See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-platform/2428/>
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 10 second
[INFO]
[INFO] Building Core Platform Module 2.9-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-platform ---
[INFO] Deleting <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-platform/ws/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-platform ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-platform ---
[INFO] [GitCommitIdMojo] Running on 'C:\.jenkins\jobs\GeoServer-Master\workspace\.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Revert style encoding to platform default
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 02.12.2015 @ 22:22:58 CET
[INFO] [GitCommitIdMojo] build.timestamp = 02-dic-2015 23:14
[INFO] [GitCommitIdMojo] build.build.time = 02.12.2015 @ 23:15:18 CET
[INFO] [GitCommitIdMojo] build.branch = 35e49ee0c16e3edd64d309d251a27a828a79d407
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 35e49ee
[INFO] [GitCommitIdMojo] build.commit.id = 35e49ee0c16e3edd64d309d251a27a828a79d407
[INFO] [GitCommitIdMojo] build.commit.message.full = Revert style encoding to platform default
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-platform ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-platform/ws/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-platform ---
[INFO] Compiling 41 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-platform/ws/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-platform ---
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-platform/ws/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-platform ---
[INFO] Compiling 19 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-platform/ws/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-platform ---
[INFO] Surefire report directory: <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-platform/ws/target/surefire-reports>
T E S T S
Running org.geoserver.platform.AdvancedDispatchFilterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.125 sec
Running org.geoserver.platform.GeoServerExtensionsTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.624 sec
Running org.geoserver.platform.exception.ExceptionLocalizeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.platform.exception.GeoServerExceptionsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.platform.resource.FileSystemResourceTheoryTest
Tests run: 36, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.69 sec
Running org.geoserver.platform.resource.FileWrapperResourceTheoryTest
Tests run: 32, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 2.324 sec <<< FAILURE!
theoryAddingFileToDirectoryAddsResource(org.geoserver.platform.resource.FileWrapperResourceTheoryTest) Time elapsed: 15 sec <<< ERROR!
org.junit.experimental.theories.internal.ParameterizedAssertionError: theoryAddingFileToDirectoryAddsResource(testPaths[2])
at org.junit.experimental.theories.Theories$TheoryAnchor.reportParameterizedError(Theories.java:192)
at org.junit.experimental.theories.Theories$TheoryAnchor$1$1.evaluate(Theories.java:146)
at org.junit.experimental.theories.Theories$TheoryAnchor.runWithCompleteAssignment(Theories.java:127)
at org.junit.experimental.theories.Theories$TheoryAnchor.runWithAssignment(Theories.java:111)
at org.junit.experimental.theories.Theories$TheoryAnchor.runWithIncompleteAssignment(Theories.java:120)
at org.junit.experimental.theories.Theories$TheoryAnchor.runWithAssignment(Theories.java:109)
at org.junit.experimental.theories.Theories$TheoryAnchor.evaluate(Theories.java:96)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.lang.AssertionError:
Expected: is resource that is defined
but: was <ResourceAdaptor(C:\Windows\TEMP\junit2538536057382917061\C:\Windows\TEMP\junit2538536057382917061\DirC\newFileCreatedDirectly)>
at org.hamcrest.MatcherAssert.assertThat(MatcherAssert.java:20)
at org.junit.Assert.assertThat(Assert.java:865)
at org.junit.Assert.assertThat(Assert.java:832)
at org.geoserver.platform.resource.ResourceTheoryTest.theoryAddingFileToDirectoryAddsResource(ResourceTheoryTest.java:452)
at org.junit.experimental.theories.Theories$TheoryAnchor$2.evaluate(Theories.java:175)
at org.junit.rules.ExternalResource$1.evaluate(ExternalResource.java:48)
at org.junit.rules.ExpectedException$ExpectedExceptionStatement.evaluate(ExpectedException.java:168)
at org.junit.experimental.theories.Theories$TheoryAnchor$1$1.evaluate(Theories.java:141)
... 26 more
Running org.geoserver.platform.resource.PathsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.util.LoggerRuleTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.25 sec
Results :
Tests in error:
theoryAddingFileToDirectoryAddsResource(org.geoserver.platform.resource.FileWrapperResourceTheoryTest): theoryAddingFileToDirectoryAddsResource(testPaths[2])
Tests run: 103, Failures: 0, Errors: 1, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
