[Geoserver-devel] Build failed in Jenkins: geoserver-master-live-docs #392
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/392/&gt;
Started by an SCM change
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/&gt;
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git -c core.askpass=true fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision bc25ccb22010a57aa9cc91cb4bf76cba088244d6 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f bc25ccb22010a57aa9cc91cb4bf76cba088244d6
java.io.IOException: Could not checkout bc25ccb22010a57aa9cc91cb4bf76cba088244d6
  at hudson.plugins.git.GitSCM.checkout(GitSCM.java:964)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:1320)
  at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:609)
  at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:88)
  at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:518)
  at hudson.model.Run.execute(Run.java:1689)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
  at hudson.model.ResourceController.execute(ResourceController.java:88)
  at hudson.model.Executor.run(Executor.java:231)
Caused by: hudson.plugins.git.GitLockFailedException: Could not lock repository. Please try again
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$9.execute(CliGitAPIImpl.java:1987)
  at hudson.plugins.git.GitSCM.checkout(GitSCM.java:961)
  ... 8 more
Caused by: hudson.plugins.git.GitException: Command "git checkout -f bc25ccb22010a57aa9cc91cb4bf76cba088244d6" returned status code 128:
stdout:
stderr: fatal: Unable to create '<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/.git/index.lock’>: File exists.
If no other git process is currently running, this probably means a
git process crashed in this repository earlier. Make sure no other git
process is running and remove the file manually to continue.
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1719)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:63)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$9.execute(CliGitAPIImpl.java:1984)
  ... 9 more
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/393/&gt;
