See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.web$gs-web-gwc/1797/>
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO]
[INFO] Building GWC UI Module 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-gwc ---
[INFO] Deleting <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.web$gs-web-gwc/ws/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-gwc ---
[INFO] [GitCommitIdMojo] Running on 'C:\.jenkins\jobs\GeoServer-Master\workspace\.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1095 from smithkm/gwc-param-ui
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.06.2015 @ 23:17:51 CEST
[INFO] [GitCommitIdMojo] build.timestamp = 17-giu-2015 23:25
[INFO] [GitCommitIdMojo] build.build.time = 17.06.2015 @ 23:51:00 CEST
[INFO] [GitCommitIdMojo] build.branch = 725743a0fef3b74b28d7e7e2895a47c9c688f22d
[INFO] [GitCommitIdMojo] build.commit.user.email = ksmith@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Kevin Smith
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 725743a
[INFO] [GitCommitIdMojo] build.commit.id = 725743a0fef3b74b28d7e7e2895a47c9c688f22d
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1095 from smithkm/gwc-param-ui
GEOS-6987 - Support new GWC Parameter Filter options via UI
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-gwc ---
[INFO] Copying 16 resources
[INFO] Copying 32 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-gwc ---
[INFO] Compiling 44 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.web$gs-web-gwc/ws/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-gwc ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.web$gs-web-gwc/ws/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-gwc ---
[INFO] Compiling 14 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.web$gs-web-gwc/ws/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[37,21] error: no suitable method found for of(CaseNormalizer)
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[77,21] error: no suitable method found for of(CaseNormalizer)
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[100,21] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[106,21] error: no suitable method found for of(CaseNormalizer)
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[115,21] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[121,21] error: no suitable method found for of(CaseNormalizer)
[ERROR] \.jenkins\jobs\GeoServer-Master\workspace\src\web\gwc\src\test\java\org\geoserver\gwc\web\layer\CaseNormalizerSubformTest.java:[130,21] error: cannot find symbol
[INFO] 7 errors
[JENKINS] Archiving disabled
