[Geoserver-devel] Build failed in Jenkins: GeoServer-Master » GeoWebCache (GWC) Module #1798
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-gwc/1798/&gt;
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO]
[INFO] Building GeoWebCache (GWC) Module 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-gwc ---
[INFO] Deleting <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-gwc/ws/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-gwc ---
[INFO] [GitCommitIdMojo] Running on 'C:\.jenkins\jobs\GeoServer-Master\workspace\.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Let GeoServerTileLayer.getMetatilingReponse propagate GeoWebCacheExceptions.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.06.2015 @ 04:45:15 CEST
[INFO] [GitCommitIdMojo] build.timestamp = 18-giu-2015 04:54
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2015 @ 05:12:14 CEST
[INFO] [GitCommitIdMojo] build.branch = cc289c2ff87ca6750596d7b37765b070e5ced8a2
[INFO] [GitCommitIdMojo] build.commit.user.email = groldan@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Gabriel Roldan
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = cc289c2
[INFO] [GitCommitIdMojo] build.commit.id = cc289c2ff87ca6750596d7b37765b070e5ced8a2
[INFO] [GitCommitIdMojo] build.commit.message.full = Let GeoServerTileLayer.getMetatilingReponse propagate GeoWebCacheExceptions.
Wrapping GeoWebCacheException with another GeoWebCacheException produces
meaningless exception messages in the log. Propagate them directly as the
method's signature already declares it throws that kind of exceptions.
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gwc ---
[INFO] Copying 0 resource
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc ---
[INFO] Compiling 41 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-gwc/ws/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayerInfoImpl.java:[27,29] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayerInfo.java:[14,29] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[161,4] error: method does not override or implement a method from a supertype
[INFO] 3 errors
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-gwc/1799/&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Add GeoServerTileLayer.setBlobStoreId(String) as per upstream API change.
[INFO] [GitCommitIdMojo] build.commit.time = 18.06.2015 @ 05:02:51 CEST
[INFO] [GitCommitIdMojo] build.timestamp = 18-giu-2015 06:24
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2015 @ 06:41:42 CEST
[INFO] [GitCommitIdMojo] build.branch = 4ea3f0a4bdeeb7a7aa97492e10c76205aa7e660c
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4ea3f0a
[INFO] [GitCommitIdMojo] build.commit.id = 4ea3f0a4bdeeb7a7aa97492e10c76205aa7e660c
[INFO] [GitCommitIdMojo] build.commit.message.full = Add GeoServerTileLayer.setBlobStoreId(String) as per upstream API change.
[INFO]
[INFO]
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[1205,4] error: method does not override or implement a method from a supertype
[INFO] 4 errors
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-gwc/1800/&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 18-giu-2015 11:03
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2015 @ 11:22:08 CEST
[INFO]
[INFO]
[INFO] 4 errors
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-gwc/1801/&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 18-giu-2015 12:35
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2015 @ 12:53:14 CEST
[INFO]
[INFO]
[INFO] 4 errors
