[Geoserver-devel] Build failed in Jenkins: GeoServer-Master » Main Module #1788
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/1788/&gt;
[...truncated 173 lines...]
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.076 sec
Running org.geoserver.ows.kvp.NamespaceKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.platform.GeoServerExtensionsHelperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.GeoServerCustomAuthTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.124 sec
Running org.geoserver.security.GeoServerCustomFilterTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.404 sec
Running org.geoserver.security.GeoServerCustomSecurityProviderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.077 sec
Running org.geoserver.security.GeoServerRoleFilterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.045 sec
Running org.geoserver.security.GeoServerSecurityManagerTest
This file was created at 2015/06/15 10:17:03
The current master password is: geoserver
Test the master password by logging in as user "root"
This file should be removed after reading !!!.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.092 sec
Running org.geoserver.security.GeoserverRequestMatcherTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.187 sec
Running org.geoserver.security.GroupAdminServiceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.17 sec
Running org.geoserver.security.KeyStoreProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.107 sec
Running org.geoserver.security.MigrateFrom_2_2_Test
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.529 sec
Running org.geoserver.security.auth.AuthenticationCacheFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.293 sec
Running org.geoserver.security.auth.AuthenticationFilterTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.697 sec
Running org.geoserver.security.auth.GeoServerRootAuthenticationProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.311 sec
Running org.geoserver.security.auth.GuavaAuthenticationCacheTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.09 sec
Running org.geoserver.security.auth.LRUAuthenticationCacheTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.645 sec
Running org.geoserver.security.decorators.DecoratingWMSLayerInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.decorators.SecuredFeatureCollectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.decorators.SecuredGetMapRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.decorators.SecuredGridCoverage2DReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.file.FileTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.218 sec
Running org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest
Running org.geoserver.security.impl.AdvertisedCatalogTest
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.452 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.546 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.072 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.076 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Running org.geoserver.security.impl.SecureCatalogImplFilterTest
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.094 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.123 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Running org.geoserver.security.password.GeoServerMultiplexingPasswordEncoderTest
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.418 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.576 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.076 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.232 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Running org.geoserver.security.validation.PasswordValidatorTest
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.108 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.046 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.154 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.232 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.324 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.494 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.25 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.359 sec
Running org.geoserver.util.DefaultCacheProviderTest
15 giu 10:18:10 WARN [geoserver.util] - Multiple Cache Providers in context: testCacheProvider1, testCacheProvider2
  Using testCacheProvider1. Override by setting system property GEOSERVER_DEFAULT_CACHE_PROVIDER
Tests run: 5, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.016 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.562 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.92 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.39 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.279 sec <<< FAILURE!
testNadCon(org.vfny.geoserver.crs.OvverideTransformationsTest) Time elapsed: 63 sec <<< ERROR!
org.opengis.referencing.FactoryException: Database failure while creating a 'Ellipsoid' object for code "7008".
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.databaseFailure(DirectEpsgFactory.java:3061)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createEllipsoid(DirectEpsgFactory.java:1312)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createEllipsoid(BufferedAuthorityFactory.java:510)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createDatum(DirectEpsgFactory.java:1635)
  at org.geotools.referencing.factory.AbstractAuthorityFactory.createGeodeticDatum(AbstractAuthorityFactory.java:276)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createGeodeticDatum(BufferedAuthorityFactory.java:489)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createCoordinateReferenceSystem(DirectEpsgFactory.java:1983)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:783)
  at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
  at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
  at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:644)
  at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
  at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
  at org.geotools.referencing.CRS.decode(CRS.java:520)
  at org.geotools.referencing.CRS.decode(CRS.java:448)
  at org.vfny.geoserver.crs.OvverideTransformationsTest.testNadCon(OvverideTransformationsTest.java:111)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.sql.SQLException: Database lock acquisition failure: attempt to connect while db opening /closing
  at org.hsqldb.jdbc.JDBCUtil.sqlException(Unknown Source)
  at org.hsqldb.jdbc.JDBCConnection.<init>(Unknown Source)
  at org.hsqldb.jdbc.JDBCDriver.getConnection(Unknown Source)
  at org.hsqldb.jdbc.JDBCDataSource.getConnection(Unknown Source)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.getConnection(DirectEpsgFactory.java:3262)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.prepareStatement(DirectEpsgFactory.java:779)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createEllipsoid(DirectEpsgFactory.java:1255)
  ... 51 more
Caused by: org.hsqldb.HsqlException: Database lock acquisition failure: attempt to connect while db opening /closing
  at org.hsqldb.error.Error.error(Unknown Source)
  at org.hsqldb.DatabaseManager.getDatabase(Unknown Source)
  at org.hsqldb.DatabaseManager.newSession(Unknown Source)
  ... 58 more
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.17 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.11 sec
Results :
Tests in error:
  testNadCon(org.vfny.geoserver.crs.OvverideTransformationsTest): Database failure while creating a 'Ellipsoid' object for code "7008".
Tests run: 666, Failures: 0, Errors: 1, Skipped: 2
[JENKINS] Recording test results
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/1789/&gt;
