Changes:
[andrea.aime] [GEOS-7083] Allow an import to have a set of default transformations
[andrea.aime] [GEOS-7084] Add a way to execute a import from REST in a single call
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO]
[INFO] Building Importer REST Api Module 2.8-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-importer-rest ---
[INFO] Deleting <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.importer$gs-importer-rest/ws/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-importer-rest ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-rest ---
[INFO] [GitCommitIdMojo] Running on 'C:\.jenkins\jobs\GeoServer-Master\workspace\.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1121 from aaime/importer_tx_run
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 03.07.2015 @ 10:49:38 CEST
[INFO] [GitCommitIdMojo] build.timestamp = 03-lug-2015 10:54
[INFO] [GitCommitIdMojo] build.build.time = 03.07.2015 @ 11:51:45 CEST
[INFO] [GitCommitIdMojo] build.branch = 9d9002a85940d77adf7f44a14cb562886e559209
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 9d9002a
[INFO] [GitCommitIdMojo] build.commit.id = 9d9002a85940d77adf7f44a14cb562886e559209
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1121 from aaime/importer_tx_run
Importer default transformations and direct execute
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-importer-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-importer-rest ---
[INFO] Compiling 11 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.importer$gs-importer-rest/ws/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-rest ---
[INFO] skip non existing resourceDirectory <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.importer$gs-importer-rest/ws/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-importer-rest ---
[INFO] Compiling 9 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.importer$gs-importer-rest/ws/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-rest ---
[INFO] Surefire report directory: <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver.importer$gs-importer-rest/ws/target/surefire-reports>
T E S T S
Running org.geoserver.importer.rest.DataResourceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 25.603 sec
Running org.geoserver.importer.rest.DateFormatTransformTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.249 sec
Running org.geoserver.importer.rest.GdalTransformTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.importer.rest.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.315 sec
Running org.geoserver.importer.rest.ImportResourceTest
SimpleFeatureTypeImpl http://geotools.org:feature identified extends Feature(geometry:geometry,name:name,pop:pop)
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.964 sec
Running org.geoserver.importer.rest.ImporterIntegrationTest
Tests run: 4, Failures: 3, Errors: 0, Skipped: 0, Time elapsed: 126.369 sec <<< FAILURE!
testDirectExecuteAsync(org.geoserver.importer.rest.ImporterIntegrationTest) Time elapsed: 125050 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<[COMPLETE]> but was:<[PENDING]>
at org.junit.Assert.assertEquals(Assert.java:115)
at org.junit.Assert.assertEquals(Assert.java:144)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectExecuteInternal(ImporterIntegrationTest.java:239)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectExecuteAsync(ImporterIntegrationTest.java:189)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
testDirectExecuteSync(org.geoserver.importer.rest.ImporterIntegrationTest) Time elapsed: 62 sec <<< FAILURE!
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectExecuteSync(ImporterIntegrationTest.java:194)
testDefaultTransformationsInit(org.geoserver.importer.rest.ImporterIntegrationTest) Time elapsed: 62 sec <<< FAILURE!
java.lang.AssertionError: expected:<1> but was:<0>
at org.junit.Assert.fail(Assert.java:88)
at org.junit.Assert.failNotEquals(Assert.java:743)
at org.junit.Assert.assertEquals(Assert.java:118)
at org.junit.Assert.assertEquals(Assert.java:555)
at org.junit.Assert.assertEquals(Assert.java:542)
at org.geoserver.importer.rest.ImporterIntegrationTest.checkLatLonTransformedImport(ImporterIntegrationTest.java:141)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDefaultTransformationsInit(ImporterIntegrationTest.java:89)
Running org.geoserver.importer.rest.RESTDataTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.412 sec
Running org.geoserver.importer.rest.TaskResourceTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.46 sec
Results :
Failed tests: testDirectExecuteAsync(org.geoserver.importer.rest.ImporterIntegrationTest): expected:<[COMPLETE]> but was:<[PENDING]>
testDirectExecuteSync(org.geoserver.importer.rest.ImporterIntegrationTest): expected:<[COMPLETE]> but was:<[PENDING]>
testDefaultTransformationsInit(org.geoserver.importer.rest.ImporterIntegrationTest): expected:<1> but was:<0>
Tests run: 59, Failures: 3, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
