[Geoserver-devel] Build failed in Jenkins: GeoServer-Master » Main Module #2430
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/2430/&gt;
[...truncated 370 lines...]
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.156 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.093 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceMockTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.filters.FlushSafeFilterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.filters.GZipFilterTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.function.InstanceOfTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.logging.LegacyLoggingImporterTest
Running org.geoserver.logging.LoggingStartupContextListenerTest
log4j:WARN No appenders could be found for logger (org.geoserver.logging).
log4j:WARN Please initialize the log4j system properly.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.ows.CustomManglerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.232 sec
Running org.geoserver.ows.LocalWorkspaceSecureCatalogTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.357 sec
Running org.geoserver.ows.kvp.NamespaceKvpParserTest
Running org.geoserver.platform.GeoServerExtensionsHelperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.GeoServerCustomAuthTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.373 sec
Running org.geoserver.security.GeoServerCustomFilterTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.7 sec
Running org.geoserver.security.GeoServerCustomSecurityProviderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.233 sec
Running org.geoserver.security.GeoServerRoleFilterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.294 sec
Running org.geoserver.security.GeoServerSecurityManagerTest
This file was created at 2015/12/03 11:08:54
The current master password is: geoserver
Test the master password by logging in as user "root"
This file should be removed after reading !!!.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.248 sec
Running org.geoserver.security.GeoserverRequestMatcherTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.203 sec
Running org.geoserver.security.GroupAdminServiceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.404 sec
Running org.geoserver.security.KeyStoreProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.295 sec
Running org.geoserver.security.MigrateFrom_2_2_Test
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.028 sec
Running org.geoserver.security.auth.AuthenticationCacheFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.979 sec
Running org.geoserver.security.auth.AuthenticationFilterTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.821 sec
Running org.geoserver.security.auth.GeoServerRootAuthenticationProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.528 sec
Running org.geoserver.security.auth.GuavaAuthenticationCacheTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.09 sec
Running org.geoserver.security.auth.LRUAuthenticationCacheTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.645 sec
Running org.geoserver.security.decorators.DecoratingWMSLayerInfoTest
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.decorators.SecuredFeatureCollectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.062 sec
Running org.geoserver.security.decorators.SecuredFeatureStoreTest
Running org.geoserver.security.decorators.SecuredGetMapRequestTest
Running org.geoserver.security.decorators.SecuredGridCoverage2DReaderTest
Running org.geoserver.security.file.FileTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.202 sec
Running org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.032 sec
Running org.geoserver.security.impl.AdvertisedCatalogTest
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.39 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.515 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.352 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.014 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Running org.geoserver.security.impl.SecureCatalogImplFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.248 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Running org.geoserver.security.password.GeoServerMultiplexingPasswordEncoderTest
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.512 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.732 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.201 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.872 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Running org.geoserver.security.validation.PasswordValidatorTest
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.311 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.248 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.341 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.326 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.871 sec <<< FAILURE!
testMigration(org.geoserver.security.xml.XMLUserDetailsServiceTest) Time elapsed: 811 sec <<< FAILURE!
java.lang.AssertionError: expected:<9> but was:<10>
  at org.junit.Assert.fail(Assert.java:88)
  at org.junit.Assert.failNotEquals(Assert.java:743)
  at org.junit.Assert.assertEquals(Assert.java:118)
  at org.junit.Assert.assertEquals(Assert.java:555)
  at org.junit.Assert.assertEquals(Assert.java:542)
  at org.geoserver.security.xml.XMLUserDetailsServiceTest.testMigration(XMLUserDetailsServiceTest.java:99)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.852 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.25 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.453 sec
Running org.geoserver.util.DefaultCacheProviderTest
03 Dec 11:10:06 WARN [geoserver.util] - Multiple Cache Providers in context: testCacheProvider1, testCacheProvider2
  Using testCacheProvider1. Override by setting system property GEOSERVER_DEFAULT_CACHE_PROVIDER
Tests run: 5, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.015 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.468 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.046 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.499 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.389 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Running org.vfny.geoserver.global.xml.WriterHelperTest
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Results :
Failed tests: testMigration(org.geoserver.security.xml.XMLUserDetailsServiceTest): expected:<9> but was:<10>
Tests run: 688, Failures: 1, Errors: 0, Skipped: 2
[JENKINS] Recording test results
[JENKINS] Archiving disabled
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/2431/&gt;
[...truncated 1306 lines...]
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.xml.XMLUserDetailsServiceTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.xml.XMLSecurityConfigValidatorTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.xml.XMLRoleServiceTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.validation.UserGroupStoreValidationWrapperTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.validation.SecurityConfigValidatorTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.validation.RoleStoreValidationWrapperTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.validation.PasswordValidatorTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.validation.MasterPasswordChangeValidatorTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.validation.FilterConfigValidatorTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.rememberme.RememberMeTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.password.URLMasterPasswordProviderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.password.MasterPasswordChangeTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.password.GeoserverPasswordEncoderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.password.GeoServerMultiplexingPasswordEncoderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.MigrateFrom_2_2_Test.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.KeyStoreProviderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.SecureTreeNodeTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.SecureCatalogIntegrationTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.SecureCatalogImplTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.SecureCatalogImplFilterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.RoleHierarchyHelperTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.MemoryUserGroupServiceTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.MemoryUserDetailsServiceTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.MemoryRoleServiceTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.GeoServerUserDaoTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.GeoServerRoleConverterImplTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.DefaultDataAccessManagerTreeTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.DefaultDataAccessManagerAuthTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.DataAccessRuleTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.DataAccessRuleDAOTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.impl.AdvertisedCatalogTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.GroupAdminServiceTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.GeoServerSecurityManagerTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.GeoServerRoleFilterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.GeoserverRequestMatcherTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.GeoServerCustomSecurityProviderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.GeoServerCustomFilterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.GeoServerCustomAuthTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.file.FileTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.decorators.SecuredGridCoverage2DReaderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.decorators.SecuredGetMapRequestTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.decorators.SecuredFeatureStoreTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.decorators.SecuredFeatureSourceTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.decorators.SecuredFeatureCollectionTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.decorators.ReadOnlyDataStoreTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.decorators.ReadOnlyDataAccessTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.decorators.DecoratingWMSLayerInfoTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.auth.LRUAuthenticationCacheTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.auth.GuavaAuthenticationCacheTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.auth.GeoServerRootAuthenticationProviderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.auth.AuthenticationFilterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.security.auth.AuthenticationCacheFilterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.platform.GeoServerExtensionsHelperTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.ows.URLManglersTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.ows.LocalWorkspaceSecureCatalogTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.ows.kvp.NamespaceKvpParserTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.ows.CustomManglerTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.ManifestLoaderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.ManifestLoaderTest$ManifestPropertiesTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.logging.LoggingStartupContextListenerTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.logging.LegacyLoggingImporterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.GeoServerInitStartupListenerTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.function.InstanceOfTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.filters.GZipFilterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.filters.FlushSafeFilterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.filters.BufferedRequestWrapperTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.filters.BufferedRequestStreamTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.feature.retype.RetypingFeatureSourceTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.feature.retype.RetypingFeatureSourceMockTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.feature.retype.RetypingDataStoreTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.feature.retype.FullyRetypingDataStoreTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.feature.ReprojectingFeatureCollectionTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.data.util.IOUtilsTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.data.util.CoverageUtilsTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.data.test.PropertyDataStoreRelativeUrlTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.data.jdbc.GenericUnWrapperTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.util.XStreamPersisterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.util.SecureXStreamTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.util.LayerIdentifierInfoListConverterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.util.AuthorityURLInfoInfoListConverterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.UpdateSequenceListenerTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.ServicePersisterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.LegacyConfigurationImporterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.GeoServerPropertyConfigurerTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.GeoServerPersisterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.GeoServerImplTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.GeoServerDataDirectoryTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.config.DefaultGeoServerLoaderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.StylesTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.StyleGeneratorTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.SchemaMappingTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.ResourcePoolTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.PredicatesTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.LayerGroupHelperTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.util.LegacyCatalogImporterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.ModificationProxyClonerTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.MetadataLinkInfoImplTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.LocalWorkspaceLayersTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.LocalWorkspaceCatalogTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.InfoObjectProxyTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.DataLinkInfoImplTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.CatalogImplTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.CatalogBuilderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.CatalogBuilderIntTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.CascadeRemovalReporterTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.impl.CascadeDeleteVisitorTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.CoverageViewTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.CoverageDimensionCustomizerReaderTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/TEST-org.geoserver.catalog.CatalogIntegrationTest.xml&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.vfny.geoserver.util.SLDValidatorTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.vfny.geoserver.util.ResponseUtilsTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.vfny.geoserver.ProjectionPolicyTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.vfny.geoserver.global.xml.WriterHelperTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.vfny.geoserver.global.GeoserverDataDirectoryTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.vfny.geoserver.crs.OvverideTransformationsTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.vfny.geoserver.crs.OverrideCRSTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.vfny.global.TolerantStartupTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.util.XCQLTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.util.PartialBufferOutputStream2Test.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.util.DefaultCacheProviderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.threadlocals.ThreadLocalsTransferTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.threadlocals.PublicThreadLocalTransferTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.template.GeoServerTemplateLoader2Test.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.template.FeatureWrapperTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.template.DirectFeatureWrapperTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.xml.XMLUserGroupServiceTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.xml.XMLUserDetailsServiceTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.xml.XMLSecurityConfigValidatorTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.xml.XMLRoleServiceTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.validation.UserGroupStoreValidationWrapperTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.validation.SecurityConfigValidatorTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.validation.RoleStoreValidationWrapperTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.validation.PasswordValidatorTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.validation.MasterPasswordChangeValidatorTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.validation.FilterConfigValidatorTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.rememberme.RememberMeTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.password.URLMasterPasswordProviderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.password.MasterPasswordChangeTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.password.GeoserverPasswordEncoderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.password.GeoServerMultiplexingPasswordEncoderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.MigrateFrom_2_2_Test.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.KeyStoreProviderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.SecureTreeNodeTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.SecureCatalogIntegrationTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.SecureCatalogImplTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.SecureCatalogImplFilterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.RoleHierarchyHelperTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.MemoryUserGroupServiceTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.MemoryUserDetailsServiceTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.MemoryRoleServiceTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.GeoServerUserDaoTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.GeoServerRoleConverterImplTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.DefaultDataAccessManagerTreeTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.DefaultDataAccessManagerAuthTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.DataAccessRuleTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.DataAccessRuleDAOTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.impl.AdvertisedCatalogTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.GroupAdminServiceTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.GeoServerSecurityManagerTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.GeoServerRoleFilterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.GeoserverRequestMatcherTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.GeoServerCustomSecurityProviderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.GeoServerCustomFilterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.GeoServerCustomAuthTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.file.FileTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.decorators.SecuredGridCoverage2DReaderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.decorators.SecuredGetMapRequestTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.decorators.SecuredFeatureStoreTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.decorators.SecuredFeatureSourceTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.decorators.SecuredFeatureCollectionTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.decorators.ReadOnlyDataStoreTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.decorators.ReadOnlyDataAccessTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.decorators.DecoratingWMSLayerInfoTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.auth.LRUAuthenticationCacheTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.auth.GuavaAuthenticationCacheTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.auth.GeoServerRootAuthenticationProviderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.auth.AuthenticationFilterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.security.auth.AuthenticationCacheFilterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.platform.GeoServerExtensionsHelperTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.ows.URLManglersTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.ows.LocalWorkspaceSecureCatalogTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.ows.kvp.NamespaceKvpParserTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.ows.CustomManglerTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.ManifestLoaderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.ManifestLoaderTest$ManifestPropertiesTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.logging.LoggingStartupContextListenerTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.logging.LegacyLoggingImporterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.GeoServerInitStartupListenerTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.function.InstanceOfTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.filters.GZipFilterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.filters.FlushSafeFilterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.filters.BufferedRequestWrapperTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.filters.BufferedRequestStreamTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.feature.retype.RetypingFeatureSourceTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.feature.retype.RetypingFeatureSourceMockTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.feature.retype.RetypingDataStoreTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.feature.retype.FullyRetypingDataStoreTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.feature.ReprojectingFeatureCollectionTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.data.util.IOUtilsTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.data.util.CoverageUtilsTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.data.test.PropertyDataStoreRelativeUrlTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.data.jdbc.GenericUnWrapperTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.util.XStreamPersisterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.util.SecureXStreamTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.util.LayerIdentifierInfoListConverterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.util.AuthorityURLInfoInfoListConverterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.UpdateSequenceListenerTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.ServicePersisterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.LegacyConfigurationImporterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.GeoServerPropertyConfigurerTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.GeoServerPersisterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.GeoServerImplTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.GeoServerDataDirectoryTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.config.DefaultGeoServerLoaderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.StylesTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.StyleGeneratorTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.SchemaMappingTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.ResourcePoolTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.PredicatesTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.LayerGroupHelperTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.util.LegacyCatalogImporterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.ModificationProxyClonerTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.MetadataLinkInfoImplTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.LocalWorkspaceLayersTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.LocalWorkspaceCatalogTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.InfoObjectProxyTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.DataLinkInfoImplTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.CatalogImplTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.CatalogBuilderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.CatalogBuilderIntTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.CascadeRemovalReporterTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.impl.CascadeDeleteVisitorTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.CoverageViewTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.CoverageDimensionCustomizerReaderTest.txt&gt;
[INFO] Deleting file <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports/org.geoserver.catalog.CatalogIntegrationTest.txt&gt;
[INFO] Deleting directory <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/org.geoserver$gs-main/ws/target/surefire-reports&gt;
