[Geoserver-devel] Build failed in Jenkins: geoserver-master-live-docs #1394
See <https://build.geoserver.org/job/geoserver-master-live-docs/1394/display/redirect?page=changes&gt;
Changes:
[Brad Hards] [GEOS-9159] Add missing commons-compress dep for excel module.
[fernandomino7] Add 'https://' protocol support for default Data Store Panel URL Model
[cmhodgson] Initial commit of MapML support.
[cmhodgson] resolved conflict with community pom
Started by an SCM change
Building remotely on apollo-slave-01 in workspace <https://build.geoserver.org/job/geoserver-master-live-docs/ws/&gt;
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 8fbd931cc88a2fb4adcd7dd98771e458a01b7ec3 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 8fbd931cc88a2fb4adcd7dd98771e458a01b7ec3
> git rev-list bde79d540ea675e487f389310ed14ce19057b33d # timeout=10
[geoserver-master-live-docs] $ mvn -f doc/en/pom.xml clean compile
[INFO] Scanning for projects...
[INFO]
[INFO] Building GeoServer English Documentation 2.16-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-docs ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (coverages) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coverages.yaml&gt;
[WARNING] Directory does not exist, or is inaccessible. No file will be evaluated.
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (coverageStores) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (datastores) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/datastores.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (featureTypes) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml&gt;
[WARNING] generated unique operationId `getFeatureTypes_0`
[WARNING] generated unique operationId `putFeatureTypes_0`
[WARNING] generated unique operationId `postFeatureTypes_0`
[WARNING] generated unique operationId `deleteFeatureTypes_0`
[WARNING] generated unique operationId `getFeatureType_0`
[WARNING] generated unique operationId `putFeatureType_0`
[WARNING] generated unique operationId `postFeatureType_0`
[WARNING] generated unique operationId `deleteFeatureType_0`
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/featuretypes/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/featuretypes/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (fonts) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (layergroups) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (layers) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[WARNING] Type is NULL for Serializable Parameter: workspaceName
[WARNING] warning! Property type "null" not found for parameter "workspaceName", using String
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (manifests) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[WARNING] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[WARNING] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (namespaces) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (owsServices) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (reload) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (security) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (settings) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (structuredCoverages) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (styles) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (template) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[WARNING] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmslayers) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmsstores) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmtslayers) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmtsstores) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (workspaces) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (monitoring) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-transforms) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-tasks) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-data) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[INFO] writing file <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (compile) @ gs-docs ---
[INFO] Executing tasks
init:
     [echo] Base directory is <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en&gt;
     [echo] Build directory is <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.16-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.16-SNAPSHOT -W -b html -d "<https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/user/source/community/mapml/index.rst&gt;:document isn't included in any toctree
[INFO] BUILD FAILURE
[INFO] Total time: 50.305 s
[INFO] Finished at: 2019-03-23T00:21:02+00:00
[INFO] Final Memory: 16M/295M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.3:run (compile) on project gs-docs: An Ant BuildException has occured: The following error occurred while executing this line:
[ERROR] <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:
[ERROR] <https://build.geoserver.org/job/geoserver-master-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 1
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <https://build.geoserver.org/job/geoserver-master-live-docs/1395/display/redirect?page=changes&gt;
