See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/1323/changes>
Changes:
[github] DAEMON to follow JAVA_HOME from config var file
[tbarsballe] Use top-level LICENSE.txt for core application packages
[j_c_lavoie] Fixed display info of memory usage inside server status page
[tbarsballe] [GEOS-7900] HttpServletRequestAware: store request in ThreadLocal
[andrea.aime] Further parallelize GWC config loading
[andrea.aime] Allow more parallelization during load by using a concurrent structure
[andrea.aime] Moving metadata payloads out of the main tables
[groldan] Organize imports for geogig plugin
[emerkle] Add missing LZ4 library to GeoGig assembly XML
[emerkle] Remove errant resource file in GeoGig plugin
[dtucker] [GEOS-7937] - Change resource pool to explicitly check URL string fore
[...truncated 8575 lines...]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf/target/gs-netcdf-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-netcdf/2.11-SNAPSHOT/gs-netcdf-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building WCS NetCDF output Module 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-netcdf-out ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-netcdf-out ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-netcdf-out ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-netcdf-out ---
[INFO] Copying 5 resources
[INFO] Copying 7 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-netcdf-out ---
[INFO] Compiling 17 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-netcdf-out ---
[INFO] Copying 10 resources
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-netcdf-out ---
[INFO] Compiling 10 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[19,24\] error: cannot find symbol
[ERROR] package org.geotools.data
<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[20,24\] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[69,39\] error: cannot find symbol
[ERROR] class AbstractDataStore
<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStoreFactory.java>:\[20,15\] error: incompatible types: MultiDimDataStore cannot be converted to DataStore
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[140,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[145,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[168,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[348,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[388,17\] error: cannot find symbol
[ERROR] class MultiDimDataStore
<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[413,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[415,12\] error: cannot find symbol
<http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[415,34\] error: cannot find symbol
[INFO] 12 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 19.285 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.415 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.095 s]
[INFO] Main Module ........................................ SUCCESS [ 21.538 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.081 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.168 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.500 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.744 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 5.902 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 7.392 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 8.301 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 12.251 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 13.439 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 8.541 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 9.789 s]
[INFO] REST Support Module ................................ SUCCESS [ 4.673 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 8.806 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.060 s]
[INFO] Core UI Module ..................................... SUCCESS [ 13.206 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.027 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 4.238 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 6.481 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 7.559 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 4.537 s]
[INFO] Demos Module ....................................... SUCCESS [ 5.743 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 4.912 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.074 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 8.533 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 4.587 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 4.553 s]
[INFO] REST UI Module ..................................... SUCCESS [ 4.075 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.004 s]
[INFO] Community Space .................................... SUCCESS [ 0.110 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 9.368 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 8.144 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 7.393 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 12.541 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 6.028 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.035 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 10.494 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.086 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 5.506 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.651 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.657 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 12.778 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 3.461 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.195 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 5.069 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.942 s]
[INFO] WMS-EO ............................................. SUCCESS [ 5.586 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.330 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 5.797 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.101 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.130 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.945 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.391 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.332 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.441 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.658 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.027 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 6.263 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 5.460 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 5.875 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 5.588 s]
[INFO] Solr Module ........................................ SUCCESS [ 4.377 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.424 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 5.558 s]
[INFO] GeoFence Server .................................... SUCCESS [ 6.675 s]
[INFO] REST SLD service ................................... SUCCESS [ 5.218 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.283 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.057 s]
[INFO] Importer Core Module ............................... SUCCESS [ 6.825 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 5.683 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.791 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.037 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.239 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.579 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.018 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.081 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.053 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 3.903 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.141 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 4.980 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 4.735 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 8.943 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.055 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 5.709 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 4.552 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.046 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 2.790 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.143 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 5.025 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 4.769 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 4.725 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 4.413 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 5.059 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.335 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 1.978 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 4.441 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 3.799 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 2.241 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 7.582 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.325 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 8.589 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 3.308 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 5.626 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.025 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.025 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.025 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.027 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 5.219 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.275 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.046 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.240 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.208 s]
[INFO] Excel Output Format ................................ SUCCESS [ 3.809 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.087 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.794 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.050 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 4.579 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 4.204 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 5.970 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 3.699 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.862 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.043 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 6.342 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 4.733 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.053 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.934 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.047 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.421 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 4.562 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 5.997 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.050 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.820 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.190 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 6.361 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 3.757 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.037 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 3.972 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 3.764 s]
[INFO] Printing Module .................................... SUCCESS [ 3.993 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.034 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 5.527 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 4.094 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 3.879 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 5.744 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 4.344 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 5.380 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 4.779 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 4.197 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 6.305 s]
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11:51 min
[INFO] Finished at: 2017-02-18T08:12:43+00:00
[INFO] Final Memory: 203M/452M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-netcdf-out: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[20,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[69,39\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStoreFactory.java>:\[20,15\] error: incompatible types: MultiDimDataStore cannot be converted to DataStore
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[413,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master-nightly/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java>:\[415,34\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
