[Geoserver-devel] Build failed in Jenkins: geoserver-master-live-docs #945
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/945/changes&gt;
Changes:
[tbarsballe] Add troubleshooting information for installing geoserver on a Mac with
[jody.garnett] update with query parameter documetation
[jody.garnett] revise based on feedback
Started by an SCM change
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/&gt;
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git -c core.askpass=true fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision bdff184d71791da9fdfabe312bd82decf443f9c6 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f bdff184d71791da9fdfabe312bd82decf443f9c6
> git rev-list 867ed88c0483185e32b8db206cb89feea68711d0 # timeout=10
[geoserver-master-docs] $ /opt/apache-maven-3.3.9/bin/mvn -f doc/en/pom.xml compile
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
[INFO] Scanning for projects...
[INFO]
[INFO] Building GeoServer English Documentation 2.12-SNAPSHOT
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (coverages) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coverages.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (coverageStores) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (datastores) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/datastores.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (featureTypes) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml&gt;
[ERROR]
java.lang.RuntimeException: Could not process operation:
  Tag: default
  Operation: deleteFeatureType
  Resource: delete /workspaces/{workspaceName}/datastores/{datastoreName}/featuretypes/{featureTypeName}
  Definitions: {FeatureTypeInfo=io.swagger.models.ModelImpl@anonymised.com, MetadataEntry=io.swagger.models.ModelImpl@anonymised.com, inline_response_200_featureTypes_featureType=io.swagger.models.ModelImpl@anonymised.com, inline_response_200_featureTypes=io.swagger.models.ModelImpl@anonymised.com, inline_response_200=io.swagger.models.ModelImpl@anonymised.com, inline_response_200_1=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_namespace=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_keywords=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_metadatalinks_metadataLink=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_metadatalinks=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_dataLinks_metadataLink=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_dataLinks=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_nativeBoundingBox=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_latLonBoundingBox=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_store=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_responseSRS=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_attributes_attribute=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_attributes=io.swagger.models.ModelImpl@anonymised.com}
  Exception: null
  at io.swagger.codegen.DefaultGenerator.processOperation(DefaultGenerator.java:827)
  at io.swagger.codegen.DefaultGenerator.processPaths(DefaultGenerator.java:731)
  at io.swagger.codegen.DefaultGenerator.generateApis(DefaultGenerator.java:356)
  at io.swagger.codegen.DefaultGenerator.generate(DefaultGenerator.java:666)
  at io.swagger.codegen.plugin.CodeGenMojo.execute(CodeGenMojo.java:338)
  at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
  at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
  at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
  at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
  at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
  at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
  at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: java.lang.NullPointerException
  at io.swagger.codegen.DefaultCodegen.updateCodegenPropertyEnum(DefaultCodegen.java:3445)
  at io.swagger.codegen.DefaultCodegen.fromParameter(DefaultCodegen.java:2405)
  at io.swagger.codegen.DefaultCodegen.fromOperation(DefaultCodegen.java:2121)
  at io.swagger.codegen.DefaultGenerator.processOperation(DefaultGenerator.java:774)
  ... 26 more
[INFO] BUILD FAILURE
[INFO] Total time: 3.277 s
[INFO] Finished at: 2017-08-25T23:05:28+00:00
[INFO] Final Memory: 15M/173M
[ERROR] Failed to execute goal io.swagger:swagger-codegen-maven-plugin:2.2.2:generate (featureTypes) on project gs-docs: Code generation failed. See above for the full exception. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/946/changes&gt;
Changes:
[jody.garnett] Minor additional docs fixes.
Checking out Revision 904799477d4f33a3690ed44700ba2a1d243719e1 (origin/master)
> git checkout -f 904799477d4f33a3690ed44700ba2a1d243719e1
> git rev-list bdff184d71791da9fdfabe312bd82decf443f9c6 # timeout=10
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
  Tag: default
  Exception: null
  ... 26 more
[INFO] Total time: 2.580 s
[INFO] Finished at: 2017-08-26T00:45:28+00:00
[INFO] Final Memory: 16M/206M
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/947/changes&gt;
Changes:
[smithkm] Add SecurityDispatcher to GWC context
[smithkm] Using the GWC Data Security Framework
[smithkm] Apply data security to direct integration
[smithkm] Tile Coordinate security check no longer needed as upstream GWC
[smithkm] Comments for GWC security framework
Checking out Revision 5c7a6f3d7c2004efd5e2205094ad5b7a7438bd83 (origin/master)
> git checkout -f 5c7a6f3d7c2004efd5e2205094ad5b7a7438bd83
> git rev-list 904799477d4f33a3690ed44700ba2a1d243719e1 # timeout=10
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
  Tag: default
  Exception: null
  ... 26 more
[INFO] Total time: 5.415 s
[INFO] Finished at: 2017-08-27T00:16:37+00:00
[INFO] Final Memory: 16M/205M
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/948/changes&gt;
Changes:
[niels] GEOS-8239 Support Limits and LayerDetails in geofence internal server
Checking out Revision 81e53eddd0c138a1ae11d3dd76409e544ddedb0d (origin/master)
> git checkout -f 81e53eddd0c138a1ae11d3dd76409e544ddedb0d
> git rev-list 5c7a6f3d7c2004efd5e2205094ad5b7a7438bd83 # timeout=10
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
  Tag: default
  Exception: null
  ... 26 more
[INFO] Total time: 5.352 s
[INFO] Finished at: 2017-08-28T13:21:03+00:00
[INFO] Final Memory: 15M/171M
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/949/changes&gt;
Changes:
[niels] GEOS-8239: fix applicationContext.xml
Checking out Revision 14e2d0e8270ffd84874a621984047fd1700fb35e (origin/master)
> git checkout -f 14e2d0e8270ffd84874a621984047fd1700fb35e
> git rev-list 81e53eddd0c138a1ae11d3dd76409e544ddedb0d # timeout=10
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
  Tag: default
  Exception: null
  ... 26 more
[INFO] Total time: 3.451 s
[INFO] Finished at: 2017-08-28T14:55:27+00:00
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/950/changes&gt;
Changes:
[antonio.cerciello] GEOS-7988
[antonio.cerciello] Root Layer Title and Root Layer Abstract are now independent
[antonio.cerciello] Test check moved from the new test class to CapabilitiesTest
[antonio.cerciello] fix for merge
[antonio.cerciello] Doc Update
[antonio.cerciello] Description
[antonio.cerciello] Controls on Title and Abstract are now separated
[tbarsballe] [GEOS-8178] check if necessary to prepend EPSG to CRS identifier for OL
Checking out Revision 367746f1dc26bd85bdc10c221c926ef7c1b27503 (origin/master)
> git checkout -f 367746f1dc26bd85bdc10c221c926ef7c1b27503
> git rev-list 14e2d0e8270ffd84874a621984047fd1700fb35e # timeout=10
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
  Tag: default
  Exception: null
  ... 26 more
[INFO] Total time: 6.609 s
[INFO] Finished at: 2017-08-28T22:26:32+00:00
[INFO] Final Memory: 15M/174M
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/951/changes&gt;
Changes:
[lore.pini] Fix data section typos in docs
[tbarsballe] [GEOS-8063] Fix WMS1.3.0 SLD definition can break getcapabilities
[andrea.aime] Actually creating and removing store/layers when playing with the
[jody.garnett] protect against transitive jts dependencies
[andrea.aime] [GEOS-8265] Move GeoPackage support into core
[jody.garnett] GEOS-8267: added support for viewParams in WPS Execute embedded WFS
Checking out Revision 5210f479eef2786a9fea55a4f9eefa744633cace (origin/master)
> git checkout -f 5210f479eef2786a9fea55a4f9eefa744633cace
> git rev-list 367746f1dc26bd85bdc10c221c926ef7c1b27503 # timeout=10
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
  Tag: default
  Exception: null
  ... 26 more
[INFO] Total time: 8.879 s
[INFO] Finished at: 2017-09-04T14:03:18+00:00
[INFO] Final Memory: 15M/144M
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/952/changes&gt;
Changes:
[andrea.aime] [GEOS-8272] Randomness in JPEG 2000 support reader/writer lookup
[dvick] Update GWC context for REST update
[dvick] updating tests to work with the new spring mvc rest api for
[jody.garnett] temp ignore ysld upload tests to restore build, restore before release
[andrea.aime] Make sure a collection can be created outside the default workspace
[andrea.aime] Factor out all layer management in a separate class
[andrea.aime] Documentation for the opensearch-eo community module
Checking out Revision 63d155c15b37842c09e74b064808212e3cce4ac9 (origin/master)
> git checkout -f 63d155c15b37842c09e74b064808212e3cce4ac9
> git rev-list 5210f479eef2786a9fea55a4f9eefa744633cace # timeout=10
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
  Tag: default
  Exception: null
  ... 26 more
[INFO] Total time: 5.810 s
[INFO] Finished at: 2017-09-08T16:57:41+00:00
[INFO] Final Memory: 15M/172M
[ERROR]
[ERROR]
Hum,
I just added a new yaml file among the API ones, however I tried building the revision
before and it still failed in the same way (so, does not look like it’s the fault of the latest change).
I saw that the codegen plugin has a minor update version, 2.2.3, that survives generation of the featureTypes,
but then dies in reload:
[INFO] — swagger-codegen-maven-plugin:2.2.3:generate (reload) @ gs-docs —
[INFO] reading from /home/aaime/devel/git-gs/doc/en/api/1.0.0/reload.yaml
[WARNING] Output directory does not exist, or is inaccessible. No file (.swager-codegen-ignore) will be evaluated.
[ERROR]
at io.swagger.codegen.languages.StaticHtmlGenerator.preprocessSwagger(StaticHtmlGenerator.java:186)
at io.swagger.codegen.DefaultGenerator.configureGeneratorProperties(DefaultGenerator.java:134)
at io.swagger.codegen.DefaultGenerator.generate(DefaultGenerator.java:687)
at io.swagger.codegen.plugin.CodeGenMojo.execute(CodeGenMojo.java:534)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:154)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:146)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:117)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:81)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:309)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:194)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:107)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:993)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:345)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:191)
at java.lang.reflect.Method.invoke(Method.java:498)
Trying to see if I can make it build
On Fri, Sep 8, 2017 at 6:57 PM, <monitor@anonymised.com> wrote:
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/952/changes>
Changes:
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/>
git -c core.askpass=true fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/:refs/remotes/origin/
Java HotSpot™ 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
[INFO] Scanning for projects…
[INFO]
[INFO]
[INFO] — swagger-codegen-maven-plugin:2.2.2:generate (coverages) @ gs-docs —
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coverages.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/coverages/index.html>
[INFO]
[INFO] — swagger-codegen-maven-plugin:2.2.2:generate (coverageStores) @ gs-docs —
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/coveragestores/index.html>
[INFO]
[INFO] — swagger-codegen-maven-plugin:2.2.2:generate (datastores) @ gs-docs —
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/datastores.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/target/api/datastores/index.html>
[INFO]
[INFO] — swagger-codegen-maven-plugin:2.2.2:generate (featureTypes) @ gs-docs —
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml>
[ERROR]
Tag: default
Definitions: {FeatureTypeInfo=io.swagger.models.ModelImpl@anonymised.com4654…, MetadataEntry=io.swagger.models.ModelImpl@anonymised.com, inline_response_200_featureTypes_featureType=io.swagger.models.ModelImpl@1ed8beea, inline_response_200_featureTypes=io.swagger.models.ModelImpl@anonymised.com, inline_response_200=io.swagger.models.ModelImpl@9ecdda9d, inline_response_200_1=io.swagger.models.ModelImpl@1ed910c2, FeatureTypeInfo_namespace=io.swagger.models.ModelImpl@7d998a8, FeatureTypeInfo_keywords=io.swagger.models.ModelImpl@6c4617eb, FeatureTypeInfo_metadatalinks_metadataLink=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_metadatalinks=io.swagger.models.ModelImpl@532beff3, FeatureTypeInfo_dataLinks_metadataLink=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_dataLinks=io.swagger.models.ModelImpl@e3bc98c1, FeatureTypeInfo_nativeBoundingBox=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_latLonBoundingBox=io.swagger.models.ModelImpl@anonymised.com…4661…, FeatureTypeInfo_store=io.swagger.models.ModelImpl@4f4cce31, FeatureTypeInfo_responseSRS=io.swagger.models.ModelImpl@1e0939ed, FeatureTypeInfo_attributes_attribute=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_attributes=io.swagger.models.ModelImpl@e5e99c7b}
Exception: null
… 26 more
[ERROR] Failed to execute goal io.swagger:swagger-codegen-maven-plugin:2.2.2:generate (featureTypes) on project gs-docs: Code generation failed. See above for the full exception. → [Help 1]
[ERROR]
[ERROR]
Build step ‘Invoke top-level Maven targets’ marked build as failure
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/953/changes&gt;
Andrea I am not seeing this failure locally, is it specific to the new yaml file you are working on?
Jody Garnett
On 8 September 2017 at 10:07, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hum,
[ERROR]
Geoserver-devel@anonymised.comrge.net
Changes:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
Tag: default
Definitions: {FeatureTypeInfo=io.swagger.models.ModelImpl@anonymised.com, MetadataEntry=io.swagger.models.ModelImpl@anonymised.com, inline_response_200_featureTypes_featureType=io.swagger.models.ModelImpl@anonymised.com, inline_response_200_featureTypes=io.swagger.models.ModelImpl@8fd0d5b3, inline_response_200=io.swagger.models.ModelImpl@anonymised.com, inline_response_200_1=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_namespace=io.swagger.models.ModelImpl@anonymised.com8, FeatureTypeInfo_keywords=io.swagger.models.ModelImpl@anonymised.comb, FeatureTypeInfo_metadatalinks_metadataLink=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_metadatalinks=io.swagger.models.ModelImpl@anonymised.com2beff3, FeatureTypeInfo_dataLinks_metadataLink=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_dataLinks=io.swagger.models.ModelImpl@anonymised.comc1, FeatureTypeInfo_nativeBoundingBox=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_latLonBoundingBox=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_store=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_responseSRS=io.swagger.models.ModelImpl@anonymised.com39ed, FeatureTypeInfo_attributes_attribute=io.swagger.models.ModelImpl@anonymised.com, FeatureTypeInfo_attributes=io.swagger.models.ModelImpl@anonymised.comc7b}
Exception: null
… 26 more
[ERROR]
[ERROR]
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Nope, and I’ve already fixed it :slight_smile:
mvn process-resources
[INFO] reading from /Users/jody/java/geoserver/jive/doc/en/api/1.0.0/featuretypes.yaml
[INFO] writing file /Users/jody/java/geoserver/jive/doc/en/target/api/featuretypes/index.html
[INFO]
[INFO] — swagger-codegen-maven-plugin:2.2.2:generate (importer-data) @ gs-docs —
[INFO] reading from /Users/jody/java/geoserver/jive/doc/en/api/1.0.0/importerData.yaml
[INFO] writing file /Users/jody/java/geoserver/jive/doc/en/target/api/importerData/index.html
[INFO] BUILD SUCCESS
Jody Garnett
Hum,
[ERROR]
Changes:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
Tag: default
Exception: null
… 26 more
[ERROR]
[ERROR]
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
