See <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/127/>
[...truncated 3658 lines...]
[INFO] [GitCommitIdMojo] build.build.time = 15.01.2014 @ 08:06:26 UTC
[INFO] [GitCommitIdMojo] build.branch = f44bf784da4d7e3ad00c01927ff97fd712e2de55
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = f44bf78
[INFO] [GitCommitIdMojo] build.commit.id = f44bf784da4d7e3ad00c01927ff97fd712e2de55
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #451 from geosolutions-it/GEOT-4640-dependency
Updating GS code to deal with GEOT-4640
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO] Compiling 11 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/classes>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/src/test/resources>
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/test-classes>
[INFO] Tests are skipped.
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/gs-sfs-2.5-SNAPSHOT.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/gs-sfs-2.5-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/gs-sfs-2.5-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/gs-sfs-2.5-SNAPSHOT-test-sources.jar>
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/dependency/gt-api-11-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/dependency/gwc-core-1.5.0.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/gs-sfs-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sfs/2.5-SNAPSHOT/gs-sfs-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/gs-sfs-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sfs/2.5-SNAPSHOT/gs-sfs-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/gs-sfs-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sfs/2.5-SNAPSHOT/gs-sfs-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/sfs/target/gs-sfs-2.5-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sfs/2.5-SNAPSHOT/gs-sfs-2.5-SNAPSHOT-test-sources.jar
[INFO] Building Aggregating Data Store
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target>
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #451 from geosolutions-it/GEOT-4640-dependency
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 14.01.2014 @ 14:16:46 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 15-Jan-2014 08:00
[INFO] [GitCommitIdMojo] build.build.time = 15.01.2014 @ 08:06:31 UTC
[INFO] Copying 3 resources
[INFO] Copying 6 resources
[INFO] snapshot org.geotools.unsupported:gt-feature-aggregate:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.unsupported:gt-feature-aggregate:11-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 8 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/classes>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/src/test/resources>
[INFO] No sources to compile
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-sources.jar>
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/dependency/gt-api-11-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/dependency/gwc-core-1.5.0.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.5-SNAPSHOT/gs-feature-aggregate-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.5-SNAPSHOT/gs-feature-aggregate-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.5-SNAPSHOT/gs-feature-aggregate-2.5-SNAPSHOT-sources.jar
[INFO] Building WMS-EO
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target>
[INFO] [GitCommitIdMojo] build.build.time = 15.01.2014 @ 08:06:34 UTC
[INFO] Copying 12 resources
[INFO] Copying 16 resources
[INFO] Compiling 26 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/classes>
[INFO] Copying 13 resources
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/test-classes>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/dependency/gt-api-11-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/dependency/gwc-core-1.5.0.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service 2.0 Earth Observation extensions
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target>
[INFO] [GitCommitIdMojo] build.build.time = 15.01.2014 @ 08:06:41 UTC
[INFO] Copying 17 resources
[INFO] Compiling 12 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/src/main/java/org/geoserver/wcs2_0/eo/response/SingleGranuleGridCoverageReader.java>:\[44,7\] org.geoserver.wcs2_0.eo.response.SingleGranuleGridCoverageReader is not abstract and does not override abstract method delete(boolean) in org.geotools.coverage.grid.io.StructuredGridCoverage2DReader
[INFO] 1 error
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 6 minutes 3 seconds
[INFO] Finished at: Wed Jan 15 08:06:44 UTC 2014
[INFO] Final Memory: 125M/334M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/master/geoserver-master-2014-01-15-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
