See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/1924/>
[...truncated 5193 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 1.342 sec <<< FAILURE!
testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest) Time elapsed: 1045 sec <<< ERROR!
org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:3002" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:951)
at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:316)
at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:390)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:783)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:520)
at org.geotools.referencing.CRS.decode(CRS.java:448)
at org.vfny.geoserver.crs.OvverideTransformationsTest.testFallbackOnEPSGDatabaseStd(OvverideTransformationsTest.java:97)
testOverrideEPSGOperation(org.vfny.geoserver.crs.OvverideTransformationsTest) Time elapsed: 0 sec <<< ERROR!
org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4269" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
at org.vfny.geoserver.crs.OvverideTransformationsTest.testOverrideEPSGOperation(OvverideTransformationsTest.java:78)
testNadCon(org.vfny.geoserver.crs.OvverideTransformationsTest) Time elapsed: 0 sec <<< ERROR!
org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4138" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
at org.vfny.geoserver.crs.OvverideTransformationsTest.testNadCon(OvverideTransformationsTest.java:111)
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.435 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.094 sec
Results :
Failed tests: testCannotRead(org.geoserver.security.impl.SecureCatalogIntegrationTest): Should have failed with a security exception
Tests in error:
modificationProxySerializeTest(org.geoserver.catalog.CatalogIntegrationTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/default6078945883980583917data/DEM/tazdem.tiff> with format GeoTIFF
testNamespaceWorkspaceListenerAttached(org.geoserver.catalog.CatalogIntegrationTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/default4955810119606323981data/DEM/tazdem.tiff> with format GeoTIFF
testReprojectLayerGroup(org.geoserver.catalog.CatalogIntegrationTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/default941770673582473529data/DEM/tazdem.tiff> with format GeoTIFF
testWorkspaceRemoveAndReadd(org.geoserver.catalog.CatalogIntegrationTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/default1800491499203554954data/DEM/tazdem.tiff> with format GeoTIFF
testCascadeDeleteWorkspaceSpecific(org.geoserver.catalog.CatalogIntegrationTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/default5109191500910036299data/DEM/tazdem.tiff> with format GeoTIFF
testBands(org.geoserver.catalog.CoverageViewTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/default5436893461066944794data/DEM/tazdem.tiff> with format GeoTIFF
testCoverageView(org.geoserver.catalog.CoverageViewTest)
testSimpleLoop(org.geoserver.catalog.LayerGroupHelperTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testAllStylesForRendering(org.geoserver.catalog.LayerGroupHelperTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testSimpleLoopWithNotEqualGroups(org.geoserver.catalog.LayerGroupHelperTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testBoundsCRS(org.geoserver.catalog.LayerGroupHelperTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testAllLayers(org.geoserver.catalog.LayerGroupHelperTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testAllStyles(org.geoserver.catalog.LayerGroupHelperTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testBounds(org.geoserver.catalog.LayerGroupHelperTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testAllLayersForRendering(org.geoserver.catalog.LayerGroupHelperTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testFeatureTypeCacheInstance(org.geoserver.catalog.ResourcePoolTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/default4832297537186651328data/DEM/tazdem.tiff> with format GeoTIFF
testConfigureFeatureTypeCacheSize(org.geoserver.catalog.ResourcePoolTest)
testCacheClearing(org.geoserver.catalog.ResourcePoolTest)
testGeoServerReload(org.geoserver.catalog.ResourcePoolTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/default7075164047579505747data/DEM/tazdem.tiff> with format GeoTIFF
testPreserveStructuredReader(org.geoserver.catalog.ResourcePoolTest)
testSEStyleWithRelativePathProtocol(org.geoserver.catalog.ResourcePoolTest)
testAttributeCache(org.geoserver.catalog.ResourcePoolTest)
testDispose(org.geoserver.catalog.ResourcePoolTest)
testDropCoverageStore(org.geoserver.catalog.ResourcePoolTest)
testSEStyleWithRelativePath(org.geoserver.catalog.ResourcePoolTest)
testMissingNullValuesInCoverageDimensions(org.geoserver.catalog.ResourcePoolTest)
testMosaicParameters(org.geoserver.catalog.impl.CatalogBuilderIntTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/default4694735483268486694data/DEM/tazdem.tiff> with format GeoTIFF
testLargeNDMosaic(org.geoserver.catalog.impl.CatalogBuilderIntTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testFeatureTypeNoSRS(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testEmptyLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testFeatureType(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testLatLonBounds(org.geoserver.catalog.impl.CatalogBuilderTest): No code "EPSG:32632" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testGeometryless(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testSingleBandedCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testLookupSRSDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testSetupBoundsDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testMetadataFromFeatueSource(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testEmptyBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testWMSLayer130crs84(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testGenericStyle(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testMultiBandCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testWMSLayer111(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testWMSLayer130(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testLayer(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testFeatureType(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testWMSLayer(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testSRSConverter(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testVirtualTable(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testCRSConverterInvalidWKT(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:3575" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testCRSConverter(org.geoserver.config.util.XStreamPersisterTest): No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testPerserveUserData(org.geoserver.feature.ReprojectingFeatureCollectionTest): SRS 'epsg:4326' unknown:No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testLockUnlockFilter(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
testGetFeaturesReader(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
testFeautureSourceFidFilter(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
testDelete(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
testLookupFeatureType(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
testModify(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
testFeatureReaderFidFilter(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
testLockUnlockQuery(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
testGetFeaturesFeatureSource(org.geoserver.feature.retype.FullyRetypingDataStoreTest): org.geotools.data.DataSourceException: PrimitiveGeoFeature schema not available
testFullAccess(org.geoserver.security.impl.SecureCatalogIntegrationTest): org.geotools.data.DataSourceException: Lines schema not available
testCannotWrite(org.geoserver.security.impl.SecureCatalogIntegrationTest): org.geotools.data.DataSourceException: Deletes schema not available
testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): No reader for <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/default6688171073863400387data/DEM/tazdem.tiff> with format GeoTIFF
testForce(org.vfny.geoserver.ProjectionPolicyTest)
testForceCoverage(org.vfny.geoserver.ProjectionPolicyTest)
testReproject(org.vfny.geoserver.ProjectionPolicyTest)
testWithRename(org.vfny.geoserver.ProjectionPolicyTest)
testOverride(org.vfny.geoserver.crs.OverrideCRSTest): No code "EPSG:3002" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest): No code "EPSG:3002" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testOverrideEPSGOperation(org.vfny.geoserver.crs.OvverideTransformationsTest): No code "EPSG:4269" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
testNadCon(org.vfny.geoserver.crs.OvverideTransformationsTest): No code "EPSG:4138" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
Tests run: 675, Failures: 1, Errors: 72, Skipped: 2
[JENKINS] Recording test results
[JENKINS] Archiving disabled
