[Geoserver-devel] Build failed in Jenkins: geoserver-master-nightly #1195
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/1195/changes&gt;
Changes:
[tbarsballe] [GEOS-7797] Add null check to Style Editor Publishing Tab
[andrea.aime] [GEOS-7788] original BandNames from coverageViews are lost, being
[maurobartolomeoli] GEOS-6189: CAS Single Sign Out should be called after internal logout
[daniele.romagnoli] Simple updated of GDAL doc to link to latest imageio-ext version
[tbarsballe] [GEOS-7692] Add error checking to Style Editor Layer Attrubtes tab
[tbarsballe] [GEOS-7693] Do not allow WMS layers for Style Page Layer Preview /
[...truncated 3051 lines...]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-mbtiles ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-mbtiles ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-mbtiles ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-mbtiles ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-mbtiles ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-mbtiles ---
[INFO] Copying gwc-core-1.11-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/dependency/gwc-core-1.11-SNAPSHOT.jar&gt;
[INFO] Copying gt-api-17-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/dependency/gt-api-17-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-mbtiles ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer GeoPackage Extension 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-geopkg ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/geopkg/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-geopkg ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-geopkg ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-geopkg ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/geopkg/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-geopkg ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/geopkg/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-geopkg ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/geopkg/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-geopkg ---
[INFO] Compiling 5 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/geopkg/target/test-classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/geopkg/src/test/java/org/geoserver/geopkg/GeoPackageGetMapOutputFormatTest.java&gt;:\[64,25\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.053 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.565 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.369 s]
[INFO] Main Module ........................................ SUCCESS [ 29.742 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.100 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 4.877 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.791 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.506 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 5.610 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 6.590 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 8.084 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 11.741 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 14.566 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 6.908 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 13.312 s]
[INFO] REST Support Module ................................ SUCCESS [ 5.137 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 8.555 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.039 s]
[INFO] Core UI Module ..................................... SUCCESS [ 12.567 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 6.344 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 7.380 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 4.375 s]
[INFO] Demos Module ....................................... SUCCESS [ 5.802 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 5.024 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.054 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 8.639 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 4.409 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 4.544 s]
[INFO] REST UI Module ..................................... SUCCESS [ 3.892 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 24.560 s]
[INFO] Community Space .................................... SUCCESS [ 4.900 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 12.318 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 4.784 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.817 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 6.445 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 2.324 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.058 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.051 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 10.015 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.084 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 5.679 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.975 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.167 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 13.158 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 3.259 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.125 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 5.301 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.826 s]
[INFO] WMS-EO ............................................. SUCCESS [ 5.382 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.587 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 4.613 s]
[INFO] GeoServer GeoPackage Extension ..................... FAILURE [ 4.819 s]
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] REST plugin community module ....................... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 05:46 min
[INFO] Finished at: 2016-10-21T08:16:02+00:00
[INFO] Final Memory: 171M/438M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geopkg: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geopkg
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/1196/changes&gt;
