See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/1246/>
[...truncated 4952 lines...]
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc-sqlite ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-gwc-sqlite ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-gwc-sqlite ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-gwc-sqlite ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-gwc-sqlite ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/gs-gwc-sqlite-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-gwc-sqlite ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/gs-gwc-sqlite-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-gwc-sqlite ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/gs-gwc-sqlite-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-gwc-sqlite ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/gs-gwc-sqlite-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-gwc-sqlite ---
[INFO] Copying gwc-core-1.11-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/dependency/gwc-core-1.11-SNAPSHOT.jar>
[INFO] Copying gt-api-17-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/dependency/gt-api-17-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-gwc-sqlite ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/gs-gwc-sqlite-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gwc-sqlite/2.11-SNAPSHOT/gs-gwc-sqlite-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gwc-sqlite/2.11-SNAPSHOT/gs-gwc-sqlite-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/gs-gwc-sqlite-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gwc-sqlite/2.11-SNAPSHOT/gs-gwc-sqlite-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/gs-gwc-sqlite-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gwc-sqlite/2.11-SNAPSHOT/gs-gwc-sqlite-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/gwc-sqlite/target/gs-gwc-sqlite-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gwc-sqlite/2.11-SNAPSHOT/gs-gwc-sqlite-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoGig GeoServer integration 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-geogig ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/geogig/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-geogig ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-geogig ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-geogig ---
[INFO] Copying 25 resources
[INFO] Copying 17 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-geogig ---
[INFO] Compiling 58 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/geogig/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-geogig ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-geogig ---
[INFO] Compiling 24 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/geogig/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/community/geogig/src/test/java/org/geogig/geoserver/functional/GeoServerFunctionalTestContext.java>:\[59,7\] error: GeoServerFunctionalTestContext is not abstract and does not override abstract method callInternal(Method,String,String,String) in FunctionalTestContext
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.449 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.868 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.982 s]
[INFO] Main Module ........................................ SUCCESS [ 26.319 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.065 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.107 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.821 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.398 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 6.170 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 6.492 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 7.630 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 13.328 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 15.379 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 6.778 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 12.563 s]
[INFO] REST Support Module ................................ SUCCESS [ 4.598 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 8.710 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.024 s]
[INFO] Core UI Module ..................................... SUCCESS [ 12.247 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 6.130 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 7.451 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 4.307 s]
[INFO] Demos Module ....................................... SUCCESS [ 5.835 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 4.662 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.055 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 8.905 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 4.576 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 4.528 s]
[INFO] REST UI Module ..................................... SUCCESS [ 3.745 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.778 s]
[INFO] Community Space .................................... SUCCESS [ 0.059 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 7.511 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.007 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.682 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.680 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 8.642 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.054 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.031 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 10.405 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.108 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 5.542 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.484 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.654 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 18.075 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 3.480 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.509 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 5.354 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.889 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.356 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.448 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 4.809 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.048 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.062 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.791 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.133 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.310 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.007 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.462 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.736 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.122 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.426 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 10.860 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 5.414 s]
[INFO] Solr Module ........................................ SUCCESS [ 4.967 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.148 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 6.052 s]
[INFO] GeoFence Server .................................... SUCCESS [ 5.866 s]
[INFO] REST SLD service ................................... SUCCESS [ 5.420 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.197 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.086 s]
[INFO] Importer Core Module ............................... SUCCESS [ 8.415 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 6.107 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.230 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 4.618 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.193 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.592 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.043 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.923 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.045 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 4.261 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 3.996 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 4.718 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 4.854 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 4.450 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 7.586 s]
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 07:59 min
[INFO] Finished at: 2016-12-04T08:08:45+00:00
[INFO] Final Memory: 195M/482M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geogig: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
