[Geoserver-devel] Build failed in Jenkins: geoserver-master-live-docs #831
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/831/changes&gt;
Changes:
[ben] Restrict hamcrest-library to test scope and harmonise versions
Started by user Hudson
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/&gt;
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git -c core.askpass=true fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision b997e136e5871948a2b8915e22aa4330e41680ad (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f b997e136e5871948a2b8915e22aa4330e41680ad
> git rev-list e632de28d460b4b25ca90fa5af176c9a26cc2a1f # timeout=10
[geoserver-master-docs] $ /bin/sh -xe /tmp/hudson183779896595910812.sh
+ VER=origin/master
+ VER=master
+ BASE=/var/www/geoserver/master/doc/en
+ [ -e /var/www/geoserver/master/doc/en ]
+ cd doc/en
+ mvn compile -Puser
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
-Dmaven.multiModuleProjectDirectory system property is not set. Check $M2_HOME environment variable and mvn script match.Build step 'Execute shell' marked build as failure
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/832/&gt;
[...truncated 4111 lines...]
56/56 KB 28/42 KB 116/147 KB 52/160 KB
56/56 KB 32/42 KB 116/147 KB 52/160 KB
56/56 KB 36/42 KB 116/147 KB 52/160 KB
56/56 KB 40/42 KB 116/147 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 4/38 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 8/38 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 12/38 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 16/38 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 20/38 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 24/38 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 28/38 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 32/38 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 36/38 KB 52/160 KB
56/56 KB 42/42 KB 116/147 KB 38/38 KB 52/160 KB
Downloaded: https://repo.maven.apache.org/maven2/org/slf4j/slf4j-ext/1.7.12/slf4j-ext-1.7.12.jar (42 KB at 12.8 KB/sec)
Downloading: https://repo.maven.apache.org/maven2/org/apache/commons/commons-lang3/3.4/commons-lang3-3.4.jar
Downloaded: https://repo.maven.apache.org/maven2/ch/qos/cal10n/cal10n-api/0.8.1/cal10n-api-0.8.1.jar (38 KB at 11.3 KB/sec)
56/56 KB 4/425 KB 116/147 KB 52/160 KB
56/56 KB 8/425 KB 116/147 KB 52/160 KB
56/56 KB 12/425 KB 116/147 KB 52/160 KB
56/56 KB 16/425 KB 116/147 KB 52/160 KB
56/56 KB 20/425 KB 116/147 KB 52/160 KB
56/56 KB 24/425 KB 116/147 KB 52/160 KB
56/56 KB 28/425 KB 116/147 KB 52/160 KB
56/56 KB 32/425 KB 116/147 KB 52/160 KB
56/56 KB 36/425 KB 116/147 KB 52/160 KB
56/56 KB 40/425 KB 116/147 KB 52/160 KB
56/56 KB 44/425 KB 116/147 KB 52/160 KB
56/56 KB 48/425 KB 116/147 KB 52/160 KB
56/56 KB 52/425 KB 116/147 KB 52/160 KB
56/56 KB 56/425 KB 116/147 KB 52/160 KB
56/56 KB 60/425 KB 116/147 KB 52/160 KB
56/56 KB 64/425 KB 116/147 KB 52/160 KB
56/56 KB 68/425 KB 116/147 KB 52/160 KB
56/56 KB 72/425 KB 116/147 KB 52/160 KB
56/56 KB 76/425 KB 116/147 KB 52/160 KB
56/56 KB 80/425 KB 116/147 KB 52/160 KB
56/56 KB 84/425 KB 116/147 KB 52/160 KB
56/56 KB 88/425 KB 116/147 KB 52/160 KB
56/56 KB 92/425 KB 116/147 KB 52/160 KB
56/56 KB 96/425 KB 116/147 KB 52/160 KB
56/56 KB 100/425 KB 116/147 KB 52/160 KB
56/56 KB 104/425 KB 116/147 KB 52/160 KB
56/56 KB 108/425 KB 116/147 KB 52/160 KB
56/56 KB 112/425 KB 116/147 KB 52/160 KB
56/56 KB 116/425 KB 116/147 KB 52/160 KB
56/56 KB 120/425 KB 116/147 KB 52/160 KB
56/56 KB 124/425 KB 116/147 KB 52/160 KB
56/56 KB 128/425 KB 116/147 KB 52/160 KB
56/56 KB 132/425 KB 116/147 KB 52/160 KB
56/56 KB 136/425 KB 116/147 KB 52/160 KB
56/56 KB 140/425 KB 116/147 KB 52/160 KB
56/56 KB 144/425 KB 116/147 KB 52/160 KB
56/56 KB 148/425 KB 116/147 KB 52/160 KB
56/56 KB 152/425 KB 116/147 KB 52/160 KB
56/56 KB 156/425 KB 116/147 KB 52/160 KB
56/56 KB 160/425 KB 116/147 KB 52/160 KB
56/56 KB 160/425 KB 116/147 KB 56/160 KB
56/56 KB 160/425 KB 116/147 KB 60/160 KB
56/56 KB 160/425 KB 116/147 KB 64/160 KB
56/56 KB 164/425 KB 116/147 KB 64/160 KB
56/56 KB 168/425 KB 116/147 KB 64/160 KB
56/56 KB 172/425 KB 116/147 KB 64/160 KB
56/56 KB 176/425 KB 116/147 KB 64/160 KB
56/56 KB 176/425 KB 116/147 KB 68/160 KB
56/56 KB 176/425 KB 116/147 KB 72/160 KB
56/56 KB 176/425 KB 116/147 KB 76/160 KB
56/56 KB 176/425 KB 116/147 KB 80/160 KB
56/56 KB 180/425 KB 116/147 KB 80/160 KB
56/56 KB 184/425 KB 116/147 KB 80/160 KB
56/56 KB 188/425 KB 116/147 KB 80/160 KB
56/56 KB 192/425 KB 116/147 KB 80/160 KB
56/56 KB 192/425 KB 116/147 KB 84/160 KB
56/56 KB 192/425 KB 116/147 KB 88/160 KB
56/56 KB 192/425 KB 116/147 KB 92/160 KB
56/56 KB 192/425 KB 116/147 KB 96/160 KB
56/56 KB 196/425 KB 116/147 KB 96/160 KB
56/56 KB 200/425 KB 116/147 KB 96/160 KB
56/56 KB 204/425 KB 116/147 KB 96/160 KB
56/56 KB 208/425 KB 116/147 KB 96/160 KB
56/56 KB 208/425 KB 116/147 KB 100/160 KB
56/56 KB 208/425 KB 116/147 KB 104/160 KB
56/56 KB 208/425 KB 116/147 KB 108/160 KB
56/56 KB 208/425 KB 116/147 KB 112/160 KB
56/56 KB 212/425 KB 116/147 KB 112/160 KB
56/56 KB 216/425 KB 116/147 KB 112/160 KB
56/56 KB 220/425 KB 116/147 KB 112/160 KB
56/56 KB 224/425 KB 116/147 KB 112/160 KB
56/56 KB 224/425 KB 116/147 KB 116/160 KB
56/56 KB 224/425 KB 116/147 KB 120/160 KB
56/56 KB 224/425 KB 116/147 KB 124/160 KB
56/56 KB 224/425 KB 116/147 KB 128/160 KB
56/56 KB 228/425 KB 116/147 KB 128/160 KB
56/56 KB 232/425 KB 116/147 KB 128/160 KB
56/56 KB 236/425 KB 116/147 KB 128/160 KB
56/56 KB 240/425 KB 116/147 KB 128/160 KB
56/56 KB 240/425 KB 116/147 KB 132/160 KB
56/56 KB 240/425 KB 116/147 KB 136/160 KB
56/56 KB 240/425 KB 116/147 KB 140/160 KB
56/56 KB 240/425 KB 116/147 KB 144/160 KB
56/56 KB 244/425 KB 116/147 KB 144/160 KB
56/56 KB 248/425 KB 116/147 KB 144/160 KB
56/56 KB 252/425 KB 116/147 KB 144/160 KB
56/56 KB 256/425 KB 116/147 KB 144/160 KB
56/56 KB 256/425 KB 116/147 KB 148/160 KB
56/56 KB 256/425 KB 116/147 KB 152/160 KB
56/56 KB 256/425 KB 116/147 KB 156/160 KB
56/56 KB 256/425 KB 116/147 KB 160/160 KB
56/56 KB 260/425 KB 116/147 KB 160/160 KB
56/56 KB 264/425 KB 116/147 KB 160/160 KB
56/56 KB 268/425 KB 116/147 KB 160/160 KB
56/56 KB 272/425 KB 116/147 KB 160/160 KB
56/56 KB 276/425 KB 116/147 KB 160/160 KB
56/56 KB 280/425 KB 116/147 KB 160/160 KB
56/56 KB 284/425 KB 116/147 KB 160/160 KB
56/56 KB 288/425 KB 116/147 KB 160/160 KB
56/56 KB 292/425 KB 116/147 KB 160/160 KB
56/56 KB 296/425 KB 116/147 KB 160/160 KB
56/56 KB 300/425 KB 116/147 KB 160/160 KB
56/56 KB 304/425 KB 116/147 KB 160/160 KB
56/56 KB 308/425 KB 116/147 KB 160/160 KB
56/56 KB 312/425 KB 116/147 KB 160/160 KB
56/56 KB 316/425 KB 116/147 KB 160/160 KB
56/56 KB 320/425 KB 116/147 KB 160/160 KB
56/56 KB 324/425 KB 116/147 KB 160/160 KB
56/56 KB 328/425 KB 116/147 KB 160/160 KB
56/56 KB 332/425 KB 116/147 KB 160/160 KB
56/56 KB 336/425 KB 116/147 KB 160/160 KB
56/56 KB 340/425 KB 116/147 KB 160/160 KB
56/56 KB 344/425 KB 116/147 KB 160/160 KB
56/56 KB 348/425 KB 116/147 KB 160/160 KB
56/56 KB 352/425 KB 116/147 KB 160/160 KB
56/56 KB 356/425 KB 116/147 KB 160/160 KB
56/56 KB 360/425 KB 116/147 KB 160/160 KB
56/56 KB 364/425 KB 116/147 KB 160/160 KB
56/56 KB 368/425 KB 116/147 KB 160/160 KB
Downloaded: https://repo.maven.apache.org/maven2/org/osgi/org.osgi.core/4.1.0/org.osgi.core-4.1.0.jar (160 KB at 44.9 KB/sec)
56/56 KB 372/425 KB 116/147 KB
56/56 KB 376/425 KB 116/147 KB
56/56 KB 380/425 KB 116/147 KB
56/56 KB 384/425 KB 116/147 KB
56/56 KB 388/425 KB 116/147 KB
56/56 KB 392/425 KB 116/147 KB
56/56 KB 396/425 KB 116/147 KB
56/56 KB 400/425 KB 116/147 KB
56/56 KB 404/425 KB 116/147 KB
56/56 KB 408/425 KB 116/147 KB
56/56 KB 412/425 KB 116/147 KB
56/56 KB 416/425 KB 116/147 KB
56/56 KB 420/425 KB 116/147 KB
56/56 KB 424/425 KB 116/147 KB
56/56 KB 425/425 KB 116/147 KB
56/56 KB 425/425 KB 120/147 KB
56/56 KB 425/425 KB 124/147 KB
56/56 KB 425/425 KB 128/147 KB
56/56 KB 425/425 KB 132/147 KB
56/56 KB 425/425 KB 136/147 KB
56/56 KB 425/425 KB 140/147 KB
56/56 KB 425/425 KB 144/147 KB
56/56 KB 425/425 KB 147/147 KB
Downloaded: https://repo.maven.apache.org/maven2/org/apache/commons/commons-lang3/3.4/commons-lang3-3.4.jar (425 KB at 116.5 KB/sec)
Downloaded: https://repo.maven.apache.org/maven2/org/apache/felix/org.apache.felix.bundlerepository/1.6.2/org.apache.felix.bundlerepository-1.6.2.jar (147 KB at 39.7 KB/sec)
Downloaded: https://repo.maven.apache.org/maven2/org/apache/maven/maven-artifact-manager/2.0.7/maven-artifact-manager-2.0.7.jar (56 KB at 12.7 KB/sec)
[INFO] reading from src/main/resources/api/coverages.yaml
[ERROR] failed to read resource listing
java.io.FileNotFoundException: src/main/resources/api/coverages.yaml (No such file or directory)
  at java.io.FileInputStream.open0(Native Method)
  at java.io.FileInputStream.open(FileInputStream.java:195)
  at java.io.FileInputStream.<init>(FileInputStream.java:138)
  at com.fasterxml.jackson.core.JsonFactory.createParser(JsonFactory.java:756)
  at com.fasterxml.jackson.databind.ObjectMapper.readTree(ObjectMapper.java:2431)
  at io.swagger.parser.SwaggerCompatConverter.readResourceListing(SwaggerCompatConverter.java:189)
  at io.swagger.parser.SwaggerCompatConverter.read(SwaggerCompatConverter.java:116)
  at io.swagger.parser.SwaggerParser.read(SwaggerParser.java:74)
  at io.swagger.codegen.config.CodegenConfigurator.toClientOptInput(CodegenConfigurator.java:419)
  at io.swagger.codegen.plugin.CodeGenMojo.execute(CodeGenMojo.java:317)
  at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
  at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
  at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
  at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
  at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
  at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
  at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
[WARNING] Directory does not exist, or is inaccessible. No file will be evaluated.
[ERROR]
java.lang.RuntimeException: missing swagger input or config!
  at io.swagger.codegen.DefaultGenerator.generate(DefaultGenerator.java:651)
  at io.swagger.codegen.plugin.CodeGenMojo.execute(CodeGenMojo.java:338)
[INFO] BUILD FAILURE
[INFO] Total time: 42.477 s
[INFO] Finished at: 2017-04-12T00:17:56+00:00
[INFO] Final Memory: 18M/174M
[ERROR] Failed to execute goal io.swagger:swagger-codegen-maven-plugin:2.2.2:generate (coverages) on project gs-docs: Code generation failed. See above for the full exception. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/833/changes&gt;
Changes:
[jody.garnett] remove makefiles
[jody.garnett] change yaml case to allow for valid url reference on
[jody.garnett] api links for completed yaml examples
[jody.garnett] 2.12 docs
[jody.garnett] Make use of ${project.basedir} so doc/en/pom.xml can be used from build
Checking out Revision 75e9ca76b7a4996e7dd355866a003ff3d8f8c7f4 (origin/master)
> git checkout -f 75e9ca76b7a4996e7dd355866a003ff3d8f8c7f4
> git rev-list b997e136e5871948a2b8915e22aa4330e41680ad # timeout=10
[geoserver-master-docs] $ /opt/apache-maven-3.3.9/bin/mvn -f doc/en/pom.xml compile -Puser
[INFO] Scanning for projects...
[INFO]
[INFO] Building GeoServer English Documentation 2.12-SNAPSHOT
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (coverages) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/src/main/resources/api/coverages.yaml&gt;
[WARNING] no property from list, null, {ENUM=null, TITLE=null, DESCRIPTION=A collection of metadata links for the resource., DEFAULT=null, PATTERN=null, DESCRIMINATOR=null, MIN_ITEMS=null, MAX_ITEMS=null, MIN_PROPERTIES=null, MAX_PROPERTIES=null, MIN_LENGTH=null, MAX_LENGTH=null, MINIMUM=null, MAXIMUM=null, EXCLUSIVE_MINIMUM=null, EXCLUSIVE_MAXIMUM=null, UNIQUE_ITEMS=null, EXAMPLE=null, TYPE=list, FORMAT=null, READ_ONLY=null, VENDOR_EXTENSIONS={}, MULTIPLE_OF=null}
[WARNING] no property from list, null, {ENUM=null, TITLE=null, DESCRIPTION=A collection of data links for the resource., DEFAULT=null, PATTERN=null, DESCRIMINATOR=null, MIN_ITEMS=null, MAX_ITEMS=null, MIN_PROPERTIES=null, MAX_PROPERTIES=null, MIN_LENGTH=null, MAX_LENGTH=null, MINIMUM=null, MAXIMUM=null, EXCLUSIVE_MINIMUM=null, EXCLUSIVE_MAXIMUM=null, UNIQUE_ITEMS=null, EXAMPLE=null, TYPE=list, FORMAT=null, READ_ONLY=null, VENDOR_EXTENSIONS={}, MULTIPLE_OF=null}
[WARNING] no property from double, null, {ENUM=null, TITLE=null, DESCRIPTION=max range value, DEFAULT=null, PATTERN=null, DESCRIMINATOR=null, MIN_ITEMS=null, MAX_ITEMS=null, MIN_PROPERTIES=null, MAX_PROPERTIES=null, MIN_LENGTH=null, MAX_LENGTH=null, MINIMUM=null, MAXIMUM=null, EXCLUSIVE_MINIMUM=null, EXCLUSIVE_MAXIMUM=null, UNIQUE_ITEMS=null, EXAMPLE=null, TYPE=double, FORMAT=null, READ_ONLY=null, VENDOR_EXTENSIONS={}, MULTIPLE_OF=null}
[WARNING] no property from double, null, {ENUM=null, TITLE=null, DESCRIPTION=min range value, DEFAULT=null, PATTERN=null, DESCRIMINATOR=null, MIN_ITEMS=null, MAX_ITEMS=null, MIN_PROPERTIES=null, MAX_PROPERTIES=null, MIN_LENGTH=null, MAX_LENGTH=null, MINIMUM=null, MAXIMUM=null, EXCLUSIVE_MINIMUM=null, EXCLUSIVE_MAXIMUM=null, UNIQUE_ITEMS=null, EXAMPLE=null, TYPE=double, FORMAT=null, READ_ONLY=null, VENDOR_EXTENSIONS={}, MULTIPLE_OF=null}
[WARNING] no property from double, null, {ENUM=null, TITLE=null, DESCRIPTION=scale value to apply in X, DEFAULT=null, PATTERN=null, DESCRIMINATOR=null, MIN_ITEMS=null, MAX_ITEMS=null, MIN_PROPERTIES=null, MAX_PROPERTIES=null, MIN_LENGTH=null, MAX_LENGTH=null, MINIMUM=null, MAXIMUM=null, EXCLUSIVE_MINIMUM=null, EXCLUSIVE_MAXIMUM=null, UNIQUE_ITEMS=null, EXAMPLE=null, TYPE=double, FORMAT=null, READ_ONLY=null, VENDOR_EXTENSIONS={}, MULTIPLE_OF=null}
[WARNING] no property from double, null, {ENUM=null, TITLE=null, DESCRIPTION=scale value to apply in Y, DEFAULT=null, PATTERN=null, DESCRIMINATOR=null, MIN_ITEMS=null, MAX_ITEMS=null, MIN_PROPERTIES=null, MAX_PROPERTIES=null, MIN_LENGTH=null, MAX_LENGTH=null, MINIMUM=null, MAXIMUM=null, EXCLUSIVE_MINIMUM=null, EXCLUSIVE_MAXIMUM=null, UNIQUE_ITEMS=null, EXAMPLE=null, TYPE=double, FORMAT=null, READ_ONLY=null, VENDOR_EXTENSIONS={}, MULTIPLE_OF=null}
[WARNING] no property from double, null, {ENUM=null, TITLE=null, DESCRIPTION=shear value to apply in X, DEFAULT=null, PATTERN=null, DESCRIMINATOR=null, MIN_ITEMS=null, MAX_ITEMS=null, MIN_PROPERTIES=null, MAX_PROPERTIES=null, MIN_LENGTH=null, MAX_LENGTH=null, MINIMUM=null, MAXIMUM=null, EXCLUSIVE_MINIMUM=null, EXCLUSIVE_MAXIMUM=null, UNIQUE_ITEMS=null, EXAMPLE=null, TYPE=double, FORMAT=null, READ_ONLY=null, VENDOR_EXTENSIONS={}, MULTIPLE_OF=null}
[WARNING] no property from double, null, {ENUM=null, TITLE=null, DESCRIPTION=shear value to apply in Y, DEFAULT=null, PATTERN=null, DESCRIMINATOR=null, MIN_ITEMS=null, MAX_ITEMS=null, MIN_PROPERTIES=null, MAX_PROPERTIES=null, MIN_LENGTH=null, MAX_LENGTH=null, MINIMUM=null, MAXIMUM=null, EXCLUSIVE_MINIMUM=null, EXCLUSIVE_MAXIMUM=null, UNIQUE_ITEMS=null, EXAMPLE=null, TYPE=double, FORMAT=null, READ_ONLY=null, VENDOR_EXTENSIONS={}, MULTIPLE_OF=null}
[WARNING] no property from double, null, {ENUM=null, TITLE=null, DESCRIPTION=translation to apply in X, DEFAULT=null, PATTERN=null, DESCRIMINATOR=null, MIN_ITEMS=null, MAX_ITEMS=null, MIN_PROPERTIES=null, MAX_PROPERTIES=null, MIN_LENGTH=null, MAX_LENGTH=null, MINIMUM=null, MAXIMUM=null, EXCLUSIVE_MINIMUM=null, EXCLUSIVE_MAXIMUM=null, UNIQUE_ITEMS=null, EXAMPLE=null, TYPE=double, FORMAT=null, READ_ONLY=null, VENDOR_EXTENSIONS={}, MULTIPLE_OF=null}
[WARNING] no property from double, null, {ENUM=null, TITLE=null, DESCRIPTION=translation to apply in Y, DEFAULT=null, PATTERN=null, DESCRIMINATOR=null, MIN_ITEMS=null, MAX_ITEMS=null, MIN_PROPERTIES=null, MAX_PROPERTIES=null, MIN_LENGTH=null, MAX_LENGTH=null, MINIMUM=null, MAXIMUM=null, EXCLUSIVE_MINIMUM=null, EXCLUSIVE_MAXIMUM=null, UNIQUE_ITEMS=null, EXAMPLE=null, TYPE=double, FORMAT=null, READ_ONLY=null, VENDOR_EXTENSIONS={}, MULTIPLE_OF=null}
[WARNING] generated unique operationId `getCoverages_0`
[WARNING] generated unique operationId `postCoverage_0`
[WARNING] generated unique operationId `postCoverage_1`
[WARNING] generated unique operationId `deleteCoverage_0`
[WARNING] generated unique operationId `putCoverage_0`
[WARNING] generated unique operationId `postCoverage_2`
[WARNING] generated unique operationId `deleteCoverage_1`
[WARNING] generated unique operationId `getCoverage_0`
[WARNING] generated unique operationId `putCoverage_1`
[WARNING] generated unique operationId `postCoverage_3`
[WARNING] generated unique operationId `deleteCoverage_2`
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/index.html&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (coverageStores) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/src/main/resources/api/coveragestores.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/index.html&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (datastores) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/src/main/resources/api/datastores.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/index.html&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/.swagger-codegen-ignore&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (featureTypes) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/src/main/resources/api/featureTypes.yaml&gt;
java.io.FileNotFoundException: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/src/main/resources/api/featureTypes.yaml&gt; (No such file or directory)
[ERROR]
[INFO] Total time: 2.781 s
[INFO] Finished at: 2017-04-12T00:44:19+00:00
[INFO] Final Memory: 15M/171M
[ERROR] Failed to execute goal io.swagger:swagger-codegen-maven-plugin:2.2.2:generate (featureTypes) on project gs-docs: Code generation failed. See above for the full exception. -> [Help 1]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/834/changes&gt;
Changes:
[jody.garnett] case sensitive file system on ares
[...truncated 2606 lines...]
     [exec] copying images... [ 94%] data/database/images/arcsdevectorcreate.png
     [exec] copying images... [ 94%] styling/ysld/reference/img/blend-lighten.png
     [exec] copying images... [ 94%] styling/ysld/cookbook/../../sld/cookbook/images/polygon_polygonwithdefaultlabel.png
     [exec] copying images... [ 94%] data/webadmin/img/data_layers_CRS.png
     [exec] copying images... [ 94%] tutorials/tomcat-jndi/sqlserver_conf.png
     [exec] copying images... [ 94%] styling/workshop/ysld/../style/img/RasterSymbology.svg
     [exec] copying images... [ 94%] data/raster/images/worldimageconfigure.png
     [exec] copying images... [ 94%] services/wms/googleearth/tutorials/time/gettingStarted.png
     [exec] copying images... [ 94%] gettingstarted/web-admin-quickstart/../../webadmin/images/web-admin.png
     [exec] copying images... [ 94%] styling/sld/extensions/images/roads_uom1.png
     [exec] copying images... [ 94%] extensions/printing/images/tableConfig.png
     [exec] copying images... [ 94%] styling/css/cookbook/../../sld/cookbook/images/raster_twocolorgradient.png
     [exec] copying images... [ 94%] styling/workshop/css/../style/img/css_07_data.png
     [exec] copying images... [ 95%] styling/workshop/css/../style/img/polygon_pattern_5.png
     [exec] copying images... [ 95%] extensions/importer/images/importer_link.png
     [exec] copying images... [ 95%] security/tutorials/ldap/images/acme_ldap.png
     [exec] copying images... [ 95%] styling/sld/extensions/images/emicircle.png
     [exec] copying images... [ 95%] services/wms/googleearth/tutorials/kmlplacemark/default.jpg
     [exec] copying images... [ 95%] styling/sld/extensions/composite-blend/images/blend1-lighten.png
     [exec] copying images... [ 95%] data/raster/images/coverageviewaddbands.png
     [exec] copying images... [ 95%] configuration/demos/img/demos_SRS.png
     [exec] copying images... [ 95%] data/raster/imagemosaic/images/vito_1.png
     [exec] copying images... [ 95%] styling/ysld/reference/img/composite-xor.svg
     [exec] copying images... [ 95%] gettingstarted/shapefile-quickstart/new_workspace.png
     [exec] copying images... [ 95%] services/wfs/img/services_WFS_servicelevel.png
     [exec] copying images... [ 95%] security/tutorials/cert/images/cert13.jpg
     [exec] copying images... [ 95%] styling/ysld/cookbook/../../sld/cookbook/images/polygon_zoombasedpolygonmedium.png
     [exec] copying images... [ 96%] community/oauth2/images/test5.jpg
     [exec] copying images... [ 96%] tutorials/imagemosaic_timeseries/img/step_4_2.png
     [exec] copying images... [ 96%] tutorials/imagemosaic-jdbc/snapshot4.png
     [exec] copying images... [ 96%] styling/workshop/css/../style/img/polygon_multitheme.png
     [exec] copying images... [ 96%] configuration/demos/img/demos_requests_WFS.png
     [exec] copying images... [ 96%] extensions/importer/images/using_recent.png
     [exec] copying images... [ 96%] gettingstarted/web-admin-quickstart/login-page.png
     [exec] copying images... [ 96%] security/tutorials/j2ee/images/j2ee3.jpg
     [exec] copying images... [ 96%] community/oauth2/images/oauth2chain001.png
     [exec] copying images... [ 96%] security/tutorials/activedirectory/images/ad3.jpg
     [exec] copying images... [ 96%] gettingstarted/postgis-quickstart/layerrow.png
     [exec] copying images... [ 96%] data/webadmin/img/data_stores_type2.png
     [exec] copying images... [ 96%] services/wms/googleearth/pointDefault.png
     [exec] copying images... [ 97%] security/webadmin/images/auth_userpass.png
     [exec] copying images... [ 97%] services/wms/googleearth/tutorials/kmlplacemark/topplink.png
     [exec] copying images... [ 97%] styling/sld/extensions/composite-blend/images/blend1-destination-atop.png
     [exec] copying images... [ 97%] styling/workshop/setup/img/cultural.png
     [exec] copying images... [ 97%] styling/ysld/cookbook/../../sld/cookbook/images/polygon_attributebasedpolygon.png
     [exec] copying images... [ 97%] installation/images/osx1.png
     [exec] copying images... [ 97%] gettingstarted/shapefile-quickstart/new_shapefile.png
     [exec] copying images... [ 97%] styling/sld/cookbook/images/polygon_polygonwithdefaultlabel.png
     [exec] copying images... [ 97%] styling/workshop/css/../style/img/line.png
     [exec] copying images... [ 97%] styling/css/cookbook/../../sld/cookbook/images/line_attributebasedline.png
     [exec] copying images... [ 97%] styling/sld/cookbook/images/point_simplepoint.png
     [exec] copying images... [ 97%] extensions/importer/images/using_datasource.png
     [exec] copying images... [ 97%] community/backuprestore/images/usagerest004.png
     [exec] copying images... [ 97%] configuration/demos/img/demos_viewwps.png
     [exec] copying images... [ 98%] styling/workshop/css/../style/img/Point_Graphic_CSS.svg
     [exec] copying images... [ 98%] styling/css/cookbook/../../sld/cookbook/images/polygon_hatchingfill.png
     [exec] copying images... [ 98%] production/images/custom_id.png
     [exec] copying images... [ 98%] community/oauth2/images/google_ssl_001.png
     [exec] copying images... [ 98%] styling/css/cookbook/../../sld/cookbook/images/line_zoombasedlinesmall.png
     [exec] copying images... [ 98%] community/jms-cluster/activemq/images/master_slave_jmx_2.png
     [exec] copying images... [ 98%] styling/ysld/reference/symbolizers/img/raster_normalize.png
     [exec] copying images... [ 98%] data/raster/imagemosaic/images/tutorial_dynamic1.png
     [exec] copying images... [ 98%] data/raster/images/gdalmasks.png
     [exec] copying images... [ 98%] community/remote-wps/images/run_example004.jpg
     [exec] copying images... [ 98%] styling/workshop/design/img/color_03_qualitative.png
     [exec] copying images... [ 98%] data/webadmin/img/data_stores.png
     [exec] copying images... [ 98%] styling/sld/extensions/composite-blend/images/blend1-difference.png
     [exec] copying images... [ 98%] styling/workshop/design/img/color_sequential.png
     [exec] copying images... [ 99%] tutorials/imagemosaic_timeseries/img/step_2_1.png
     [exec] copying images... [ 99%] styling/ysld/reference/img/functions_buffer.png
     [exec] copying images... [ 99%] gettingstarted/web-admin-quickstart/../../data/webadmin/img/data_search_results.png
     [exec] copying images... [ 99%] styling/ysld/reference/img/composite-destination-over.svg
     [exec] copying images... [ 99%] styling/sld/extensions/composite-blend/images/blend1-exclusion.png
     [exec] copying images... [ 99%] geowebcache/webadmin/img/gridsets_matrix.png
     [exec] copying images... [ 99%] tutorials/imagemosaic_timeseries/img/step_3.png
     [exec] copying images... [ 99%] data/raster/images/gdal_driver_path.png
     [exec] copying images... [ 99%] styling/sld/extensions/images/random-slash.png
     [exec] copying images... [ 99%] styling/ysld/reference/symbolizers/img/text_basic.png
     [exec] copying images... [ 99%] community/oauth2/images/google_ssl_007.png
     [exec] copying images... [ 99%] styling/workshop/css/../style/img/PointSymbology.svg
     [exec] copying images... [ 99%] styling/sld/cookbook/images/line_attributebasedline.png
     [exec] copying images... [100%] styling/sld/cookbook/images/raster_brightnessandcontrast.png
     [exec] copying downloadable files... [ 0%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_rotatedsquare.sld&gt;
     [exec] copying downloadable files... [ 1%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_attributebasedpolygon.sld&gt;
     [exec] copying downloadable files... [ 2%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/CompositionPart_MappingFile.xml&gt;
     [exec] copying downloadable files... [ 2%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_simplepointwithstroke.sld&gt;
     [exec] copying downloadable files... [ 3%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_rotatedsquare.ysld&gt;
     [exec] copying downloadable files... [ 4%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_pointwithrotatedlabel.ysld&gt;
     [exec] copying downloadable files... [ 4%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_simpleline.sld&gt;
     [exec] copying downloadable files... [ 5%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_dashedline.ysld&gt;
     [exec] copying downloadable files... [ 6%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_transparentgradient.sld&gt;
     [exec] copying downloadable files... [ 7%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_simplepoint.sld&gt;
     [exec] copying downloadable files... [ 7%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_dashedline.sld&gt;
     [exec] copying downloadable files... [ 8%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/one_to_many_relationship.JPG&gt;
     [exec] copying downloadable files... [ 9%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/point_example.ysld&gt;
     [exec] copying downloadable files... [ 9%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_manycolorgradient.ysld&gt;
     [exec] copying downloadable files... [ 10%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_transparentpolygon.ysld&gt;
     [exec] copying downloadable files... [ 11%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_twocolorgradient.ysld&gt;
     [exec] copying downloadable files... [ 11%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_optimizedstyledlabel.sld&gt;
     [exec] copying downloadable files... [ 12%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/sld_cookbook_polygon.zip&gt;
     [exec] copying downloadable files... [ 13%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_simplepoint.ysld&gt;
     [exec] copying downloadable files... [ 14%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/ysld_cookbook_raster.zip&gt;
     [exec] copying downloadable files... [ 14%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/composite-blend/files/statesblend.sld&gt;
     [exec] copying downloadable files... [ 15%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/MappedFeature_MappingFile.xml&gt;
     [exec] copying downloadable files... [ 16%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/z-order/files/roads_groups.sld&gt;
     [exec] copying downloadable files... [ 16%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_pointwithdefaultlabel.sld&gt;
     [exec] copying downloadable files... [ 17%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_zoombasedline.ysld&gt;
     [exec] copying downloadable files... [ 18%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/airports0.ysld&gt;
     [exec] copying downloadable files... [ 19%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/artifacts/shadow.sld&gt;
     [exec] copying downloadable files... [ 19%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_hatchingfill.ysld&gt;
     [exec] copying downloadable files... [ 20%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/src/release/epl-1.0.txt&gt;
     [exec] copying downloadable files... [ 21%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/extensions/printing/files/print-example.html&gt;
     [exec] copying downloadable files... [ 21%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/seed_json.txt&gt;
     [exec] copying downloadable files... [ 22%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_labelfollowingline.ysld&gt;
     [exec] copying downloadable files... [ 23%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_zoom.ysld&gt;
     [exec] copying downloadable files... [ 23%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/CGITermValue_MappingFile.xml&gt;
     [exec] copying downloadable files... [ 24%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/artifacts/vertices.sld&gt;
     [exec] copying downloadable files... [ 25%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_dashspace.ysld&gt;
     [exec] copying downloadable files... [ 26%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_zoombasedline.sld&gt;
     [exec] copying downloadable files... [ 26%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_twocolorgradient.sld&gt;
     [exec] copying downloadable files... [ 27%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_linewithborder.ysld&gt;
     [exec] copying downloadable files... [ 28%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_dashspace.sld&gt;
     [exec] copying downloadable files... [ 28%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_linewithborder.sld&gt;
     [exec] copying downloadable files... [ 29%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_attributebasedline.sld&gt;
     [exec] copying downloadable files... [ 30%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/security/usergrouprole/schemas/users.xsd&gt;
     [exec] copying downloadable files... [ 30%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/artifacts/startend.sld&gt;
     [exec] copying downloadable files... [ 31%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/artifacts/parpoint.sld&gt;
     [exec] copying downloadable files... [ 32%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_offset.sld&gt;
     [exec] copying downloadable files... [ 33%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/many_to_many_relationship.JPG&gt;
     [exec] copying downloadable files... [ 33%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/ysld_cookbook_point.zip&gt;
     [exec] copying downloadable files... [ 34%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/src/release/apache-2.0.txt&gt;
     [exec] copying downloadable files... [ 35%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_optimizedlabel.ysld&gt;
     [exec] copying downloadable files... [ 35%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/src/release/GPL.txt&gt;
     [exec] copying downloadable files... [ 36%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_simplepolygon.ysld&gt;
     [exec] copying downloadable files... [ 37%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/airports0.sld&gt;
     [exec] copying downloadable files... [ 38%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_transparenttriangle.ysld&gt;
     [exec] copying downloadable files... [ 38%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/production/scripts/geoserver_tomcat&gt;
     [exec] copying downloadable files... [ 39%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_brightnessandcontrast.ysld&gt;
     [exec] copying downloadable files... [ 40%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_dashdot.sld&gt;
     [exec] copying downloadable files... [ 40%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_linewithdefaultlabel.sld&gt;
     [exec] copying downloadable files... [ 41%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_graphicfill.ysld&gt;
     [exec] copying downloadable files... [ 42%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_attributebasedline.ysld&gt;
     [exec] copying downloadable files... [ 42%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/production/scripts/geoserver_deb&gt;
     [exec] copying downloadable files... [ 43%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/cert/sample_certs.zip&gt;
     [exec] copying downloadable files... [ 44%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/GeologicUnit_MappingFile.xml&gt;
     [exec] copying downloadable files... [ 45%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/rest/examples/polyphemus_20120401.nc&gt;
     [exec] copying downloadable files... [ 45%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_polygonwithstyledlabel.ysld&gt;
     [exec] copying downloadable files... [ 46%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/ysld_cookbook_line.zip&gt;
     [exec] copying downloadable files... [ 47%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/diskquota_json.txt&gt;
     [exec] copying downloadable files... [ 47%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_pointasgraphic.ysld&gt;
     [exec] copying downloadable files... [ 48%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_labelhalo.sld&gt;
     [exec] copying downloadable files... [ 49%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_labelhalo.ysld&gt;
     [exec] copying downloadable files... [ 50%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/gettingstarted/postgis-quickstart/nyc_buildings.zip&gt;
     [exec] copying downloadable files... [ 50%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_discretecolors.ysld&gt;
     [exec] copying downloadable files... [ 51%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/services/wms/googleearth/tutorials/time/inet_weu.zip&gt;
     [exec] copying downloadable files... [ 52%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/sld_cookbook_line.zip&gt;
     [exec] copying downloadable files... [ 52%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_polygonwithdefaultlabel.ysld&gt;
     [exec] copying downloadable files... [ 53%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/wmslayer.xml.txt&gt;
     [exec] copying downloadable files... [ 54%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/point_example2.css&gt;
     [exec] copying downloadable files... [ 54%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_simplepolygonwithstroke.sld&gt;
     [exec] copying downloadable files... [ 55%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_alphachannel.ysld&gt;
     [exec] copying downloadable files... [ 56%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/tutorials/feature-pregeneralized/streams.zip&gt;
     [exec] copying downloadable files... [ 57%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_threecolorgradient.sld&gt;
     [exec] copying downloadable files... [ 57%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/tutorials/imagemosaic_footprint/rastermask.zip&gt;
     [exec] copying downloadable files... [ 58%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/production/scripts/geoserver_suse&gt;
     [exec] copying downloadable files... [ 59%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/ysld_cookbook_polygon.zip&gt;
     [exec] copying downloadable files... [ 59%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_pointwithdefaultlabel.ysld&gt;
     [exec] copying downloadable files... [ 60%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_transparentpolygon.sld&gt;
     [exec] copying downloadable files... [ 61%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_attribute.ysld&gt;
     [exec] copying downloadable files... [ 61%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_polygonwithstyledlabel.sld&gt;
     [exec] copying downloadable files... [ 62%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_zoom.sld&gt;
     [exec] copying downloadable files... [ 63%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_brightnessandcontrast.sld&gt;
     [exec] copying downloadable files... [ 64%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/sld_cookbook_raster.zip&gt;
     [exec] copying downloadable files... [ 64%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_threecolorgradient.ysld&gt;
     [exec] copying downloadable files... [ 65%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_linewithdefaultlabel.ysld&gt;
     [exec] copying downloadable files... [ 66%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_hatchingfill.sld&gt;
     [exec] copying downloadable files... [ 66%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_offset.sld&gt;
     [exec] copying downloadable files... [ 67%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_simplepolygon.sld&gt;
     [exec] copying downloadable files... [ 68%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/z-order/files/z_order_roads.zip&gt;
     [exec] copying downloadable files... [ 69%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/sld_cookbook_point.zip&gt;
     [exec] copying downloadable files... [ 69%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/geoserverlayer_minimal.xml.txt&gt;
     [exec] copying downloadable files... [ 70%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/airports2.sld&gt;
     [exec] copying downloadable files... [ 71%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/point_example.css&gt;
     [exec] copying downloadable files... [ 71%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_pointwithstyledlabel.sld&gt;
     [exec] copying downloadable files... [ 72%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_simpleline.ysld&gt;
     [exec] copying downloadable files... [ 73%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/GeologicEvent_MappingFile.xml&gt;
     [exec] copying downloadable files... [ 73%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/geoserverlayer.xml.txt&gt;
     [exec] copying downloadable files... [ 74%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/src/release/apache-1.1.txt&gt;
     [exec] copying downloadable files... [ 75%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_zoombasedpolygon.sld&gt;
     [exec] copying downloadable files... [ 76%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/MappedFeature_Output.xml&gt;
     [exec] copying downloadable files... [ 76%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_discretecolors.sld&gt;
     [exec] copying downloadable files... [ 77%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/LICENSE.txt&gt;
     [exec] copying downloadable files... [ 78%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_manycolorgradient.sld&gt;
     [exec] copying downloadable files... [ 78%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_pointasgraphic.sld&gt;
     [exec] copying downloadable files... [ 79%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/point_example2.ysld&gt;
     [exec] copying downloadable files... [ 80%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_alphachannel.sld&gt;
     [exec] copying downloadable files... [ 80%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_attributebasedpolygon.ysld&gt;
     [exec] copying downloadable files... [ 81%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_graphicfill.sld&gt;
     [exec] copying downloadable files... [ 82%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_dashdot.ysld&gt;
     [exec] copying downloadable files... [ 83%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/gettingstarted/shapefile-quickstart/nyc_roads.zip&gt;
     [exec] copying downloadable files... [ 83%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_offsetline.ysld&gt;
     [exec] copying downloadable files... [ 84%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_pointwithrotatedlabel.sld&gt;
     [exec] copying downloadable files... [ 85%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_simplepolygonwithstroke.ysld&gt;
     [exec] copying downloadable files... [ 85%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_optimizedstyledlabel.ysld&gt;
     [exec] copying downloadable files... [ 86%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/diskquota_xml.txt&gt;
     [exec] copying downloadable files... [ 87%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_zoombasedpolygon.ysld&gt;
     [exec] copying downloadable files... [ 88%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/rest/examples/empty.zip&gt;
     [exec] copying downloadable files... [ 88%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_transparentgradient.ysld&gt;
     [exec] copying downloadable files... [ 89%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/security/usergrouprole/schemas/roles.xsd&gt;
     [exec] copying downloadable files... [ 90%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_simplepointwithstroke.ysld&gt;
     [exec] copying downloadable files... [ 90%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_labelfollowingline.sld&gt;
     [exec] copying downloadable files... [ 91%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_railroad.ysld&gt;
     [exec] copying downloadable files... [ 92%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/tutorials/imagemosaic_timeseries/temperatureLZWdataset.zip&gt;
     [exec] copying downloadable files... [ 92%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/tutorials/imagemosaic_timeseries/snowLZWdataset.zip&gt;
     [exec] copying downloadable files... [ 93%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_optimizedlabel.sld&gt;
     [exec] copying downloadable files... [ 94%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_attribute.sld&gt;
     [exec] copying downloadable files... [ 95%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_pointwithstyledlabel.ysld&gt;
     [exec] copying downloadable files... [ 95%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_railroad.sld&gt;
     [exec] copying downloadable files... [ 96%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/seed_xml.txt&gt;
     [exec] copying downloadable files... [ 97%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/wmslayer_minimal.xml.txt&gt;
     [exec] copying downloadable files... [ 97%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_polygonwithdefaultlabel.sld&gt;
     [exec] copying downloadable files... [ 98%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_transparenttriangle.sld&gt;
     [exec] copying downloadable files... [ 99%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/services/wms/googleearth/tutorials/time/inet_weu.sld&gt;
     [exec] copying downloadable files... [100%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/z-order/files/roads_no_groups.sld&gt;
     [exec] copying static files... done
     [exec] dumping search index... done
     [exec] dumping object inventory... done
     [exec] build succeeded, 13 warnings.
[INFO] Executed tasks
[INFO] BUILD SUCCESS
[INFO] Total time: 02:30 min
[INFO] Finished at: 2017-04-12T00:49:07+00:00
[INFO] Final Memory: 15M/266M
[geoserver-master-docs] $ /bin/sh -xe /tmp/hudson7683649602544556172.sh
+ VER=origin/master
+ VER=master
+ cd doc/en
+ cp -r target/user/html /var/www/geoserver/master/doc/en/user
+ cp -r target/api /var/www/geoserver/master/doc/en/user/api
+ cp -r target/developer/html /var/www/geoserver/master/doc/en/developer
cp: cannot stat `target/developer/html': No such file or directory
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/835/&gt;
