[Geoserver-devel] Build failed in Jenkins: geoserver-master-live-docs #837
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/837/changes&gt;
Changes:
[nuno.oliveira] [GEOS-8086] Make Notification community module compatible with the new
[andrea.aime] [GEOS-8087] Slow WCS GetCoverage extraction with GeoTiff output format
[...truncated 188 lines...]
  "isInteger" : false,
  "isLong" : false,
  "isFloat" : false,
  "isDouble" : false,
  "isByteArray" : false,
  "isBinary" : false,
  "isFile" : false,
  "isBoolean" : false,
  "isDate" : false,
  "isDateTime" : false,
  "isListContainer" : true,
  "isMapContainer" : false,
  "isEnum" : false,
  "isReadOnly" : false,
  "vendorExtensions" : { },
  "hasValidation" : false,
  "isInherited" : false,
  "nameInCamelCase" : "WmsLayers"
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (workspaces) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/src/main/resources/api/workspaces.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (monitoring) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/src/main/resources/api/monitoring.yaml&gt;
[WARNING] generated unique operationId `getMonitorRequests_0`
[WARNING] generated unique operationId `putMonitorRequests_0`
[WARNING] generated unique operationId `postMonitorRequests_0`
[WARNING] generated unique operationId `deleteMonitorRequests_0`
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (compile) @ gs-docs ---
[INFO] Executing tasks
init:
     [echo] Build directory is <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target&gt; and project version is 2.12-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.12-SNAPSHOT -W -b html -d "<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
     [exec] Running Sphinx v1.2b1
     [exec] loading pickled environment... done
     [exec] building [html]: targets for 0 source files that are out of date
     [exec] updating environment: 0 added, 0 changed, 0 removed
     [exec] looking for now-outdated files... none found
     [exec] no targets are out of date.
user:
sphinx-ignore-warnings:
     [exec] updating environment: 0 added, 1 changed, 0 removed
     [exec] reading sources... [100%] rest/examples/index
     [exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/rest/examples/index.rst&gt;:22: WARNING: toctree contains reference to nonexisting document u'rest/examples/fonts'
     [exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/rest/examples/index.rst&gt;:22: WARNING: toctree contains reference to nonexisting document u'rest/examples/layers'
     [exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/rest/examples/index.rst&gt;:22: WARNING: toctree contains reference to nonexisting document u'rest/examples/styles'
     [exec] pickling environment... done
     [exec] checking consistency... done
     [exec] preparing documents... done
     [exec] writing output... [ 33%] index
     [exec] writing output... [ 66%] rest/examples/index
     [exec] writing output... [100%] rest/index
     [exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/rest/index.rst&gt;:33: WARNING: unknown document: workspaces
     [exec] writing additional files... search
     [exec] copying downloadable files... [ 0%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_manycolorgradient.ysld&gt;
     [exec] copying downloadable files... [ 1%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_attributebasedpolygon.sld&gt;
     [exec] copying downloadable files... [ 2%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/CompositionPart_MappingFile.xml&gt;
     [exec] copying downloadable files... [ 2%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_simplepointwithstroke.sld&gt;
     [exec] copying downloadable files... [ 3%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_rotatedsquare.ysld&gt;
     [exec] copying downloadable files... [ 4%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_pointwithrotatedlabel.ysld&gt;
     [exec] copying downloadable files... [ 4%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_hatchingfill.ysld&gt;
     [exec] copying downloadable files... [ 5%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/airports2.sld&gt;
     [exec] copying downloadable files... [ 6%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_transparentgradient.sld&gt;
     [exec] copying downloadable files... [ 7%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_simplepoint.sld&gt;
     [exec] copying downloadable files... [ 7%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_dashedline.sld&gt;
     [exec] copying downloadable files... [ 8%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/one_to_many_relationship.JPG&gt;
     [exec] copying downloadable files... [ 9%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/point_example.ysld&gt;
     [exec] copying downloadable files... [ 9%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_rotatedsquare.sld&gt;
     [exec] copying downloadable files... [ 10%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_transparentpolygon.ysld&gt;
     [exec] copying downloadable files... [ 11%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_twocolorgradient.ysld&gt;
     [exec] copying downloadable files... [ 11%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_optimizedstyledlabel.sld&gt;
     [exec] copying downloadable files... [ 12%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/sld_cookbook_polygon.zip&gt;
     [exec] copying downloadable files... [ 13%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/diskquota_xml.txt&gt;
     [exec] copying downloadable files... [ 14%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_simplepoint.ysld&gt;
     [exec] copying downloadable files... [ 14%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/ysld_cookbook_raster.zip&gt;
     [exec] copying downloadable files... [ 15%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/composite-blend/files/statesblend.sld&gt;
     [exec] copying downloadable files... [ 16%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/MappedFeature_MappingFile.xml&gt;
     [exec] copying downloadable files... [ 16%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/z-order/files/roads_groups.sld&gt;
     [exec] copying downloadable files... [ 17%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_pointwithdefaultlabel.sld&gt;
     [exec] copying downloadable files... [ 18%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_zoombasedline.ysld&gt;
     [exec] copying downloadable files... [ 19%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/artifacts/shadow.sld&gt;
     [exec] copying downloadable files... [ 19%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/src/release/epl-1.0.txt&gt;
     [exec] copying downloadable files... [ 20%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/rest/examples/empty.zip&gt;
     [exec] copying downloadable files... [ 21%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_attribute.sld&gt;
     [exec] copying downloadable files... [ 21%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/extensions/printing/files/print-example.html&gt;
     [exec] copying downloadable files... [ 22%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_zoom.ysld&gt;
     [exec] copying downloadable files... [ 23%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/CGITermValue_MappingFile.xml&gt;
     [exec] copying downloadable files... [ 23%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/artifacts/vertices.sld&gt;
     [exec] copying downloadable files... [ 24%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_pointasgraphic.ysld&gt;
     [exec] copying downloadable files... [ 25%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_zoombasedline.sld&gt;
     [exec] copying downloadable files... [ 26%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_simpleline.sld&gt;
     [exec] copying downloadable files... [ 26%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_linewithborder.ysld&gt;
     [exec] copying downloadable files... [ 27%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_railroad.ysld&gt;
     [exec] copying downloadable files... [ 28%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_dashspace.sld&gt;
     [exec] copying downloadable files... [ 28%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_linewithborder.sld&gt;
     [exec] copying downloadable files... [ 29%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_attributebasedline.sld&gt;
     [exec] copying downloadable files... [ 30%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/security/usergrouprole/schemas/users.xsd&gt;
     [exec] copying downloadable files... [ 30%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/artifacts/startend.sld&gt;
     [exec] copying downloadable files... [ 31%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/artifacts/parpoint.sld&gt;
     [exec] copying downloadable files... [ 32%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_offset.sld&gt;
     [exec] copying downloadable files... [ 33%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/many_to_many_relationship.JPG&gt;
     [exec] copying downloadable files... [ 33%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_brightnessandcontrast.ysld&gt;
     [exec] copying downloadable files... [ 34%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/src/release/apache-2.0.txt&gt;
     [exec] copying downloadable files... [ 35%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_optimizedlabel.ysld&gt;
     [exec] copying downloadable files... [ 35%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/src/release/GPL.txt&gt;
     [exec] copying downloadable files... [ 36%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_simplepolygon.ysld&gt;
     [exec] copying downloadable files... [ 37%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/airports0.sld&gt;
     [exec] copying downloadable files... [ 38%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_transparenttriangle.ysld&gt;
     [exec] copying downloadable files... [ 38%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/production/scripts/geoserver_tomcat&gt;
     [exec] copying downloadable files... [ 39%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_dashdot.sld&gt;
     [exec] copying downloadable files... [ 40%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_linewithdefaultlabel.sld&gt;
     [exec] copying downloadable files... [ 40%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_graphicfill.ysld&gt;
     [exec] copying downloadable files... [ 41%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_attributebasedline.ysld&gt;
     [exec] copying downloadable files... [ 42%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/production/scripts/geoserver_deb&gt;
     [exec] copying downloadable files... [ 42%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/security/tutorials/cert/sample_certs.zip&gt;
     [exec] copying downloadable files... [ 43%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/seed_json.txt&gt;
     [exec] copying downloadable files... [ 44%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_manycolorgradient.sld&gt;
     [exec] copying downloadable files... [ 45%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_polygonwithstyledlabel.ysld&gt;
     [exec] copying downloadable files... [ 45%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/ysld_cookbook_line.zip&gt;
     [exec] copying downloadable files... [ 46%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/diskquota_json.txt&gt;
     [exec] copying downloadable files... [ 47%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_polygonwithstyledlabel.sld&gt;
     [exec] copying downloadable files... [ 47%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_labelhalo.ysld&gt;
     [exec] copying downloadable files... [ 48%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/gettingstarted/postgis-quickstart/nyc_buildings.zip&gt;
     [exec] copying downloadable files... [ 49%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_discretecolors.ysld&gt;
     [exec] copying downloadable files... [ 50%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/services/wms/googleearth/tutorials/time/inet_weu.zip&gt;
     [exec] copying downloadable files... [ 50%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/sld_cookbook_line.zip&gt;
     [exec] copying downloadable files... [ 51%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_polygonwithdefaultlabel.ysld&gt;
     [exec] copying downloadable files... [ 52%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/wmslayer.xml.txt&gt;
     [exec] copying downloadable files... [ 52%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_optimizedlabel.sld&gt;
     [exec] copying downloadable files... [ 53%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_simplepolygonwithstroke.sld&gt;
     [exec] copying downloadable files... [ 54%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_alphachannel.ysld&gt;
     [exec] copying downloadable files... [ 54%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_threecolorgradient.sld&gt;
     [exec] copying downloadable files... [ 55%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/tutorials/imagemosaic_footprint/rastermask.zip&gt;
     [exec] copying downloadable files... [ 56%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_labelfollowingline.ysld&gt;
     [exec] copying downloadable files... [ 57%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/ysld_cookbook_polygon.zip&gt;
     [exec] copying downloadable files... [ 57%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_pointwithdefaultlabel.ysld&gt;
     [exec] copying downloadable files... [ 58%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_transparentpolygon.sld&gt;
     [exec] copying downloadable files... [ 59%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_attribute.ysld&gt;
     [exec] copying downloadable files... [ 59%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_labelhalo.sld&gt;
     [exec] copying downloadable files... [ 60%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_zoom.sld&gt;
     [exec] copying downloadable files... [ 61%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_brightnessandcontrast.sld&gt;
     [exec] copying downloadable files... [ 61%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/sld_cookbook_raster.zip&gt;
     [exec] copying downloadable files... [ 62%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_threecolorgradient.ysld&gt;
     [exec] copying downloadable files... [ 63%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_linewithdefaultlabel.ysld&gt;
     [exec] copying downloadable files... [ 64%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_transparenttriangle.sld&gt;
     [exec] copying downloadable files... [ 64%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_hatchingfill.sld&gt;
     [exec] copying downloadable files... [ 65%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_offset.sld&gt;
     [exec] copying downloadable files... [ 66%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_simplepolygon.sld&gt;
     [exec] copying downloadable files... [ 66%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/z-order/files/z_order_roads.zip&gt;
     [exec] copying downloadable files... [ 67%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/sld_cookbook_point.zip&gt;
     [exec] copying downloadable files... [ 68%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/geoserverlayer_minimal.xml.txt&gt;
     [exec] copying downloadable files... [ 69%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_dashedline.ysld&gt;
     [exec] copying downloadable files... [ 69%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_twocolorgradient.sld&gt;
     [exec] copying downloadable files... [ 70%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/point_example.css&gt;
     [exec] copying downloadable files... [ 71%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_pointwithstyledlabel.sld&gt;
     [exec] copying downloadable files... [ 71%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_simpleline.ysld&gt;
     [exec] copying downloadable files... [ 72%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/GeologicEvent_MappingFile.xml&gt;
     [exec] copying downloadable files... [ 73%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/geoserverlayer.xml.txt&gt;
     [exec] copying downloadable files... [ 73%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/src/release/apache-1.1.txt&gt;
     [exec] copying downloadable files... [ 74%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/seed_xml.txt&gt;
     [exec] copying downloadable files... [ 75%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/MappedFeature_Output.xml&gt;
     [exec] copying downloadable files... [ 76%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_discretecolors.sld&gt;
     [exec] copying downloadable files... [ 76%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/LICENSE.txt&gt;
     [exec] copying downloadable files... [ 77%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/rest/examples/polyphemus_20120401.nc&gt;
     [exec] copying downloadable files... [ 78%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_pointasgraphic.sld&gt;
     [exec] copying downloadable files... [ 78%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/point_example2.ysld&gt;
     [exec] copying downloadable files... [ 79%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/raster_alphachannel.sld&gt;
     [exec] copying downloadable files... [ 80%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_attributebasedpolygon.ysld&gt;
     [exec] copying downloadable files... [ 80%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/data/app-schema/GeologicUnit_MappingFile.xml&gt;
     [exec] copying downloadable files... [ 81%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_graphicfill.sld&gt;
     [exec] copying downloadable files... [ 82%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_dashdot.ysld&gt;
     [exec] copying downloadable files... [ 83%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/gettingstarted/shapefile-quickstart/nyc_roads.zip&gt;
     [exec] copying downloadable files... [ 83%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_offsetline.ysld&gt;
     [exec] copying downloadable files... [ 84%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/point_pointwithrotatedlabel.sld&gt;
     [exec] copying downloadable files... [ 85%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_simplepolygonwithstroke.ysld&gt;
     [exec] copying downloadable files... [ 85%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_optimizedstyledlabel.ysld&gt;
     [exec] copying downloadable files... [ 86%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/airports0.ysld&gt;
     [exec] copying downloadable files... [ 87%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/polygon_zoombasedpolygon.ysld&gt;
     [exec] copying downloadable files... [ 88%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/line_dashspace.ysld&gt;
     [exec] copying downloadable files... [ 88%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/raster_transparentgradient.ysld&gt;
     [exec] copying downloadable files... [ 89%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/security/usergrouprole/schemas/roles.xsd&gt;
     [exec] copying downloadable files... [ 90%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_simplepointwithstroke.ysld&gt;
     [exec] copying downloadable files... [ 90%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_labelfollowingline.sld&gt;
     [exec] copying downloadable files... [ 91%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/ysld_cookbook_point.zip&gt;
     [exec] copying downloadable files... [ 92%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/tutorials/imagemosaic_timeseries/temperatureLZWdataset.zip&gt;
     [exec] copying downloadable files... [ 92%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/tutorials/imagemosaic_timeseries/snowLZWdataset.zip&gt;
     [exec] copying downloadable files... [ 93%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/workshop/files/point_example2.css&gt;
     [exec] copying downloadable files... [ 94%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/production/scripts/geoserver_suse&gt;
     [exec] copying downloadable files... [ 95%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/ysld/cookbook/artifacts/point_pointwithstyledlabel.ysld&gt;
     [exec] copying downloadable files... [ 95%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/line_railroad.sld&gt;
     [exec] copying downloadable files... [ 96%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_zoombasedpolygon.sld&gt;
     [exec] copying downloadable files... [ 97%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/geowebcache/rest/representations/wmslayer_minimal.xml.txt&gt;
     [exec] copying downloadable files... [ 97%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/cookbook/artifacts/polygon_polygonwithdefaultlabel.sld&gt;
     [exec] copying downloadable files... [ 98%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/tutorials/feature-pregeneralized/streams.zip&gt;
     [exec] copying downloadable files... [ 99%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/services/wms/googleearth/tutorials/time/inet_weu.sld&gt;
     [exec] copying downloadable files... [100%] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/user/source/styling/sld/extensions/z-order/files/roads_no_groups.sld&gt;
     [exec] copying static files... done
     [exec] dumping search index... done
     [exec] dumping object inventory... done
     [exec] build succeeded, 4 warnings.
developer:
full:
[INFO] Executed tasks
[INFO] BUILD SUCCESS
[INFO] Total time: 13.337 s
[INFO] Finished at: 2017-04-12T19:29:12+00:00
[INFO] Final Memory: 16M/283M
[geoserver-master-docs] $ /bin/sh -xe /tmp/hudson8691649343594380444.sh
+ VER=origin/master
+ VER=master
+ BASE=/var/www/geoserver/master/doc/en
+ [ -e /var/www/geoserver/master/doc/en ]
+ cd doc/en
+ rm -rf /var/www/docs.geoserver.org/htdocs/api/docs/*.yaml
+ cp src/main/resources/api/coverages.yaml src/main/resources/api/coveragestores.yaml src/main/resources/api/datastores.yaml src/main/resources/api/featuretypes.yaml src/main/resources/api/fonts.yaml src/main/resources/api/layergroups.yaml src/main/resources/api/layers.yaml src/main/resources/api/manifests.yaml src/main/resources/api/monitoring.yaml src/main/resources/api/namespaces.yaml src/main/resources/api/owsservices.yaml src/main/resources/api/reload.yaml src/main/resources/api/security.yaml src/main/resources/api/settings.yaml src/main/resources/api/structuredcoverages.yaml src/main/resources/api/styles.yaml src/main/resources/api/templates.yaml src/main/resources/api/transforms.yaml src/main/resources/api/wmslayers.yaml src/main/resources/api/wmsstores.yaml src/main/resources/api/workspaces.yaml /var/www/docs.geoserver.org/htdocs/api/docs/
cp: target `/var/www/docs.geoserver.org/htdocs/api/docs/' is not a directory
Build step 'Execute shell' marked build as failure
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/838/changes&gt;
