[emerkle] Update Geogig plugin to incorporate web api conversion to spring.
[emerkle] Replace objectDatabase reference with conflictsDatabase
[emerkle] Re-enable the plugin for GeoGig in the communityRelease
[emerkle] Implement ability for provider to retreive repository ID
[andrea.aime] Update JAI-EXT to version 1.0.16
[github] Rest API Swagger doc QA - coverages and coveragestores (#2525)
Started by an SCM change
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/>
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git -c core.askpass=true fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision 2c0db7eab7dde24727427eb82b224f34da376e09 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 2c0db7eab7dde24727427eb82b224f34da376e09
> git rev-list 3c5093ca319243301e84d70e4bfcf4f48216562e # timeout=10
[geoserver-master-docs] $ /opt/apache-maven-3.3.9/bin/mvn -f doc/en/pom.xml compile
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
[INFO] Scanning for projects...
[INFO]
[INFO] Building GeoServer English Documentation 2.12-SNAPSHOT
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (coverages) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coverages.yaml>
[ERROR] failed to read resource listing
com.fasterxml.jackson.core.JsonParseException: Unexpected character ('-' (code 45)) in numeric value: expected digit (0-9) to follow minus sign, for valid numeric value
at [Source: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-live-docs/ws/doc/en/api/1.0.0/coverages.yaml;> line: 1, column: 3]
at com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:1702)
at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:558)
at com.fasterxml.jackson.core.base.ParserBase.reportUnexpectedNumberChar(ParserBase.java:1058)
at com.fasterxml.jackson.core.json.UTF8StreamJsonParser._handleInvalidNumberStart(UTF8StreamJsonParser.java:2811)
at com.fasterxml.jackson.core.json.UTF8StreamJsonParser._parseNegNumber(UTF8StreamJsonParser.java:1446)
at com.fasterxml.jackson.core.json.UTF8StreamJsonParser._nextTokenNotInObject(UTF8StreamJsonParser.java:861)
at com.fasterxml.jackson.core.json.UTF8StreamJsonParser.nextToken(UTF8StreamJsonParser.java:772)
at com.fasterxml.jackson.databind.ObjectMapper._initForReading(ObjectMapper.java:3834)
at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:3783)
at com.fasterxml.jackson.databind.ObjectMapper.readTree(ObjectMapper.java:2431)
at io.swagger.parser.SwaggerCompatConverter.readResourceListing(SwaggerCompatConverter.java:189)
at io.swagger.parser.SwaggerCompatConverter.read(SwaggerCompatConverter.java:116)
at io.swagger.parser.SwaggerParser.read(SwaggerParser.java:74)
at io.swagger.codegen.config.CodegenConfigurator.toClientOptInput(CodegenConfigurator.java:419)
at io.swagger.codegen.plugin.CodeGenMojo.execute(CodeGenMojo.java:317)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
[ERROR]
java.lang.RuntimeException: missing swagger input or config!
at io.swagger.codegen.DefaultGenerator.generate(DefaultGenerator.java:651)
at io.swagger.codegen.plugin.CodeGenMojo.execute(CodeGenMojo.java:338)
[INFO] BUILD FAILURE
[INFO] Total time: 4.195 s
[INFO] Finished at: 2017-09-26T00:02:53+00:00
[INFO] Final Memory: 13M/168M
[ERROR] Failed to execute goal io.swagger:swagger-codegen-maven-plugin:2.2.2:generate (coverages) on project gs-docs: Code generation failed. See above for the full exception. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[github] Swagger API Docs - proper style example (#2532)
Checking out Revision 3eca86d1143538af184e2e73db5c6ace5b6925be (origin/master)
> git checkout -f 3eca86d1143538af184e2e73db5c6ace5b6925be
> git rev-list 2c0db7eab7dde24727427eb82b224f34da376e09 # timeout=10
[INFO]
[INFO]
[ERROR]
[INFO] Total time: 2.156 s
[INFO] Finished at: 2017-09-26T00:06:34+00:00
[INFO] Final Memory: 13M/208M
[ERROR]
[ERROR]
[github] Rest API Swagger doc QA - namespaces (#2528)
Checking out Revision 98d664829c7229f44fcfa24bc4ab659f2c8cb41e (origin/master)
> git checkout -f 98d664829c7229f44fcfa24bc4ab659f2c8cb41e
> git rev-list 3eca86d1143538af184e2e73db5c6ace5b6925be # timeout=10
[INFO]
[INFO]
[ERROR]
[INFO] Total time: 2.084 s
[INFO] Finished at: 2017-09-26T00:11:39+00:00
[INFO] Final Memory: 13M/204M
[ERROR]
[ERROR]
[nuno.oliveira] [GEOS-8283] Add an extension point for new tabs in GeoServer status
[nuno.oliveira] [GEOS-8285] Add clause in GeoServer LICENSE for OSHI library
[nuno.oliveira] [GEOS-8284] Create status monitoring community module
Checking out Revision 21f0254e631ad98e6515410c2067fd721a93b2f6 (origin/master)
> git checkout -f 21f0254e631ad98e6515410c2067fd721a93b2f6
> git rev-list 98d664829c7229f44fcfa24bc4ab659f2c8cb41e # timeout=10
[INFO]
[INFO]
[ERROR]
[INFO] Total time: 4.446 s
[INFO] Finished at: 2017-09-26T07:38:01+00:00
[ERROR]
[ERROR]
[github] Rest API Swagger doc QA - layer groups (#2531)
[github] Rest API Swagger doc QA - layers (#2534)
Checking out Revision 726c61a130c160562b65db5bb2cd64552a4f376f (origin/master)
> git checkout -f 726c61a130c160562b65db5bb2cd64552a4f376f
> git rev-list 21f0254e631ad98e6515410c2067fd721a93b2f6 # timeout=10
[INFO]
[INFO]
[ERROR]
[INFO] Total time: 21.994 s
[INFO] Finished at: 2017-09-26T16:07:47+00:00
[INFO] Final Memory: 13M/179M
[ERROR]
[ERROR]
[github] Rest API Swagger doc QA - templates (#2537)
Checking out Revision c5e155e44541901b91d20fdd794cf030cfc6e3cb (origin/master)
> git checkout -f c5e155e44541901b91d20fdd794cf030cfc6e3cb
> git rev-list 726c61a130c160562b65db5bb2cd64552a4f376f # timeout=10
[INFO]
[INFO]
[ERROR]
[INFO] Total time: 1.866 s
[INFO] Finished at: 2017-09-26T16:11:37+00:00
[INFO] Final Memory: 13M/207M
[ERROR]
[ERROR]
[github] Rest API Swagger doc QA - security (#2539)
[github] Rest API Swagger doc QA - settings (#2536)
Checking out Revision 0ffaf340ac3056b5ecb6e31496650981f7ff0808 (origin/master)
> git checkout -f 0ffaf340ac3056b5ecb6e31496650981f7ff0808
> git rev-list c5e155e44541901b91d20fdd794cf030cfc6e3cb # timeout=10
[INFO]
[INFO]
[ERROR]
[INFO] Total time: 2.047 s
[INFO] Finished at: 2017-09-26T16:51:38+00:00
[INFO] Final Memory: 13M/206M
[ERROR]
[ERROR]
[github] Rest API Swagger doc QA - wms and wmts stores and layers (#2527)
Checking out Revision 4cacc49ac257689095e4fad49a25c08eea824384 (origin/master)
> git checkout -f 4cacc49ac257689095e4fad49a25c08eea824384
> git rev-list 0ffaf340ac3056b5ecb6e31496650981f7ff0808 # timeout=10
[INFO]
[INFO]
[ERROR]
[INFO] Total time: 2.083 s
[INFO] Finished at: 2017-09-26T18:01:38+00:00
[INFO] Final Memory: 13M/169M
[ERROR]
[ERROR]
[tbarsballe] [GEOS-8300] Prevent extension from overriding format parameter when
[tbarsballe] Rest API Swagger doc QA - resources
[github] Rest API Swagger doc QA - datastores and featuretypes (#2526)
Checking out Revision a2cb6f17455231decd4b0b4de28e9825bb8ba2cc (origin/master)
> git checkout -f a2cb6f17455231decd4b0b4de28e9825bb8ba2cc
> git rev-list 4cacc49ac257689095e4fad49a25c08eea824384 # timeout=10
[INFO]
[INFO]
[ERROR]
[INFO] Total time: 1.847 s
[INFO] Finished at: 2017-09-26T18:31:38+00:00
[INFO] Final Memory: 13M/170M
[ERROR]
[ERROR]
