See <https://build.geoserver.org/job/geoserver-master-live-docs/1845/display/redirect>
Started by an SCM change
ln builds/lastSuccessfulBuild /var/lib/jenkins/jobs/geoserver-master-live-docs/lastSuccessful failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-master-live-docs/lastSuccessful
at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
at java.nio.file.Files.deleteIfExists(Files.java:1165)
at hudson.Util.createSymlink(Util.java:1193)
at hudson.model.Run.createSymlink(Run.java:1955)
at hudson.model.Run.updateSymlinks(Run.java:1936)
at hudson.model.Run.execute(Run.java:1814)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-master-live-docs/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-master-live-docs/lastStable
at hudson.model.Run.updateSymlinks(Run.java:1937)
Building remotely on FleetCloud i-097defbc6728da012 (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-master-live-docs/ws/>
Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-097defbc6728da012
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:957)
at hudson.FilePath.act(FilePath.java:1069)
at hudson.FilePath.act(FilePath.java:1058)
at hudson.FilePath.mkdirs(FilePath.java:1243)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1202)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1816)
java.nio.file.FileSystemException: <https://build.geoserver.org/job/geoserver-master-live-docs/ws/>: No space left on device
at sun.nio.fs.UnixException.translateToIOException(UnixException.java:100)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:116)
at sun.nio.fs.UnixFileSystemProvider.createDirectory(UnixFileSystemProvider.java:385)
at java.nio.file.Files.createDirectory(Files.java:689)
at java.nio.file.Files.createAndCheckIsDirectory(Files.java:796)
at java.nio.file.Files.createDirectories(Files.java:782)
at hudson.FilePath.mkdirs(FilePath.java:3229)
at hudson.FilePath.access$1300(FilePath.java:210)
at hudson.FilePath$Mkdirs.invoke(FilePath.java:1251)
at hudson.FilePath$Mkdirs.invoke(FilePath.java:1247)
at hudson.FilePath$FileCallableWrapper.call(FilePath.java:3042)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.lang.Thread.run(Thread.java:834)
See <https://build.geoserver.org/job/geoserver-master-live-docs/1846/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1847/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1848/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1849/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1850/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1851/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1852/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1853/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1854/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1855/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1856/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1857/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1858/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1859/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1860/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1861/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1862/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1863/display/redirect>
See <https://build.geoserver.org/job/geoserver-master-live-docs/1864/display/redirect>
