See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-gwc/1820/>
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO]
[INFO] Building GeoWebCache (GWC) Module 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-gwc ---
[INFO] Deleting <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-gwc/ws/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-gwc ---
[INFO] [GitCommitIdMojo] Running on 'C:\.jenkins\jobs\GeoServer-Master\workspace\.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1119 from ridethepenguin/master
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 24.06.2015 @ 12:14:53 CEST
[INFO] [GitCommitIdMojo] build.timestamp = 24-giu-2015 12:24
[INFO] [GitCommitIdMojo] build.build.time = 24.06.2015 @ 12:42:21 CEST
[INFO] [GitCommitIdMojo] build.branch = 3245f0f68a7910085b908f45c07905432194d9cd
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3245f0f
[INFO] [GitCommitIdMojo] build.commit.id = 3245f0f68a7910085b908f45c07905432194d9cd
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1119 from ridethepenguin/master
[GEOS-7086] Make sure if namespace is deleted, associated workspace is deleted too
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gwc ---
[INFO] Copying 0 resource
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc ---
[INFO] Compiling 41 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-gwc/ws/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayerInfoImpl.java:[27,29] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayerInfo.java:[14,29] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[161,4] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\layer\GeoServerTileLayer.java:[1205,4] error: method does not override or implement a method from a supertype
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\ConfigurableBlobStore.java:[548,51] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\gwc\src\main\java\org\geoserver\gwc\ConfigurableBlobStore.java:[563,51] error: cannot find symbol
[INFO] 6 errors
[JENKINS] Archiving disabled
