[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #1144
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/1144/changes&gt;
Changes:
[rfecher] minor updates to reflect the newer namespace of the processes
[nuno.oliveira] [GEOS-7676] Makes the importer share the request context when starting
[...truncated 7084 lines...]
[INFO] Building XLST based WFS output format 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-xslt ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-xslt ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-xslt ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-xslt ---
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-xslt ---
[INFO] Compiling 12 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-xslt ---
[INFO] Copying 0 resource
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-xslt ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-xslt ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-xslt ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/gs-xslt-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-xslt ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/gs-xslt-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-xslt ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/gs-xslt-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-xslt ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/gs-xslt-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-xslt ---
[INFO] Copying gt-api-16-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/dependency/gt-api-16-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.10-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/dependency/gwc-core-1.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-xslt ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/gs-xslt-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-xslt/2.10-SNAPSHOT/gs-xslt-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-xslt/2.10-SNAPSHOT/gs-xslt-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/gs-xslt-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-xslt/2.10-SNAPSHOT/gs-xslt-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/gs-xslt-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-xslt/2.10-SNAPSHOT/gs-xslt-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/xslt/target/gs-xslt-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-xslt/2.10-SNAPSHOT/gs-xslt-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer INSPIRE Extensions 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-inspire ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/inspire/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-inspire ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-inspire ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-inspire ---
[INFO] Copying 2 resources
[INFO] Copying 16 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-inspire ---
[INFO] Compiling 15 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/inspire/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/inspire/src/main/java/org/geoserver/inspire/wmts/WMTSExtendedCapabilitiesProvider.java&gt;:\[29,7\] error: WMTSExtendedCapabilitiesProvider is not abstract and does not override abstract method encodeLayer(XMLBuilder,TileLayer) in WMTSExtension
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 16.503 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.704 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.632 s]
[INFO] Main Module ........................................ SUCCESS [ 22.107 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.065 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 4.687 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.598 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.545 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 5.656 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 6.503 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 7.237 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 11.988 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 13.336 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 7.024 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 9.764 s]
[INFO] REST Support Module ................................ SUCCESS [ 4.804 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 8.711 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.030 s]
[INFO] Core UI Module ..................................... SUCCESS [ 11.559 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 6.087 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 7.388 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 3.857 s]
[INFO] Demos Module ....................................... SUCCESS [ 5.298 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 5.268 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.043 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 9.112 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 4.432 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 4.659 s]
[INFO] REST UI Module ..................................... SUCCESS [ 3.691 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.465 s]
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 5.347 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.349 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.816 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.264 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 2.342 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 8.942 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.073 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.475 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.453 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.682 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 12.400 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 3.408 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.225 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 5.136 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.671 s]
[INFO] WMS-EO ............................................. SUCCESS [ 5.418 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.501 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 4.770 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.164 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 1.970 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.102 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.098 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.362 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.058 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.242 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.022 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.230 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.595 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 5.313 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.157 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.116 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.574 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 5.471 s]
[INFO] GeoFence Server .................................... SUCCESS [ 5.785 s]
[INFO] REST SLD service ................................... SUCCESS [ 5.076 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.166 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 4.863 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.058 s]
[INFO] Importer Core Module ............................... SUCCESS [ 7.194 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 5.464 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.191 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 4.069 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 1.988 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.779 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.019 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.850 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.019 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 4.172 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 3.809 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 4.450 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 4.911 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 4.207 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 8.028 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.037 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 5.683 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 4.749 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.281 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.983 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 1.013 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 5.871 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.020 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 10.372 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 1.900 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 4.833 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.025 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.025 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.044 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.031 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.589 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.227 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.036 s]
[INFO] OGR WFS ............................................ SUCCESS [ 3.796 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.050 s]
[INFO] Excel Output Format ................................ SUCCESS [ 3.581 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.033 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.869 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.058 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 4.551 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 4.204 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 6.016 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 3.593 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.292 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 6.212 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 4.749 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.047 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.094 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.047 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.407 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 4.550 s]
[INFO] GeoServer INSPIRE Extensions ....................... FAILURE [ 2.379 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 09:17 min
[INFO] Finished at: 2016-09-05T16:06:45+00:00
[INFO] Final Memory: 192M/431M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-inspire: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-inspire
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/1145/changes&gt;
