See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/1792/>
[...truncated 1826 lines...]
Tests run: 48, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.445 sec
Running org.geoserver.config.GeoServerPropertyConfigurerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.config.ServicePersisterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.357 sec
Running org.geoserver.config.UpdateSequenceListenerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.155 sec
Running org.geoserver.config.util.AuthorityURLInfoInfoListConverterTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Running org.geoserver.config.util.LayerIdentifierInfoListConverterTest
[{"authority":"auth1","identifier":"IDENTIFIER_1"},{"authority":"auth2","identifier":"IDENTIFIER_2"}]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.config.util.XStreamPersisterTest
Tests run: 25, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.156 sec
Running org.geoserver.data.jdbc.GenericUnWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.data.test.PropertyDataStoreRelativeUrlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.108 sec
Running org.geoserver.data.util.CoverageUtilsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.data.util.IOUtilsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.feature.ReprojectingFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.14 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.062 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceMockTest
Running org.geoserver.feature.retype.RetypingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.filters.FlushSafeFilterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.filters.GZipFilterTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.function.InstanceOfTest
Running org.geoserver.logging.LegacyLoggingImporterTest
Running org.geoserver.logging.LoggingStartupContextListenerTest
log4j:WARN No appenders could be found for logger (org.geoserver.logging).
log4j:WARN Please initialize the log4j system properly.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.ows.CustomManglerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.139 sec
Running org.geoserver.ows.LocalWorkspaceSecureCatalogTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.124 sec
Running org.geoserver.ows.kvp.NamespaceKvpParserTest
Running org.geoserver.platform.GeoServerExtensionsHelperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.GeoServerCustomAuthTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.341 sec
Running org.geoserver.security.GeoServerCustomFilterTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.358 sec
Running org.geoserver.security.GeoServerCustomSecurityProviderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.123 sec
Running org.geoserver.security.GeoServerRoleFilterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.061 sec
Running org.geoserver.security.GeoServerSecurityManagerTest
This file was created at 2015/06/16 19:18:01
The current master password is: geoserver
Test the master password by logging in as user "root"
This file should be removed after reading !!!.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.108 sec
Running org.geoserver.security.GeoserverRequestMatcherTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.187 sec
Running org.geoserver.security.GroupAdminServiceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.185 sec
Running org.geoserver.security.KeyStoreProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.155 sec
Running org.geoserver.security.MigrateFrom_2_2_Test
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.09 sec
Running org.geoserver.security.auth.AuthenticationCacheFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.87 sec
Running org.geoserver.security.auth.AuthenticationFilterTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.651 sec
Running org.geoserver.security.auth.GeoServerRootAuthenticationProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.295 sec
Running org.geoserver.security.auth.GuavaAuthenticationCacheTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.09 sec
Running org.geoserver.security.auth.LRUAuthenticationCacheTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.645 sec
Running org.geoserver.security.decorators.DecoratingWMSLayerInfoTest
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Running org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.decorators.SecuredFeatureCollectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Running org.geoserver.security.decorators.SecuredGetMapRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.decorators.SecuredGridCoverage2DReaderTest
Running org.geoserver.security.file.FileTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.218 sec
Running org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest
Running org.geoserver.security.impl.AdvertisedCatalogTest
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.437 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.437 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.181 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.951 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Running org.geoserver.security.impl.SecureCatalogImplFilterTest
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.062 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.046 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Running org.geoserver.security.password.GeoServerMultiplexingPasswordEncoderTest
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.465 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.997 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.186 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.201 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Running org.geoserver.security.validation.PasswordValidatorTest
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.061 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.03 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.029 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.277 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.65 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.234 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.406 sec
Running org.geoserver.util.DefaultCacheProviderTest
16 giu 19:19:09 WARN [geoserver.util] - Multiple Cache Providers in context: testCacheProvider1, testCacheProvider2
Using testCacheProvider1. Override by setting system property GEOSERVER_DEFAULT_CACHE_PROVIDER
Tests run: 5, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.016 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.515 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.92 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.422 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.248 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.076 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Running org.vfny.geoserver.util.ResponseUtilsTest
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.093 sec
Results :
Tests in error:
testMissingNullValuesInCoverageDimensions(org.geoserver.catalog.ResourcePoolTest): Error persisting CoverageInfoImpl[DEM] to workspaces/wcs/DEM/DEM/coverage.xml
testMosaicParameters(org.geoserver.catalog.impl.CatalogBuilderIntTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testLargeNDMosaic(org.geoserver.catalog.impl.CatalogBuilderIntTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testFeatureTypeNoSRS(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testEmptyLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testFeatureType(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testLatLonBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testGeometryless(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testSingleBandedCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testLookupSRSDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testSetupBoundsDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testMetadataFromFeatueSource(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testEmptyBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testWMSLayer130crs84(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testGenericStyle(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testMultiBandCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testWMSLayer111(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testWMSLayer130(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
Tests run: 666, Failures: 0, Errors: 19, Skipped: 2
[JENKINS] Recording test results
[JENKINS] Archiving disabled
