-data-access-test ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/sample-data-access-test/target/surefire-reports>
T E S T S
Running org.geoserver.test.SampleDataAccessWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.753 sec
Results :
[INFO]
[INFO] Building Application Schema Integration Online Test with Postgis Database 2.13-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-postgis-test ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-app-schema-postgis-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-postgis-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-postgis-test ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/src/main/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-postgis-test ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-postgis-test ---
[INFO] Copying 165 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-postgis-test ---
[INFO] Compiling 137 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/test-classes>
[WARNING] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[26,21\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[159,11\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[165,12\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[WARNING] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/onlineTest/support/AbstractReferenceDataSetup.java>:\[165,39\] CachedRowSetImpl is internal proprietary API and may be removed in a future release
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-postgis-test ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-postgis-test/target/surefire-reports>
T E S T S
Running org.geoserver.test.BBox3DTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.927 sec
Running org.geoserver.test.BBoxFilterTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.59 sec
Running org.geoserver.test.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.692 sec
Running org.geoserver.test.ConnectionUsageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.038 sec
Running org.geoserver.test.DefaultIdTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.921 sec
Running org.geoserver.test.DuplicatePropertiesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.766 sec
Running org.geoserver.test.DuplicateTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.993 sec
Running org.geoserver.test.EncodeIfEmptyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.135 sec
Running org.geoserver.test.FeatureChainingSharedConnectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.07 sec
Running org.geoserver.test.FeatureChainingWfsTest
Tests run: 32, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.525 sec
Running org.geoserver.test.FeatureGML32Test
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.36 sec
Running org.geoserver.test.GUChainNoIDMFTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.526 sec
Running org.geoserver.test.GetPropertyValueTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.529 sec
Running org.geoserver.test.Gsml30WfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.302 sec
Running org.geoserver.test.Gsml32BoreholeIntervalWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.598 sec
Running org.geoserver.test.Gsml32BoreholeWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.765 sec
Running org.geoserver.test.IdFunctionWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.994 sec
Running org.geoserver.test.IdFunctionWfsWithJoiningTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.817 sec
Running org.geoserver.test.IdNotEncodedTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.248 sec
Running org.geoserver.test.InvalidColumnTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.411 sec
Running org.geoserver.test.LocalResolveFeatureChainingByRefTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.847 sec
Running org.geoserver.test.LocalResolveTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.572 sec
Running org.geoserver.test.MappingNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.715 sec
Running org.geoserver.test.MeasureTypeBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.39 sec
Running org.geoserver.test.MultivaluedXlinkHrefTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.147 sec
Running org.geoserver.test.NamespacesWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.876 sec
Running org.geoserver.test.NestedIdSupportTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.093 sec
Running org.geoserver.test.Observation_2_0_WfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.96 sec
Running org.geoserver.test.PagingTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.113 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.268 sec
Running org.geoserver.test.PolymorphismWfsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.714 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.841 sec
Running org.geoserver.test.PropertySelectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.65 sec
Running org.geoserver.test.Reprojection3DTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.087 sec
Running org.geoserver.test.RestconfigWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.591 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.334 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.843 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.498 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.992 sec
Running org.geoserver.test.SecuredFeatureChainingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.278 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.629 sec
Running org.geoserver.test.SortByTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.558 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.463 sec
Running org.geoserver.test.StringConstantIdWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.855 sec
Running org.geoserver.test.SubstitutionGroupCoverageWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.53 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.193 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.002 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.787 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.878 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.945 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.303 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.391 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.109 sec
Running org.geoserver.test.XPathPredicateTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.336 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.763 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.804 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.48 sec
Running org.geoserver.test.web.Gml311LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.793 sec
Running org.geoserver.test.web.Gml32LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.302 sec
Results :
Tests run: 197, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] Building Application Schema MongoDB Integration Test 2.13-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema-mongo-test ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-mongo-test/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-app-schema-mongo-test ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema-mongo-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-app-schema-mongo-test ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-mongo-test/src/main/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-mongo-test/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-app-schema-mongo-test ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-app-schema-mongo-test ---
[INFO] Copying 7 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-app-schema-mongo-test ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-mongo-test/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-app-schema-mongo-test ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-mongo-test/target/surefire-reports>
T E S T S
Running org.geoserver.test.onlineTest.ComplexMongoDBTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.503 sec
Results :
[INFO] Reactor Summary:
[INFO]
[INFO] Application Schema Support ......................... SUCCESS [ 5.326 s]
[INFO] Application Schema Integration Test ................ FAILURE [ 02:54 h]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.445 s]
[INFO] Application Schema Integration Online Test with Postgis Database SUCCESS [03:59 min]
[INFO] Application Schema MongoDB Integration Test ........ SUCCESS [ 3.119 s]
[INFO] BUILD FAILURE
[INFO] Total time: 02:58 h
[INFO] Finished at: 2017-09-28T23:39:25+00:00
[INFO] Final Memory: 44M/479M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-app-schema-online/ws/src/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
