[Geoserver-devel] Build failed in Jenkins: GeoServer-Master » Application Schema Integration Test #2525
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.extension$gs-app-schema-test/2525/&gt;
[...truncated 2863 lines...]
[DEBUG] adding entry test-data/BBoxTestPropertyfile.properties
[DEBUG] adding entry test-data/Borehole.properties
[DEBUG] adding entry test-data/Borehole.xml
[DEBUG] adding entry test-data/BoreholeView.xml
[DEBUG] adding entry test-data/borehole_nestedid.properties
[DEBUG] adding entry test-data/borehole_nestedid.xml
[DEBUG] adding entry test-data/CGI_PlanarOrientation.properties
[DEBUG] adding entry test-data/CGI_PlanarOrientation.xml
[DEBUG] adding entry test-data/CompositionPartXLink32.xml
[DEBUG] adding directory test-data/DataReferenceData/
[DEBUG] adding directory test-data/DataReferenceData/gsml_CompositionPart/
[DEBUG] adding entry test-data/DataReferenceData/gsml_CompositionPart/CP_CGITermValue.xml
[DEBUG] adding entry test-data/DataReferenceData/gsml_CompositionPart/gsml_CompositionPart.xml
[DEBUG] adding entry test-data/DataReferenceData/gsml_CompositionPart/gsml_ConstituentPart.xml
[DEBUG] adding entry test-data/DataReferenceData/gsml_CompositionPart/gsml_Mineral.xml
[DEBUG] adding entry test-data/DataReferenceData/gsml_CompositionPart/RockMaterial.xml
[DEBUG] adding directory test-data/DataReferenceData/gsml_Contact/
[DEBUG] adding entry test-data/DataReferenceData/gsml_Contact/gsml_Contact.xml
[DEBUG] adding directory test-data/DataReferenceData/gsml_DisplacementEvent/
[DEBUG] adding entry test-data/DataReferenceData/gsml_DisplacementEvent/gsml_DisplacementEvent.xml
[DEBUG] adding directory test-data/DataReferenceData/gsml_GeologicEvent/
[DEBUG] adding entry test-data/DataReferenceData/gsml_GeologicEvent/GE_CGITermValue.xml
[DEBUG] adding entry test-data/DataReferenceData/gsml_GeologicEvent/gsml_GeologicEvent.xml
[DEBUG] adding directory test-data/DataReferenceData/gsml_GeologicUnit/
[DEBUG] adding entry test-data/DataReferenceData/gsml_GeologicUnit/gsml_GeologicUnit.xml
[DEBUG] adding entry test-data/DataReferenceData/gsml_GeologicUnit/gsml_PhysicalDescription.xml
[DEBUG] adding entry test-data/DataReferenceData/gsml_GeologicUnit/GU_CGITermValue.xml
[DEBUG] adding directory test-data/DataReferenceData/gsml_MappedFeature/
[DEBUG] adding entry test-data/DataReferenceData/gsml_MappedFeature/gsml_MappedFeature.xml
[DEBUG] adding entry test-data/DataReferenceData/gsml_MappedFeature/MF_CGITermValue.xml
[DEBUG] adding directory test-data/DataReferenceData/gsml_ShearDisplacementStructure/
[DEBUG] adding entry test-data/DataReferenceData/gsml_ShearDisplacementStructure/gsml_ShearDisplacementStructure.xml
[DEBUG] adding entry test-data/duplicateProperties.properties
[DEBUG] adding entry test-data/duplicateProperties.xml
[DEBUG] adding entry test-data/duplicateProperties.xsd
[DEBUG] adding entry test-data/DuplicateTypeTest.properties
[DEBUG] adding entry test-data/DuplicateTypeTest.xml
[DEBUG] adding entry test-data/DuplicateTypeTest.xsd
[DEBUG] adding entry test-data/er_MineralOccurrence.properties
[DEBUG] adding entry test-data/er_MineralOccurrence.xml
[DEBUG] adding entry test-data/GeologicUnit32.xml
[DEBUG] adding entry test-data/GeologicUnit32Resolve.xml
[DEBUG] adding entry test-data/GeologicUnitGetId.xml
[DEBUG] adding entry test-data/GeologicUnitXLink32.xml
[DEBUG] adding entry test-data/geosciml-portrayal.xsd
[DEBUG] adding entry test-data/Gsml30WfsTest.properties
[DEBUG] adding entry test-data/Gsml30WfsTest.xml
[DEBUG] adding entry test-data/Gsml32Borehole.properties
[DEBUG] adding entry test-data/Gsml32Borehole.xml
[DEBUG] adding entry test-data/Gsml32BoreholeInterval.xml
[DEBUG] adding entry test-data/GUInLineNoIDMF.xml
[DEBUG] adding entry test-data/HydrogeologicUnit.xsd
[DEBUG] adding entry test-data/HydrostratigraphicUnit.xml
[DEBUG] adding directory test-data/img/
[DEBUG] adding entry test-data/img/datareference_simplelithology.png
[DEBUG] adding entry test-data/img/datareference_stratchart.png
[DEBUG] adding entry test-data/img/mappedfeature.png
[DEBUG] adding entry test-data/img/outcrop.png
[DEBUG] adding entry test-data/img/outcrop_3857.png
[DEBUG] adding entry test-data/img/posacc.png
[DEBUG] adding entry test-data/InvalidColumnGeologicUnit.properties
[DEBUG] adding entry test-data/InvalidColumnGeologicUnit.xml
[DEBUG] adding entry test-data/MappedFeature.properties
[DEBUG] adding entry test-data/MappedFeature.xml
[DEBUG] adding entry test-data/MappedFeature32Property.xml
[DEBUG] adding entry test-data/MappedFeature32Resolve.xml
[DEBUG] adding entry test-data/MappedFeature3D.properties
[DEBUG] adding entry test-data/MappedFeature3D.xml
[DEBUG] adding entry test-data/MappedFeatureGetId.xml
[DEBUG] adding entry test-data/MappedFeatureNameOne.properties
[DEBUG] adding entry test-data/MappedFeatureNameTwo.properties
[DEBUG] adding entry test-data/MappedFeatureNoId.properties
[DEBUG] adding entry test-data/MappedFeatureNoId.xml
[DEBUG] adding entry test-data/MappedFeaturePoints.properties
[DEBUG] adding entry test-data/MappedFeaturePolygons.properties
[DEBUG] adding entry test-data/MappedFeaturePropertySelection.xml
[DEBUG] adding entry test-data/MappedFeatureStringConstantId.xml
[DEBUG] adding entry test-data/MappedFeatureSubstitutionGroup.xml
[DEBUG] adding entry test-data/MappedFeatureWithHyphen.xml
[DEBUG] adding entry test-data/MappedFeatureWithNestedName.properties
[DEBUG] adding entry test-data/MappedFeatureWms.properties
[DEBUG] adding entry test-data/MappedFeatureWms.xml
[DEBUG] adding entry test-data/MappedFeatureXlink.xml
[DEBUG] adding entry test-data/MappedFeatureXlink32.xml
[DEBUG] adding entry test-data/mappedinterval.properties
[DEBUG] adding entry test-data/MappedInterval.xml
[DEBUG] adding entry test-data/MeasureTypeBindingTest.properties
[DEBUG] adding entry test-data/MeasureTypeBindingTest.xml
[DEBUG] adding entry test-data/Nillable.properties
[DEBUG] adding entry test-data/Nillable.xml
[DEBUG] adding entry test-data/nillableSimpleContentInteger.xml
[DEBUG] adding entry test-data/NillableWithError.xml
[DEBUG] adding entry test-data/ObservationAnyTypeTest.xml
[DEBUG] adding entry test-data/ObservationMethod.properties
[DEBUG] adding entry test-data/ObservationMethod.xml
[DEBUG] adding entry test-data/ObservationMethodWithHyphen.xml
[DEBUG] adding entry test-data/Observation_2_0_EncodeIfEmpty_Test.xml
[DEBUG] adding entry test-data/Observation_2_0_Test.xml
[DEBUG] adding entry test-data/PolymorphicFeature.properties
[DEBUG] adding entry test-data/polymorphism.xml
[DEBUG] adding entry test-data/polymorphism.xsd
[DEBUG] adding entry test-data/polymorphism_inline.xml
[DEBUG] adding entry test-data/ResourceAccessManagerContext.xml
[DEBUG] adding entry test-data/SameNameDiffNamespace.properties
[DEBUG] adding entry test-data/SameNameDiffNamespace.xml
[DEBUG] adding entry test-data/SameNameDiffNamespace.xsd
[DEBUG] adding directory test-data/schemas/
[DEBUG] adding directory test-data/schemas/csml/
[DEBUG] adding entry test-data/schemas/csml/csmlMain.xsd
[DEBUG] adding directory test-data/schemas/gmlcov/
[DEBUG] adding directory test-data/schemas/gmlcov/1.0/
[DEBUG] adding entry test-data/schemas/gmlcov/1.0/coverage.xsd
[DEBUG] adding directory test-data/schemas/sweCommon/
[DEBUG] adding directory test-data/schemas/sweCommon/2.0/
[DEBUG] adding entry test-data/schemas/sweCommon/2.0/advanced_encodings.xsd
[DEBUG] adding entry test-data/schemas/sweCommon/2.0/basic_types.xsd
[DEBUG] adding entry test-data/schemas/sweCommon/2.0/block_components.xsd
[DEBUG] adding entry test-data/schemas/sweCommon/2.0/choice_components.xsd
[DEBUG] adding entry test-data/schemas/sweCommon/2.0/record_components.xsd
[DEBUG] adding entry test-data/schemas/sweCommon/2.0/simple_components.xsd
[DEBUG] adding entry test-data/schemas/sweCommon/2.0/simple_encodings.xsd
[DEBUG] adding entry test-data/schemas/sweCommon/2.0/swe.xsd
[DEBUG] adding directory test-data/schemas/waterml/
[DEBUG] adding directory test-data/schemas/waterml/DR/
[DEBUG] adding directory test-data/schemas/waterml/DR/2.0/
[DEBUG] adding entry test-data/schemas/waterml/DR/2.0/timeseries-domain-range.xsd
[DEBUG] adding entry test-data/schemas/wml2dr_catalog.xml
[DEBUG] adding entry test-data/SecondaryNamespace.xml
[DEBUG] adding entry test-data/secondaryNamespace.xsd
[DEBUG] adding entry test-data/SecondaryNamespacePropertyfile.properties
[DEBUG] adding entry test-data/SimpleAttributeFeatureChainTest.xml
[DEBUG] adding entry test-data/SpecimenWfsTest.properties
[DEBUG] adding entry test-data/SpecimenWfsTest.xml
[DEBUG] adding entry test-data/SRSReprojectionTest.xml
[DEBUG] adding entry test-data/SRSTest.xml
[DEBUG] adding entry test-data/SRSTestPropertyfile.properties
[DEBUG] adding directory test-data/styles/
[DEBUG] adding entry test-data/styles/cgi-simplelithology-2008.sld
[DEBUG] adding entry test-data/styles/Default.sld
[DEBUG] adding entry test-data/styles/ics-stratchart-2008.sld
[DEBUG] adding entry test-data/styles/mappedfeaturebyname.sld
[DEBUG] adding entry test-data/styles/outcropcharacter.sld
[DEBUG] adding entry test-data/styles/positionalaccuracy.sld
[DEBUG] adding entry test-data/styles/positionalaccuracy21.sld
[DEBUG] adding entry test-data/timeseries.properties
[DEBUG] adding entry test-data/TimeSeries.xml
[DEBUG] adding entry test-data/TimeSeriesInline.xml
[DEBUG] adding entry test-data/WaterMLTimeSeriesTest.xml
[DEBUG] adding directory test-data/WfsOnlineTest/
[DEBUG] adding directory test-data/WfsOnlineTest/gsml_DisplacementEvent/
[DEBUG] adding entry test-data/WfsOnlineTest/gsml_DisplacementEvent/gsml_DisplacementEvent.xml
[DEBUG] adding directory test-data/WfsOnlineTest/gsml_ShearDisplacementStructure/
[DEBUG] adding entry test-data/WfsOnlineTest/gsml_ShearDisplacementStructure/gsml_ShearDisplacementStructure.xml
[DEBUG] adding directory test-data/WmsDataReferenceData/
[DEBUG] adding directory test-data/WmsDataReferenceData/gsml_GeologicEvent/
[DEBUG] adding entry test-data/WmsDataReferenceData/gsml_GeologicEvent/gsml_GeologicEvent.xml
[DEBUG] adding directory test-data/WmsDataReferenceData/gsml_GeologicUnit/
[DEBUG] adding entry test-data/WmsDataReferenceData/gsml_GeologicUnit/gsml_GeologicUnit.xml
[DEBUG] adding directory test-data/WmsDataReferenceData/gsml_MappedFeature/
[DEBUG] adding entry test-data/WmsDataReferenceData/gsml_MappedFeature/gsml_MappedFeature.xml
[DEBUG] adding entry test-data/XlinkGeometry.properties
[DEBUG] adding entry test-data/XlinkGeometry.xml
[DEBUG] adding entry test-data/XlinkGeometry.xsd
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-app-schema-test ---
[DEBUG] Configuring mojo org.apache.maven.plugins:maven-dependency-plugin:2.1:copy-dependencies from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-dependency-plugin:2.1, parent: sun.misc.Launcher$AppClassLoader@anonymised.com]
[DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-dependency-plugin:2.1:copy-dependencies' with basic configurator -->
[DEBUG] (s) copyPom = false
[DEBUG] (f) excludeTransitive = false
[DEBUG] (s) failOnMissingClassifierArtifact = true
[DEBUG] (f) includeArtifactIds = gt-api,gwc-core
[DEBUG] (f) includeGroupIds = org.geotools,org.geowebcache
[DEBUG] (s) local = id: local
      url: file:///C:/Windows/system32/config/systemprofile/.m2/repository/
   layout: none
[DEBUG] (s) markersDirectory = C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\target\dependency-maven-plugin-markers
[DEBUG] (f) outputAbsoluteArtifactFilename = false
[DEBUG] (s) outputDirectory = C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\target\dependency
[DEBUG] (f) overWriteIfNewer = true
[DEBUG] (f) overWriteReleases = false
[DEBUG] (f) overWriteSnapshots = false
[DEBUG] (f) project = MavenProject: org.geoserver.extension:gs-app-schema-test:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\pom.xml
[DEBUG] (f) reactorProjects = [MavenProject: org.geoserver:geoserver:2.9-SNAPSHOT @ c:\.jenkins\jobs\GeoServer-Master\workspace\src\pom.xml, MavenProject: org.geoserver:gs-platform:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\platform\pom.xml, MavenProject: org.geoserver:gs-ows:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\ows\pom.xml, MavenProject: org.geoserver:gs-main:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\main\pom.xml, MavenProject: org.geoserver:gs-security:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\security\pom.xml, MavenProject: org.geoserver.security:gs-sec-jdbc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\security\jdbc\pom.xml, MavenProject: org.geoserver.security:gs-sec-ldap:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\security\ldap\pom.xml, MavenProject: org.geoserver:gs-wcs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs\pom.xml, MavenProject: org.geoserver:gs-wcs1_0:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs1_0\pom.xml, MavenProject: org.geoserver:gs-wcs1_1:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs1_1\pom.xml, MavenProject: org.geoserver:gs-wcs2_0:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wcs2_0\pom.xml, MavenProject: org.geoserver:gs-wfs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wfs\pom.xml, MavenProject: org.geoserver:gs-wms:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\wms\pom.xml, MavenProject: org.geoserver:gs-kml:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\kml\pom.xml, MavenProject: org.geoserver:gs-gwc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\gwc\pom.xml, MavenProject: org.geoserver:gs-rest:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\rest\pom.xml, MavenProject: org.geoserver:gs-restconfig:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\restconfig\pom.xml, MavenProject: org.geoserver:web:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\pom.xml, MavenProject: org.geoserver.web:gs-web-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\core\pom.xml, MavenProject: org.geoserver.web:gs-web-wms:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\wms\pom.xml, MavenProject: org.geoserver.web:gs-web-gwc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\pom.xml, MavenProject: org.geoserver.web:gs-web-wfs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\wfs\pom.xml, MavenProject: org.geoserver.web:gs-web-demo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\demo\pom.xml, MavenProject: org.geoserver.web:gs-web-wcs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\wcs\pom.xml, MavenProject: org.geoserver.web:gs-web-sec:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\pom.xml, MavenProject: org.geoserver.web:gs-web-sec-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\core\pom.xml, MavenProject: org.geoserver.web:gs-web-sec-jdbc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\jdbc\pom.xml, MavenProject: org.geoserver.web:gs-web-sec-ldap:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\security\ldap\pom.xml, MavenProject: org.geoserver.web:gs-web-rest:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\rest\pom.xml, MavenProject: org.geoserver.web:gs-web-app:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\web\app\pom.xml, MavenProject: org.geoserver:community:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\community\pom.xml, MavenProject: org.geoserver:extension:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\pom.xml, MavenProject: org.geoserver.extension:gs-app-schema:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\pom.xml, MavenProject: org.geoserver.extension:gs-app-schema-test:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\pom.xml, MavenProject: org.geoserver.extension:gs-sample-data-access-test:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\sample-data-access-test\pom.xml, MavenProject: org.geoserver.extension:gs-arcsde:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\arcsde\pom.xml, MavenProject: org.geoserver.extension:gs-geosearch:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\geosearch\pom.xml, MavenProject: org.geoserver.extension:gs-h2:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\h2\pom.xml, MavenProject: org.geoserver.extension:gs-sqlserver:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\sqlserver\pom.xml, MavenProject: org.geoserver.extension:gs-oracle:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\oracle\pom.xml, MavenProject: org.geoserver.extension:gs-mysql:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\mysql\pom.xml, MavenProject: org.geoserver.extension:gs-db2:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\db2\pom.xml, MavenProject: org.geoserver.extension:gs-imagemap:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\imagemap\pom.xml, MavenProject: org.geoserver.extension:gs-gdal:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\gdal\pom.xml, MavenProject: org.geoserver.extension:gs-jp2k:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\jp2k\pom.xml, MavenProject: org.geoserver.extension:gs-ogr:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\pom.xml, MavenProject: org.geoserver.extension:gs-ogr-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\ogr-core\pom.xml, MavenProject: org.geoserver.extension:gs-ogr-wfs:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\ogr-wfs\pom.xml, MavenProject: org.geoserver.extension:gs-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\pom.xml, MavenProject: org.geoserver.extension:gs-wps-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-core\pom.xml, MavenProject: org.geoserver.extension:gs-ogr-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\ogr\ogr-wps\pom.xml, MavenProject: org.geoserver.extension:gs-excel:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\excel\pom.xml, MavenProject: org.geoserver.extension:gs-charts:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\charts\pom.xml, MavenProject: org.geoserver.extension:gs-feature-pregeneralized:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\feature-pregeneralized\pom.xml, MavenProject: org.geoserver.extension:gs-imagemosaic-jdbc:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\imagemosaic-jdbc\pom.xml, MavenProject: org.geoserver.extension:gs-control-flow:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\control-flow\pom.xml, MavenProject: org.geoserver.extension:gs-wps-cluster-hazelcast:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-cluster-hazelcast\pom.xml, MavenProject: org.geoserver.extension:gs-web-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\web-wps\pom.xml, MavenProject: org.geoserver.extension:gs-querylayer:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\querylayer\pom.xml, MavenProject: org.geoserver.extension:gs-teradata:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\teradata\pom.xml, MavenProject: org.geoserver.extension:gs-monitor:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\monitor\pom.xml, MavenProject: org.geoserver.extension:gs-monitor-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\monitor\core\pom.xml, MavenProject: org.geoserver.extension:gs-monitor-hibernate:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\monitor\hibernate\pom.xml, MavenProject: org.geoserver.extension:gs-security:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\pom.xml, MavenProject: org.geoserver.security:gs-sec-cas:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\cas\pom.xml, MavenProject: org.geoserver.extension:gs-web-sec:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\web\pom.xml, MavenProject: org.geoserver.security:gs-web-sec-cas:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\security\web\web-cas\pom.xml, MavenProject: org.geoserver:gs-xslt:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\xslt\pom.xml, MavenProject: org.geoserver.extension:gs-inspire:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\inspire\pom.xml, MavenProject: org.geoserver.extension:gs-css:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\css\pom.xml, MavenProject: org.geoserver:gs-csw:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\pom.xml, MavenProject: org.geoserver.csw:gs-csw-api:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\api\pom.xml, MavenProject: org.geoserver.csw:gs-csw-simple-store:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\simple-store\pom.xml, MavenProject: org.geoserver.csw:gs-csw-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\core\pom.xml, MavenProject: org.geoserver.csw:gs-web-csw:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\csw\web-csw\pom.xml, MavenProject: org.geoserver.extension:gs-dxf:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\dxf\pom.xml, MavenProject: org.geoserver.extension:gs-dxf-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\dxf\core\pom.xml, MavenProject: org.geoserver.extension:gs-dxf-wps:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\dxf\wps\pom.xml, MavenProject: org.geoserver.extension:gs-printing:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\printing\pom.xml, MavenProject: org.geoserver.extension:gs-wcs2_0-eo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wcs2_0-eo\pom.xml, MavenProject: org.geoserver.extension:gs-wcs2_0-eo-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wcs2_0-eo\core\pom.xml, MavenProject: org.geoserver.extension:gs-web-wcs2_0-eo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wcs2_0-eo\web\pom.xml, MavenProject: org.geoserver.extension:gs-libjpeg-turbo:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\libjpeg-turbo\pom.xml, MavenProject: org.geoserver:gs-importer:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\pom.xml, MavenProject: org.geoserver.importer:gs-importer-core:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\core\pom.xml, MavenProject: org.geoserver.importer:gs-importer-rest:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\rest\pom.xml, MavenProject: org.geoserver.importer:gs-importer-bdb:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\bdb\pom.xml, MavenProject: org.geoserver.importer:gs-importer-web:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\importer\web\pom.xml, MavenProject: org.geoserver.extension:gs-grib:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\grib\pom.xml, MavenProject: org.geoserver.extension:gs-netcdf:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\netcdf\pom.xml, MavenProject: org.geoserver.extension:gs-netcdf-out:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\netcdf-out\pom.xml, MavenProject: org.geoserver:gs-release:2.9-SNAPSHOT @ C:\.jenkins\jobs\GeoServer-Master\workspace\src\release\pom.xml]
[DEBUG] (s) remoteRepos = [ id: boundless
      url: https://repo.boundlessgeo.com/main/
   layout: default
snapshots: [enabled => true, update => daily]
releases: [enabled => true, update => daily]
, id: osgeo
      url: http://download.osgeo.org/webdav/geotools/
   layout: default
, id: maven-restlet
      url: http://maven.restlet.org
   layout: default
snapshots: [enabled => false, update => daily]
, id: hibspat
      url: http://www.hibernatespatial.org/repository
   layout: default
, id: central
      url: http://repo.maven.apache.org/maven2
   layout: default
[DEBUG] (f) silent = false
[DEBUG] (s) stripVersion = false
[DEBUG] (f) type = java-source
[DEBUG] (s) useRepositoryLayout = false
[DEBUG] (s) useSubDirectoryPerArtifact = false
[DEBUG] (s) useSubDirectoryPerType = false
[DEBUG] -- end configuration --
[INFO] Copying gt-api-15-SNAPSHOT.jar to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\target\dependency\gt-api-15-SNAPSHOT.jar
[INFO] Copying gwc-core-1.9-SNAPSHOT.jar to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\target\dependency\gwc-core-1.9-SNAPSHOT.jar
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-app-schema-test ---
[DEBUG] Configuring mojo org.apache.maven.plugins:maven-install-plugin:2.3.1:install from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-install-plugin:2.3.1, parent: sun.misc.Launcher$AppClassLoader@anonymised.com]
[DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-install-plugin:2.3.1:install' with basic configurator -->
[DEBUG] (f) artifact = org.geoserver.extension:gs-app-schema-test:jar:2.9-SNAPSHOT
[DEBUG] (f) attachedArtifacts = [org.geoserver.extension:gs-app-schema-test:test-jar:tests:2.9-SNAPSHOT, org.geoserver.extension:gs-app-schema-test:java-source:test-sources:2.9-SNAPSHOT]
[DEBUG] (f) createChecksum = false
[DEBUG] (f) localRepository = id: local
   layout: none
[DEBUG] (f) packaging = jar
[DEBUG] (f) pomFile = C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\pom.xml
[DEBUG] (f) updateReleaseInfo = false
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\target\gs-app-schema-test-2.9-SNAPSHOT.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\extension\gs-app-schema-test\2.9-SNAPSHOT\gs-app-schema-test-2.9-SNAPSHOT.jar
[DEBUG] Writing resolution tracking file C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\extension\gs-app-schema-test\2.9-SNAPSHOT\_maven.repositories
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\pom.xml to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\extension\gs-app-schema-test\2.9-SNAPSHOT\gs-app-schema-test-2.9-SNAPSHOT.pom
[DEBUG] Installing org.geoserver.extension:gs-app-schema-test:2.9-SNAPSHOT/maven-metadata.xml to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\extension\gs-app-schema-test\2.9-SNAPSHOT\maven-metadata-local.xml
[DEBUG] Installing org.geoserver.extension:gs-app-schema-test/maven-metadata.xml to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\extension\gs-app-schema-test\maven-metadata-local.xml
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\target\gs-app-schema-test-2.9-SNAPSHOT-tests.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\extension\gs-app-schema-test\2.9-SNAPSHOT\gs-app-schema-test-2.9-SNAPSHOT-tests.jar
[INFO] Installing C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\app-schema\app-schema-test\target\gs-app-schema-test-2.9-SNAPSHOT-test-sources.jar to C:\Windows\system32\config\systemprofile\.m2\repository\org\geoserver\extension\gs-app-schema-test\2.9-SNAPSHOT\gs-app-schema-test-2.9-SNAPSHOT-test-sources.jar
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.extension$gs-app-schema-test/2526/&gt;
