See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/1013/changes>
Changes:
[breuil] Bump log4j dependency to 1.2.17, to allow configuring rollingPolicy via properties
[tbarsballe] [GEOS-7517] Return HTTP 404 for REST PUT against global styles when style exists in workspace
[tbarsballe] Updated version to 2.10-SNAPSHOT, updated GeoTools dependency to 16-SNAPSHOT, updated GeoWebCache dependency to 1.10-SNAPSHOT, and related changes
[...truncated 5386 lines...]
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-gdal-wps ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-gdal-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-gdal-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-gdal-wps ---
[INFO] Copying gt-api-16-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gdal/gdal-wps/target/dependency/gt-api-16-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.10-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gdal/gdal-wps/target/dependency/gwc-core-1.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-gdal-wps ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.10-SNAPSHOT/gs-gdal-wps-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gdal/gdal-wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.10-SNAPSHOT/gs-gdal-wps-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.10-SNAPSHOT/gs-gdal-wps-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.10-SNAPSHOT/gs-gdal-wps-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.10-SNAPSHOT/gs-gdal-wps-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Ysld GeoServer Plugin 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-ysld ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-ysld ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-ysld ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-ysld ---
[INFO] Copying 0 resource
[INFO] Copying 6 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-ysld ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-ysld ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-ysld ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-ysld ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-ysld ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-ysld ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) > generate-sources @ gs-ysld >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) < generate-sources @ gs-ysld <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-ysld ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) > generate-sources @ gs-ysld >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) < generate-sources @ gs-ysld <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ysld ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-ysld ---
[INFO] Copying gt-api-16-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/dependency/gt-api-16-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.10-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/dependency/gwc-core-1.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-ysld ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/ysld/target/gs-ysld-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-ysld/2.10-SNAPSHOT/gs-ysld-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Community Release Module 2.10-SNAPSHOT
[WARNING] The POM for org.geoserver.community:gs-vectortiles:jar:2.10-SNAPSHOT is missing, no dependency information available
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 15.927 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.438 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.231 s]
[INFO] Main Module ........................................ SUCCESS [ 22.014 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.087 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.258 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.263 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.513 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 5.700 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 7.163 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 7.578 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 12.043 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 13.619 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 7.064 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 9.344 s]
[INFO] REST Support Module ................................ SUCCESS [ 4.639 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 9.000 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.042 s]
[INFO] Core UI Module ..................................... SUCCESS [ 12.426 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 5.903 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 7.500 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 3.865 s]
[INFO] Demos Module ....................................... SUCCESS [ 5.792 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 4.987 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.087 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 9.479 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 4.954 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 4.608 s]
[INFO] REST UI Module ..................................... SUCCESS [ 3.949 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.650 s]
[INFO] Community Space .................................... SUCCESS [ 0.074 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 14.253 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 10.556 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 7.920 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 6.973 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 2.426 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.079 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.027 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 9.558 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.099 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 5.520 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.901 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.056 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 12.376 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 3.332 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.302 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 5.238 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.850 s]
[INFO] WMS-EO ............................................. SUCCESS [ 5.279 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.167 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 4.659 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.317 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.107 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.953 s]
[INFO] REST plugin community module ....................... SUCCESS [ 3.982 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 3.909 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.045 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.059 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.046 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.006 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 8.058 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 5.220 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 5.575 s]
[INFO] Solr Module ........................................ SUCCESS [ 4.481 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.094 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 5.448 s]
[INFO] GeoFence Server .................................... SUCCESS [ 5.435 s]
[INFO] REST SLD service ................................... SUCCESS [ 5.090 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 4.867 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.093 s]
[INFO] Importer Core Module ............................... SUCCESS [ 7.351 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 5.327 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.198 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.064 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.470 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.051 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.851 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.035 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 3.968 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 3.859 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 4.291 s]
[INFO] GeoServer Community Release Module ................. FAILURE [ 0.225 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 07:21 min
[INFO] Finished at: 2016-04-30T08:08:11+00:00
[INFO] Final Memory: 201M/457M
[ERROR] Failed to execute goal on project gs-release: Could not resolve dependencies for project org.geoserver.community:gs-release:jar:2.10-SNAPSHOT: Failure to find org.geoserver.community:gs-vectortiles:jar:2.10-SNAPSHOT in https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-release
